Not Banned
Help With Windstar Install
Hey, I am just installing my VAP windstar kit now and im not sure if its because im super tired or if im just completely missing something. I cannot seem to get the intake to clear the coolant tube thing.
Maybe im missing somehting you guys can see. I cut it down as far as possible and bent it out as far as i could. Does anyone have pics of how they bent it? im going to resume in the morning ![]() ![]() ![]()
1999 Mustang v6
You see how yours is tilted forward and almost straight up and down.. I have mine tilted to the back and to the right.
I went to school to be a mechanic, so I know what I'm talking about most of the time. mods in the garage, slowly getting peppier. 6ershootout.com summer of 2012... Be There |
2003 3.8L Mustang SIXXER
Resting for the night is a good idea, possibly tomorrow make you realize a solution. There's many times that's happened to me haha. Anyway, nice swap. Those things look great under the hood.
![]() Serbiandude Sig U.S Navy E-3 http://www.facebook.com/profile.php?id=100001133239318 http://www.moddedmustangs.com/forums...ore-style.html |
#4 | |
Not Banned
was I supposed to push is towards the back of the car or the front? I moved it foreward a bit. |
1999 Mustang v6
I'm not sure where you're supposed to push it, but mine works. I don't have any pics of that. I can try to get some when I get up tomorrow.
01 True Blue v6
to slow to matter
Screw the tube. Cut it off and use a T to connect the 3 lines. Sooo much easier. I'll take pics of mine later.
Not Banned
Well I'm going to have to get it running to go get any parts.
1999 Mustang v6
I would've taken a picture but I can't find my camera
<EDIT> found one that might help some. If you look to the left of the TB and right behind the TB arm/spring you can see the vent cap for the coolant tube. ![]() Here if you look beside the TB you can kind of get in idea of how it is positioned. ![]() I know it all looks like a mess.
I went to school to be a mechanic, so I know what I'm talking about most of the time. mods in the garage, slowly getting peppier. 6ershootout.com summer of 2012... Be There Last edited by v6kid; August 30th, 2010 at 01:11 PM. |
Not Banned
Ok so its just a matter of moving it around until it fits.
thanks for the pics |
2001 mustang v6
I'm planning to get this same kit this month. How hard was the install over all? I'm asking because I don't have a lot of mechanical experience and don't want to get in over my head.
'01 3.8L |
1999 Mustang v6
As long as you buy the whole kit from him it will be easy... The only problem that I ran into was that I had to clean up the threads in the coolant tube that was cut.
Not Banned
Ok, i have more questions:
where does this thing go? ![]() it was plugged into here on the stock intake ![]() i deleted the EGR so do i need this little 'T" in there or should it be one line? (drivers PCV to the intake) ![]() there is no hole in the air intake tube for this sensor (only 99-00 have them) ![]() ![]() it says something about using the stock hard PCV tube for these lines, do they connect to each other? ![]() and what about this line, it comes up from where the fuel line is ![]() and should i just cut this long tube down to fit snug? ![]() (the one on the left going into the air intake pipe) and can i just zip tie the throttle cable a bit so its not sticking up so far? it almost seems too long ![]() here is where im at now
1999 Mustang v6
Ok this is alot at once but i'll try. I'll number everything in order.
1. The one that you took off the old intake take it off of the TEE... You got 3 1/4 hoses connected by a TEE one goes to the fuel rail, one to the manifold, one goes behind the manifold and connects to the now open TEE. 2. It should just be one line 3. Sounds like you got hooked up with the wrong intake pipe. You need one with port for that. That is your Intake Air Temperature sensor. It is a necessary sensor.... When you go to plug it in make sure that the passing air can hit the sensor in middle. 4.The hard 90 of the stock pcv goes on the port on top of the manifold. Look up in my pic you can see it. 5. That was hooked up to another hose at first right? In between them they were connected with a hard piece of plastic (kinda like a TEE but with only two sides, and it's straight) use that hard part to connect that line to the one that you routed underneath the intake from the top port. 6.Don't trim anything til it is all complete. Then trim it, but of course leave some slack. 7. The mount that came off the old intake looks like it is still on the cables (that's good). Use that mount to mount the cables to the two slots on the coil pack adapter plate... One of the last things to do before you're done is to adjust that mount (so just make it snug for now). You are going to want to pull the mount back so that the cables are taught against the TB arm, but the TB is fully closed (this is to insure that there is no slack) 8.Half way there just keep up the good work. -_- this was all strictly from memory. I just did this mod not long ago so I "should" be right about it all. If I was right, then <--- hit that rep button.
I went to school to be a mechanic, so I know what I'm talking about most of the time. mods in the garage, slowly getting peppier. 6ershootout.com summer of 2012... Be There Last edited by v6kid; August 30th, 2010 at 07:56 PM. |
#14 | |
Not Banned
Not Banned
ok, this hose here (the one in my hand) connected to the loose hose on the stock intake shown below
![]() connected here via a coupler ![]()
99 V6 BASE
NEVER RACED THIS ONE
Take your 90 degree cap off your PCV and put it up top for a cleaner look
Not Banned
[QUOTE=99 BLUE V6;3120612]Take your 90 degree cap off your PCV and put it up top for a cleaner look
ok so that is not necessary it just cleans things up a bit? and i dont need the stock hard PCV tube for anything else? thanks |
99 V6 BASE
did you get it all figured out?
You need the PCV, but the tube, no. As long as you can get a hose to fit it.
I recommend keeping everything that you don't think you need for awhile after, that way you make sure that you won't need it. You never know, sometimes you run into problems that make you change things.
![]() UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors |
99 V6 BASE
[quote=southfour;3120625] actually with out it your hood is going to slam into the hose.
Threads Similar to: Help With Windstar Install
| 99 03 Windstar Install | 99 BLUE V6 | V6 Mustangs | 31 | August 20th, 2010 03:59 AM |
| Windstar install | moddedstang93 | V6 Mustangs | 12 | May 20th, 2010 12:57 PM |
| Windstar install time | Mr. Red Pony | V6 Mustangs | 61 | April 16th, 2010 01:04 AM |
| My Turbo install with Windstar upper swap | WLJohnson05 | V6 Mustangs | 398 | November 29th, 2008 06:03 PM |
| windstar | Wiley | V6 Mustangs | 9 | November 11th, 2008 08:12 PM |
