Where and what are the best brakes to buy?
Old August 19th, 2010, 06:47 AM   #1
00mustangv6's Avatar
2000 Mustang v6
00mustangv6 is an unknown quantity at this point
for a v6 daily driver with some mods not for racing? id like to put a whole system in the brakes are shot for the best price
Old August 19th, 2010, 10:28 AM   #2
mustangmike!'s Avatar
2004,1994,1967
14.37 @ 96
mustangmike! is a jewel in the roughmustangmike! is a jewel in the roughmustangmike! is a jewel in the rough
Turn rotors + new pads from local auto parts store works wonders
227whp N/A V6
Now w/ 8th Mile 8s !
How To Jmod Your Late Model 4R70W
Old August 19th, 2010, 10:30 AM   #3
2004,1994,1967
14.37 @ 96
but if you really want to spend that kind of money just on brakes, a good pair of stock or just like them; GT, Mach1, or Cobra brakes.
Dont go waste a ton on the big slotted and drilled brakes for a DD
227whp N/A V6
Old August 19th, 2010, 01:23 PM   #4
Not Banned
southfour!'s Avatar
2000 Mustang V6
2000 Silverado 1500
southfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of light
Send a message via AIM to southfour! Send a message via MSN to southfour!
Gt brakes are the same as sixxers
If you want to upgrade get a set of bullitt/Mach/ or Cobra fronts
For the rear you will need the brake brackets which requires pulling out the axles in the rear end so you will also need new diff oil.
The rear calipers on all new edge mustangs are the same with the exception of the Mach/ cobra and bullitt using thinner pads for a wider rotor. If your stock rear calipers are good they can be modified to use the larger cobra rotors.
You will also need the larger cobra anti moan braces from a 94-98 cobra
American muscle sells all the parts needed in the kit for $184 and that is the best deal
You should be able to find a used set of front calipers and rotors for about $250-$300
H/C/I V6
BMC Member: 12521
Old August 19th, 2010, 01:49 PM   #5
2000stallion's Avatar
2000 Mustang
slow@slow
2000stallion will become famous soon enough2000stallion will become famous soon enough
You dont need to stop fast unless you can go fast....
For Sale:
99-04 smoked tail light covers
Old August 19th, 2010, 02:16 PM   #6
v6kid's Avatar
1999 Mustang v6
v6kid will become famous soon enough
^ true... I'm probably never going to upgrade my brakes. I'm never going to go over 100. And I already have a problem with my skinny stock tires losing traction from braking.
I went to school to be a mechanic, so I know what I'm talking about most of the time.
mods in the garage, slowly getting peppier.
6ershootout.com summer of 2012... Be There
Old August 19th, 2010, 02:22 PM   #7
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
If that's the case, there is NOTHING you can do to increase your braking performance until you upgrade your tires (well, other than adding ABS).
Once you have better tires, my suggestion is to get stainless braided lines, get some *good* brake pads (Hawks, EBCs, or Porterfields), then flush your system, replacing the fluid with DOT 4 (higher DOT rating means higher boiling point, which means the system can take more heat before your pedal goes soft).
The only reason for bigger brakes is that they can absorb more heat before heatsoaking. If you're not pushing hard enough to get heat-related issues, then bigger brakes are actually detrimental to performance as they're just unnecessary unsprung weight.
O o
/¯/______________________
\_\
Old August 19th, 2010, 02:26 PM   #8
v6kid's Avatar
1999 Mustang v6
You always seem to amaze me at your level of knowledge
Old August 19th, 2010, 02:39 PM   #9
2000 Mustang
slow@slow
LOL me too
For Sale:
Old August 19th, 2010, 03:39 PM   #10
1 Wheel Peel
GreenMustang00's Avatar
2000 Mustang 393w
2001 Mustang GT Vert
GreenMustang00 has a spectacular aura aboutGreenMustang00 has a spectacular aura aboutGreenMustang00 has a spectacular aura about
Who needs to stop anyways???
2000 393w Swapped Vert
2001 GT Vert
2002 Six Banger
Old August 19th, 2010, 04:53 PM   #11
2000 Mustang
slow@slow
haha yeah i roll stop signs all day long! but seriously...i dont
For Sale:
Old August 19th, 2010, 04:59 PM   #12
One gear, GO!
Gerbig's Avatar
Gerbig is a glorious beacon of lightGerbig is a glorious beacon of lightGerbig is a glorious beacon of lightGerbig is a glorious beacon of lightGerbig is a glorious beacon of light
iTrader: 8 reviews
go to autozone..i got duralast ceramic and they have lifetime warranty, even on normal wear
2000 Mustang GT-It's a miracle, it runs!!!
Originally Posted by sclass-hole View Post
I'd mail you a free stylus but that would be like giving a nun a dildo. Neither one of you would know what the fuck to do with it!
Old August 19th, 2010, 05:06 PM   #13
Six Banger's Avatar
2001 - 3.8
Six Banger has a spectacular aura aboutSix Banger has a spectacular aura aboutSix Banger has a spectacular aura about
newbs
and me
Look on the bright side: If you're reading this, you're alive. And that's fucking awesome.
Old August 19th, 2010, 05:29 PM   #14
You say that like it's a good thing; brake pads *should* be a wear item. You have to think about why those pads have a lifetime warranty, and how that relates to how they actually work.
O o
\_\
Threads Similar to: Where and what are the best brakes to buy?
stroker, buy a shortblock, or buy parts and have it assembled? 94pacecarSVT 99-04 23 March 3rd, 2010 10:44 PM
cobra brakes vs Baer brakes 03SuperchargedGT 99-04 20 May 1st, 2009 05:08 PM
buy a rotating assembly to make a 298stroker or just buy a livernois 298 stroker? navyman8903 2005 - 2010 56 October 27th, 2008 01:58 PM
Buy a 93,95 or wait and buy a new vette? Got the itch 1911A1 5.0 Mustangs 14 August 8th, 2008 02:53 AM
Will 97 front brakes fit a fox? and should i buy these slicks? whitefox89 5.0 Mustangs 18 December 20th, 2007 06:26 PM
