Help With Windstar Install - Page 4
Old September 1st, 2010, 08:30 PM   #61
Resident badass
Mr. Red Pony's Avatar
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
I has plastic MAF.
271rwhp N/A V6
Suck it.
Old September 1st, 2010, 11:04 PM   #62
Not Banned
southfour!'s Avatar
2000 Mustang V6
2000 Silverado 1500
southfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of light
Send a message via AIM to southfour! Send a message via MSN to southfour!
Well I got a coupler on there now, I tried tightening it down and I would rather just have the coupler on there.
Also did anyone else notice that their gas pedal became a bit stiffer?
And the damn thing still has a vac leak and I cannot see where it's coming from so tomorrow I'm taking off all the hoses and re connecting them.
edit: new coupler
and should i make a bracket to move the throttle cable bracket foreward more so i can attatch the cruise cable?
H/C/I V6
BMC Member: 12521
Old September 2nd, 2010, 12:38 AM   #63
99 BLUE V6's Avatar
99 V6 BASE
NEVER RACED THIS ONE
99 BLUE V6 has a spectacular aura about99 BLUE V6 has a spectacular aura about
edit: new coupler
1) coupler looks good.
2) i would pull TB off first and look at how its sealing. are you using gasket or o-ring?
3) my pedal felt easier (stock TB with extension)
4) i dont think you have much room to mod bracket. and it shouldent be nessassery. is cruz cable adjustable at other end?
Old September 2nd, 2010, 12:40 AM   #64
Not Banned
southfour!'s Avatar
2000 Mustang V6
2000 Silverado 1500
Im using the provided gaskets, 1 between the spacer and intake and one between the spacer and throttle body.
tomorrow i will fill up that groove in the intake with JB weld like you did to see if it improves anything.
and im getting an updated tune tomorrow for the EGR delete and i will see if he can do anything for the larger tb and the intake.
H/C/I V6
BMC Member: 12521
Old September 2nd, 2010, 12:48 AM   #65
99 BLUE V6's Avatar
99 V6 BASE
Originally Posted by Mr. Red Pony View Post
I has plastic MAF.
01/04 plastic---99/2000 alium
Old September 2nd, 2010, 12:51 AM   #66
99 BLUE V6's Avatar
99 V6 BASE
south look at picture post 43/48
Old September 2nd, 2010, 12:56 AM   #67
Not Banned
southfour!'s Avatar
2000 Mustang V6
2000 Silverado 1500
I will check out the spring tomorrow and see if the throttle body has that groove. If so i will fill it.
Did you just use JB weld and then flatten it with a spatula?
How long does that stuff take to harden?
and how would you go about filling the little groove in the throttle body so that there is no chance if it falling off and being sucked into the engine.
H/C/I V6
BMC Member: 12521
Old September 2nd, 2010, 01:06 AM   #68
99 BLUE V6's Avatar
99 V6 BASE
jb mixed well, small spatula would work i used a flat file. get the quick set jb. you just need to look at TB and spaces mounting face.
Old September 2nd, 2010, 01:15 AM   #69
Not Banned
southfour!'s Avatar
2000 Mustang V6
2000 Silverado 1500
Alright, i will work on it tomorrow and then see how it runs.
H/C/I V6
BMC Member: 12521
Old September 2nd, 2010, 01:21 AM   #70
99 BLUE V6's Avatar
99 V6 BASE
rembember i preped my own manifold. i would think VAP has 65mm figured out.
Old September 2nd, 2010, 10:50 PM   #71
StangMod is on a distinguished road
You are correct with the throttle body gasket arrangement. You do not want to use the Windstar's rubber style gasket.
No JB Weld is needed on the throttle body or mount. Your throttle body from VAP will come all ready modified and ready to go. If you get the full kit you will not need to use any JB Weld at all.
I would look elsewhere for your vacuum leak. Let me know how it goes.
Old September 2nd, 2010, 11:04 PM   #72
Not Banned
southfour!'s Avatar
2000 Mustang V6
2000 Silverado 1500
well there is no vaccum leak, however.
tonight when i went to seafoam the car so i can get the oil changed tomorrow i went to put it in the nipple ontop of the intake above the throttle body and i think the hose might be pinched under the intake as there was no vaccum in it at all. Like all the other hoses have a bit of sucking force.
so when i get time I will take the intake off and try to re route the cable.
H/C/I V6
BMC Member: 12521
Old September 2nd, 2010, 11:36 PM   #73
1998 Mustang
jrp11888 is on a distinguished road
good luck i cant wait to start modding mine, then do the winstar swap
-Mods-
rebuilt 7.5 rear, posi, 3.73's, 245/55/16 sumi racers, CAI
-Future-
4.2L swap, ported lower, windstar upper, UDP, Tune, dual exhaust, short shift kit...etc
Old September 3rd, 2010, 12:13 AM   #74
Resident badass
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
I know. I like the look of the aluminum MAFs.
271rwhp N/A V6
Suck it.
Old September 3rd, 2010, 12:17 AM   #75
v6kid's Avatar
1999 Mustang v6
v6kid will become famous soon enough
Hey 99Bluev6, post pics of what you did with making the channel for the hose to route under the intake for Southfour.
I went to school to be a mechanic, so I know what I'm talking about most of the time.
mods in the garage, slowly getting peppier.
6ershootout.com summer of 2012... Be There
Threads Similar to: Help With Windstar Install
99 03 Windstar Install 99 BLUE V6 V6 Mustangs 31 August 20th, 2010 03:59 AM
Windstar install moddedstang93 V6 Mustangs 12 May 20th, 2010 12:57 PM
Windstar install time Mr. Red Pony V6 Mustangs 61 April 16th, 2010 01:04 AM
My Turbo install with Windstar upper swap WLJohnson05 V6 Mustangs 398 November 29th, 2008 06:03 PM
windstar Wiley V6 Mustangs 9 November 11th, 2008 08:12 PM
