Could it be the CPS?
Old August 13th, 2010, 01:23 PM   #1
8A_Honda is on a distinguished road
So I'm at school (auto tech) and our instructor tells us about a car problem and wants to see who can figure it out by what he tells us. It's a 3.8L, has a random #1 cylinder misfire, compression is 150 on all cylinders except #1 is at 140 but leak down test says there's no leak in the cylinders. Apparently, this is a common problem on 3.8 motors.
I'm thinking it's the CPS because it can cause the misfire code and the timing would be off I suppose. But would that change the compression somehow??? It's just on #1 cylinder. Thanks would be appreciated.
Old August 13th, 2010, 01:28 PM   #2
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to all
I would look at the valvetrain myself.
If it was the cps, I would suspect all cylinder to be reading a tad low...
Random misfire could just be a bad injector / ignition coil
Disclamer: I haven't eaten breakfast yet so only ESG is here the 642T is still waking up.
Hi, You can call me Kyle
Random ESG fact: Had a prochamber on his v6 before it was popular.
WTB: v6 BBK valve covers
Old August 13th, 2010, 01:32 PM   #3
1996 Mustang 3.8l
Walters97Racing is on a distinguished road
same idea here. remember the kiss method. keep it simple stupid. dont jump to the abstract possibilities first. check the plugs, wires, injectors and stuff that would have an effect on a single cylinder
96 v6 - needs v8
03 Roush - needs turbo
06 F250 6.0 - needs stepladder
Old August 13th, 2010, 01:50 PM   #4
Yes but there's "lower" compression on cylinder #1. Leak down test says there's no leakage in the cylinder but it's 10 psi lower than the others. Random cylinder 1 misfire. Misfire isn't gonna cause the lower compression. Sure there's some information we don't have to answer the question but just trying to look like the smart one in the class. Lol. Well, I usually am.
Old August 13th, 2010, 01:57 PM   #5
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
valvetrain sir.
Old August 13th, 2010, 01:59 PM   #6
Why do you think valvetrain???
Old August 13th, 2010, 02:00 PM   #7
1996 Mustang 3.8l
well in that case.. is it the same piston as the rest? stupid question but its gotta be asked
96 v6 - needs v8
Old August 13th, 2010, 02:03 PM   #8
Yes it is.
Old August 13th, 2010, 02:05 PM   #9
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
Low comp and leak down is fine, its my educated guess of today...
Without anymore specs on the motor of course.
Old August 13th, 2010, 02:08 PM   #10
But there's a misfire involved. I would think that if this is a common problem, there'd be a tsb but we can't get onto alldata right now. Guess I'll post back sometime Monday if we don't get an answer before then.
Old August 13th, 2010, 02:13 PM   #11
1996 Mustang 3.8l
lol. i got all data. want me to check it out? haha
96 v6 - needs v8
Old August 13th, 2010, 02:18 PM   #12
Sure, if ya have nothing else to do. Lol. I guess this could be the quiz for the forum as well.
Old August 13th, 2010, 02:19 PM   #13
1996 Mustang 3.8l
lol. give me a min. i gotta log in n all
96 v6 - needs v8
Old August 13th, 2010, 02:20 PM   #14
1996 Mustang 3.8l
whats the vehicle?
96 v6 - needs v8
Old August 13th, 2010, 02:27 PM   #15
It's a Ford with a 3.8. He won't say anything else other than that it's around an 05+
Old August 13th, 2010, 02:33 PM   #16
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
05+ 3.8 , you mean 3.9?
Or its not push rod?
Old August 13th, 2010, 02:36 PM   #17
1996 Mustang 3.8l
the only tbs i see remotely related is this
NOTE FOLLOW THIS TSB PROCEDURE ONLY IF THERE ARE NO SPECIFIC MISFIRE TSBs/SSMs RELEASED FOR THE VEHICLE SYMPTOM BEING EXPERIENCED.
ISSUE
Approximately 50% of coil on plug (COP) coils returned for warranty do not have a problem.
ACTION
The misfiring cylinder must be identified through Self-Test misfire codes or through WDS Power Balance. Rule out base engine problems, rule out fuel problems, and then look at ignition problems (be sure to rule out coil primary circuit issues). Once the above steps have been completed, and the issue is in the secondary part of the ignition system, the oscilloscope procedure outlined in this TSB can isolate the difference between a coil or spark plug problem.
96 v6 - needs v8
Old August 13th, 2010, 02:39 PM   #18
1996 Mustang 3.8l
yeah. the clossest thing i could find of corse for it to be a 3.8 was an 04 mustang
96 v6 - needs v8
Old August 13th, 2010, 02:47 PM   #19
nukeman13's Avatar
99 mustang v6
nukeman13 is on a distinguished road
i had the same problem... but mine was bad o2 sensors and bad egr pressure feadback sensor... im sure if urs was the same then those codes for the sensors would come up... i suggest u listen to ESG.. he knows what he's talkin about haha
Old August 13th, 2010, 02:56 PM   #20
Resident badass
Mr. Red Pony's Avatar
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
Possibly not a valve closing completely allowing just a little air to escape. That's my guess. But you would figure if it would let a little out, it would let all out. I think if it was the CPS it would cause it on all. Is the spark plug letting air past it? right before I blew out a sparkplug it was missfiring on that cylinder. Could be a combination of those WITH a faulty injector.. It is fuel injected right?
271rwhp N/A V6
Suck it.
Threads Similar to: Could it be the CPS?
cps injected03stang 99-04 4 October 20th, 2008 03:27 PM
CPS?? CBSTANG 5.0 Mustangs 1 January 24th, 2007 09:37 PM
