Getting very worried.
Old August 24th, 2010, 01:27 AM   #1
Mces97@gmail.com is on a distinguished road
Sorry for the long post in advanced, but please read and offer advice if you can.The other day I made a post about oil mixing with my coolant. Took it to a trusty mechanic who said he did some tests and everything came back clean, and he does not think it is the head gasket as was suggested. I remember when he showed me the new coolant the level was very high. When I got home I saw it was lower, but it was about the height of the full cool mark , so I figured that would be the end of this. I took the car down to Florida, and about 3/4 of the way there I decided to check out the coolant. It was still even after running the car for hours of 75mph driving at the full cool mark. I thought it was suppose to be at the hot full mark. Now here is what is getting me worried. My service engine soon light popped up. This happened last week and I saw that the guy who pumped my gas in nj (where you can not pump your own gas) did not put the gas cap on properly. I attributed it to that and disconnected the battery for a few min and the light went away. Now I dont know what to think. I also have had a few times the lights for my odometer not turn on and then suddenly come back, so I want to hope that it is just a computer glitch and not a major mechanical problem. The car is not overheating or driving odd in any way, except for a little vibrating noise when the car is driven between 58-62mph, over or under and I hear nothing. If there was a problem with coolant or the headgasket, or something mechanical that made the check engine light come on, shouldn't I feel it? I still need to get my car to Florida and hope that nothing serious happens as I don't know any mechanics in the area I am in.
Thanks
Old August 24th, 2010, 01:43 AM   #2
v6kid's Avatar
1999 Mustang v6
v6kid will become famous soon enough
If that light hasn't come back on then chill.... The odometer is just something that happens to a lot of our cars with age.
I went to school to be a mechanic, so I know what I'm talking about most of the time.
mods in the garage, slowly getting peppier.
6ershootout.com summer of 2012... Be There
Old August 24th, 2010, 01:47 AM   #3
Sorry if I did not make it clear, the light I was able to turn off last week, but it came on today while driving my car to Florida, after about 700 miles of driving. The Car does not overheat and like stated before seems fine, not pulling or struggling in anyway. I am going to go to an autozone as soon as I can and see if they can pull the code, and also go to a mechanic so he can look at the coolant level and let me know if he thinks its low. I really do not how to determine if the levels are proper or not simply because the car is not overheating.
Old August 24th, 2010, 01:57 AM   #4
v6kid's Avatar
1999 Mustang v6
I'm sorry I must have misread it.
If you are going to be going to a mechanic then forget Autozone. Typically the know very little about what they are actually looking at. Just have the Mechanic look at it.
Old August 24th, 2010, 09:24 AM   #5
stephen has a spectacular aura aboutstephen has a spectacular aura about
The variation in coolant levels sounds normal. There was some air in the system and it has worked it's way out and now the radiator refilled from the overflow bottle.
The check engine light is probably unrelated. See what the code says.
Old August 24th, 2010, 10:43 AM   #6
Trick Tuners's Avatar
KB'd GT
I wouldn't worry with those symptoms. I would try cleaning the battery terminals just to rule out / help with an electrical issue. Maybe check the ecu ground wire too.
Threads Similar to: Getting very worried.
Really Worried! Help Antfo89 Modular Mustangs 14 May 19th, 2009 09:39 PM
Worried 2006GTARPD3 2005 - 2010 10 April 27th, 2009 04:41 PM
I know you were all worried so 07 STROKER The Clubhouse 41 January 13th, 2009 10:48 AM
Please tell me this is nothing to be worried about! amphibrecon 99-04 21 March 27th, 2007 05:36 PM
