the PCM, questions ?
Old August 17th, 2010, 07:28 PM   #1
Horseyxpowered's Avatar
65 289/66 351/93 5.0/99v6
13.2@114
Horseyxpowered is on a distinguished road
Send a message via AIM to Horseyxpowered
so i took care of my misfire #3 cyd, replaced my coil pack, plugs and wires. My SERV ENG light still wont piss off ! THE CODE IS : 2ndary air injection, incorrect flow... well i replaces my air pump with a factory ford one. DYNO states the engine is running TOP KNOTCH >? im wondering if the PCM got anything to do with this service engine light? any ideas ?
Old August 17th, 2010, 08:32 PM   #2
99 mustang
clidefr0g is an unknown quantity at this point
unplug the neg bat terminal for 20 minutes it will clear the code, if it comes back check it out, if it doesnt then ur fine.
*disclaimer* If i tell you something about your car i may be wrong so if your not sure take your car to a mechanic!
Originally Posted by ReverendDexter View Post
Make something idiot-proof, and they'll just make a better idiot.
Old August 18th, 2010, 12:51 PM   #3
13.2@114
@clidefr0g : yeah i have done that a few good times, even cleared the codes from a computer scanner. It is just crazy how this even had the FORD EXPERTS puzzled at why the code was thrown even after we replaced the problem parts
Old August 18th, 2010, 01:51 PM   #4
v6kid's Avatar
1999 Mustang v6
v6kid will become famous soon enough
Either you have another problematic part or it's the pcm. Just forget about it if it's not causing a problem, or get a tune to get rid of the light.
I went to school to be a mechanic, so I know what I'm talking about most of the time.
mods in the garage, slowly getting peppier.
6ershootout.com summer of 2012... Be There
Threads Similar to: the PCM, questions ?
98 Gt PCM monoxide83 96-98 2 January 16th, 2010 12:31 AM
pcm flashing questions M0T0PSYC0 99-04 6 September 15th, 2008 12:38 AM
Pcm -??? JOHNNY K. 99-04 1 August 22nd, 2008 03:45 PM
the pcm krispy V6 Mustangs 13 June 28th, 2008 07:04 PM
A Couple of PCM questions.. Need Help! ohcat68 99-04 4 May 8th, 2008 03:29 PM
