interested in gears and a t lok - Page 2
Old August 17th, 2010, 10:41 PM   #21
Codeman's Avatar
Codeman will become famous soon enoughCodeman will become famous soon enough
I use an air grinder for most of the porting. But it gets to be a pain in the butt. Cuz my compressor cant keep up.
Then I have been using a dremel with those stones to get in and clean it up. I also am using it with sanding wheels to polish. I have about 10 hours into it. I just got to fill the EGR ports, which I ground out already. Then fill in the holes for the IMRC shaft. Then blend those in. Port the other side, and smooth it all out and polish it. Then I have to clean the gasket surfaces that I knicked a couple times on accident with the cutter.
UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors
Old August 18th, 2010, 05:21 AM   #22
nukeman13's Avatar
99 mustang v6
nukeman13 is on a distinguished road
what are the gains of a decent port/polish job?
Threads Similar to: interested in gears and a t lok
Gears and T-lok Ninjawafers! V6 Mustangs 10 September 1st, 2008 01:16 PM
Gears and T-lok RavensChild V6 Mustangs 6 January 13th, 2008 07:51 PM
gears and t-lok stanged out V6 Mustangs 13 March 8th, 2007 12:06 AM
4.10 Gears And T-Lok stanged out V6 Mustangs 7 October 25th, 2006 12:10 PM
