#21 |
99 V6 BASE
NEVER RACED THIS ONE
There's also a sticky on V6 plugs
#22 |
1999 Mustang v6
Where?
I went to school to be a mechanic, so I know what I'm talking about most of the time. mods in the garage, slowly getting peppier. 6ershootout.com summer of 2012... Be There |
#23 |
99 V6 BASE
V6 tech then work shop then link then menu. its alot of work but its there lol lol
#24 |
1999 Mustang Coupe
I could not find a sticky on it, nor find anything using the search function. Oh well, you guys gave me the info I needed. I got some motorcraft plugs for it and its running good. Thanks for the info, you da man MM!
Andy!
1999 Bright Atlantic Blue Metallic V6 Stang 18x9 Bullitts||GT Rear Bumper||Flowmaster||3 inch tips||Stock wing Mod ||Mach 1 chin spoiler||grille delete||Sequential Tails CLICK HERE FOR MY GARAGE AND SHITTY CELL PHONE PICS
#25 |
glad it worked out for ya manye
![]() 1995 Turbo V6 Mustang (auto) Check out my build <---- ET: 14.1@99mph (coupler blowing off/MBC failing ) Built by Iron Horse Motorsports |
#26 |
Priest of the Car Gods
+1 for NGK coppers. They shouldn't be any more than $2/plug.
#27 |
No matter what, Do not get BOSCH spark plugs
#28 |
+1
+eleventybillion if talking about multi-electrode Bosch plugs.
#29 |
I'm doing it wrong
04 Grand Cherokee
I just went with normal old autolite coppers, nothing fancy at all. Been working fine for me, no problems or anything. I had double plats in the car before that and I would mis fire every so often, they were gapped correctly I checked when I pulled them out. Swapped the coppers in and havent had a problem yet and its been a couple months since.
Formerly known as Demon_54 "I feel the same way about disco as I do about herpes." - Hunter S. Thompson
#30 | |
99 V6 BASE
Many Ford engines come from the factory with different platinum spark plugs on the left and right sides of the engine. On a 2000 3.8L V6 you will find platinum plugs marked AWSF-42E on the LH side (cylinders 1,2,3) and AWSF-42EG on the RH side (cylinders 4,5,6). They appear to have different electrodes. Why is this? Ford does it to take advantage of the "waste spark ignition system" on our cars, in which there is one coil for each pair of spark plugs. One half of the plugs see a different polarity from the other half. Ford Engine Cylinders Firing Order 1.9L 4 1 3 4 2 2.3L 4 1 3 4 2 3.8L 6 1 4 2 5 3 6 (1 2 3 are red) 4.6L 8 1 3 7 2 6 5 4 8 4.6L 32 Valve 8 1 3 7 2 6 5 4 8 The chart above illiustrates the firing orders and polarities for Ford waste spark ignition systems. The red numbers are positive firing spark plugs. The blue numbers are negative firing spark plugs. These differing polarities cause the spark plug electrode metal (platinum) to erode differently, depending on the direction of the current flow of the spark. On one side of the engine metal is transferred from the tip to the electrode. On the other side it goes from electrode to tip. This allows Ford to save a tiny bit of platinum on each plug installed at the factory by using plugs with only a platinum tip on one side and plugs with only a platinum electrode on the other. Doing this may only save a few cents per plug, but it adds up. Just think how many spark plugs Ford installs. The replacement platinum plugs specified for our cars (AWSF-42EE) have platinum both on the tip and the electrode, so they can be used on either side. Another replacement option (the one I chose) is to install copper plugs in the same heat range (AWSF-42C). I install new copper plugs every 15,000 miles and thats the sticky
Threads Similar to: spark plugs
| Spark Plugs Gap for Colder Plugs | Matt. | V6 Mustangs | 5 | April 10th, 2010 11:48 AM |
| 08 Spark plugs | 08blackchrome | 2005 - 2010 | 9 | October 31st, 2008 09:12 AM |
| the new E3 spark plugs? | 71mustang06 | 2005 - 2010 | 1 | October 15th, 2008 08:31 PM |
| Spark Plugs | 2000Mustang | V6 Mustangs | 5 | July 31st, 2007 03:48 PM |
| spark plugs?? | jmansracerocket | 99-04 | 1 | July 22nd, 2007 09:42 PM |
