black smoke
Old August 18th, 2010, 05:35 PM   #1
aheartofamom2 is on a distinguished road
Unhappy
black smoke
I went to start my car the other day and when I did the engine sputtered and then died with black smoke coming out of the exhuast pipe and engine, the day before I was driving home and had a half tank of gas when I look and gas gauge it read below empty and fuel light was on, it scared me and got in the turn lane and when I applied my brakes the gauge popped back up and fuel light went off. Could it be from my fuel injection being plugged?????? Please help
Old August 18th, 2010, 05:38 PM   #2
oh oops....I have a 2000 Mustang V6
Old August 18th, 2010, 07:09 PM   #3
99 mustang
clidefr0g is an unknown quantity at this point
Black smoke is caused by excess fuel that has entered the cylinder area and cannot be burned completely. Another term for excess fuel is "running rich." Black smoke out the tailpipe is the least cause for alarm. Excess fuel will usually effect engine performance, reduce fuel economy, and produce a fuel odor.
How did the fuel get into the cylinder in the first place? Some of the causes of excess fuel are a carburetor that is out of adjustment, a faulty fuel pump, a leaky fuel injector, or a faulty engine computer or computer sensor. If black smoke is present, check the engine oil to make sure excess fuel has not contaminated it. Do not start the engine if a heavy, raw fuel smell can be detected in the engine oil, Call your mechanic.
*disclaimer* If i tell you something about your car i may be wrong so if your not sure take your car to a mechanic!
Originally Posted by ReverendDexter View Post
Make something idiot-proof, and they'll just make a better idiot.
Old August 19th, 2010, 12:41 PM   #4
Thank you cliderfrOg, that gives me somewhere to start cuz I know nothing about engines, I am mechanically retarded :-) so again thank you very much
Old August 19th, 2010, 04:09 PM   #5
Six Banger's Avatar
2001 - 3.8
Six Banger has a spectacular aura aboutSix Banger has a spectacular aura aboutSix Banger has a spectacular aura about
You didnt get a CEL did you?
Look on the bright side: If you're reading this, you're alive. And that's fucking awesome.
Old August 19th, 2010, 09:37 PM   #6
What is a CEL?
Old August 19th, 2010, 10:01 PM   #7
I'm doing it wrong
Rich J's Avatar
04 Grand Cherokee
Rich J is just really niceRich J is just really niceRich J is just really niceRich J is just really nice
check engine light
Formerly known as Demon_54
"I feel the same way about disco as I do about herpes." - Hunter S. Thompson
Old August 19th, 2010, 10:25 PM   #8
Resident badass
Mr. Red Pony's Avatar
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
Any problem happen prior to this? The gauge sounds like a bad sending unit. It dying could be a vacuum leak. Black smoke is running rich. Do you fill the tank up even after the gas pump clicks off? How long has it had black smoke? Running rich can foul the plugs, and they could be causing poor combustion making run even more rich.
271rwhp N/A V6
Suck it.
Old August 20th, 2010, 02:25 PM   #9
That was the first time it happened and I haven't started it since. No I don't fill it up everytime. Should I be filling it up everytime? Is there a point I should't let it get to before filling it up? I've never had a car like this so it's new to me and any info would be greatly appriciated, I would like to make it last for a while...lol...
Old August 20th, 2010, 06:15 PM   #10
Resident badass
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
Take it to firestone. Get an inspection. Could be something like a sensor sending bad info.
271rwhp N/A V6
Suck it.
Old August 20th, 2010, 06:22 PM   #11
BadBlackGT's Avatar
13.82@100.26
BadBlackGT is a jewel in the roughBadBlackGT is a jewel in the roughBadBlackGT is a jewel in the roughBadBlackGT is a jewel in the rough
o2 sensor making it run rich?
If its got titts or tires, it's gonna give you problems.
Originally Posted by navyman8903 View Post
He has a 500rwhp 1990 5.0L with a cam who's lope takes virginity.
Originally Posted by Towelly View Post
Go find some Chill biscuits, dip them in some Calm the Fuck down sauce and chill the fuck out.
Old August 20th, 2010, 07:30 PM   #12
9986paulk's Avatar
1999 Mustang V6
9986paulk will become famous soon enough
the fuel gauge would be a completly unrelated problem. as long as there was enough gas in it for it to run, it was ok. And as far as the black smoke, yes it is excess fuel. If there are really no driveablity problems, then keep driving it unless it starts acting funny often. I'm used to something funny going on, it happens somewhat often once you modify a car.
Just start it and see if it runs ok.
Old August 20th, 2010, 07:59 PM   #13
99 mustang
its not a good idea to keep driving your car with black smoke coming out the back, get it fixed...
Old August 20th, 2010, 11:54 PM   #14
walt1120's Avatar
04 Stang 1.0Gallon V6
14.45 @95.8
walt1120 has a spectacular aura aboutwalt1120 has a spectacular aura about
strange your not throwing a code with the gauge doing that. sometimes that would happen if maybe there was be damaged fuse in the distribution box, check that out.
a bad injector usually increases effect over time so that fact that you started the car and it was just all 0of a sudden running rich would most likely be the 02 sensor gone bad, or something with your cars computer, possibly could be caused by a blown fuse in the distribution box that messed something up.
your going to need to take your car to someone who does know what there doing and can see exactly whats going on because no-one here can tell you the exact problem unless were there with you checking out your car.
2004 Bolt on & Cammed 3.9L V6
Old August 24th, 2010, 12:48 PM   #15
I'm not driving it....I started it and that happened and I haven't started it since
Old August 24th, 2010, 01:01 PM   #16
Well here it is, there is a gas odor in my oil, so it is contaminated !!!!!!! If there is anything I can do other then a mechanic please let me know, but if it also better to just take it to a mechanic let me know that too. Much appriciated all
Threads Similar to: black smoke
Smoke/black out CaptDeanSierra 2005 - 2010 V6 13 July 8th, 2010 03:10 AM
Black smoke. Hudstang 96-98 4 September 16th, 2008 06:38 PM
Black smoke. Hudstang 96-98 1 September 13th, 2008 07:25 PM
Black smoke after poweradders Danish mustang General Tech 7 January 12th, 2008 01:00 PM
'00 Mustang V6 black smoke Makikun V6 Mustangs 15 January 26th, 2007 03:59 PM
