Lowering springs
Old August 31st, 2010, 07:39 PM   #1
BlueScreaM's Avatar
Better than ONLYaUNCfan's
2012@lightspeed
BlueScreaM has a spectacular aura aboutBlueScreaM has a spectacular aura about
Lowering springs
Would a 2" drop be too much for a mustang i have 18" rims so its about 1/2 an inch higher on the car. A guy i know had to rebuilt his cobra motor because he messed up his oil pan due to its height... but he has 17" rims if it plays a difference on the height, i just figure mine is higher off the ground. I dont want to have to avoid every pot hole on the road cuz the roads here suck and the driveway is on a hill.
Formerly, AhobosCheese and Cheddars.
Old August 31st, 2010, 08:00 PM   #2
2000stallion's Avatar
2000 Mustang
slow@slow
2000stallion will become famous soon enough2000stallion will become famous soon enough
if the roads suck, i dont think i would look into a lowering springs. My car isnt even lowered but its still pretty damn close to the ground. And for a while, my aftermarket exhaust would scrape on every bump i hit.
For Sale:
99-04 smoked tail light covers
Old August 31st, 2010, 08:01 PM   #3
99 BLUE V6's Avatar
99 V6 BASE
NEVER RACED THIS ONE
99 BLUE V6 has a spectacular aura about99 BLUE V6 has a spectacular aura about
I think two inch is a bit much for every day driving. you will need alot of other thing just to get it align properly.
Old August 31st, 2010, 09:11 PM   #4
BlueScreaM's Avatar
2012@lightspeed
Thats what i figured I can lowering springs that lower 2" cheaper that the 1.5" but i would be more comfortable with it over the 2" but having 18's still not keep it ideal for DD?
Old August 31st, 2010, 09:12 PM   #5
BlueScreaM's Avatar
2012@lightspeed
In case im reading it wrong how tall are stock springs because it might be 2" after the springs.
Old August 31st, 2010, 09:47 PM   #6
Codeman's Avatar
Codeman will become famous soon enoughCodeman will become famous soon enough
I would recommend going with a 1.5 inch drop or so. That is pretty decent.
UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors
Old August 31st, 2010, 09:51 PM   #7
silver03gt's Avatar
2003 Mustang GT
14.16 @99.03
silver03gt is on a distinguished road
Ahh come on... 2 inches aint that much.
Military Crew - United States Navy - Second Class Petty Officer
My 2v build - MMR 1000 rotating assembly, Stage 3 heads/cams, 76mm turbo. Shooting for 700+rwhp.
Old August 31st, 2010, 09:55 PM   #8
99 BLUE V6's Avatar
99 V6 BASE
starting to sound like mabe you shouldnt be working on cars #%@&*
Old August 31st, 2010, 09:57 PM   #9
BlueScreaM's Avatar
2012@lightspeed
Thats what i think but if it has to go over speed bump sideways im walking away.... and I dont have Long tubes does anyone know what the stock spring height is? It would give me a better idea.
Old August 31st, 2010, 10:01 PM   #10
BlueScreaM's Avatar
2012@lightspeed
Right after i posted that I realized it was 2" off I just didn't take it off.
Old August 31st, 2010, 10:08 PM   #11
99 BLUE V6's Avatar
99 V6 BASE
:bang head
Old August 31st, 2010, 10:14 PM   #12
Six Banger's Avatar
2001 - 3.8
Six Banger has a spectacular aura aboutSix Banger has a spectacular aura aboutSix Banger has a spectacular aura about
Cut them, its the cheapest option of all. Mr Red Pony cut a coil out of his springs and its pretty low.
Look on the bright side: If you're reading this, you're alive. And that's fucking awesome.
Old August 31st, 2010, 10:20 PM   #13
BlueScreaM's Avatar
2012@lightspeed
Thought about it but i think im just going to replace them even though i dont want to put allot of money into it b/c im saving for a GT as well.
Old August 31st, 2010, 11:27 PM   #14
MM's Official Lucifer
goren813's Avatar
'00 3.8L & '05 4.6L
Check my garage for my mods, that set up dropped me 1.75" lower than stock height measured at the side skirt. Springs rated 1.5" drop. I wouldn't want to be any lower at all, and will actually be playing with my bumpsteer kit to try and raise the front a little bit. Have 18" wheels as well.
Basically I suggest either Eibach prokit or HR Supersport springs. I have a write up as well if you'll be doing the install yourself, its pretty simple if you know your way around hand tools and aren't in special classes.
Old August 31st, 2010, 11:35 PM   #15
BlueScreaM's Avatar
2012@lightspeed
Yeah AM has one too i appreciate it but im going to use a spring compressor but if it cant do the job ill lower the control arm a little for some room.
Old August 31st, 2010, 11:36 PM   #16
goren813's Avatar
'00 3.8L & '05 4.6L
Don't use a spring compressor, it only makes the job more difficult by getting in the way.
Old September 1st, 2010, 10:46 AM   #17
BlueScreaM's Avatar
2012@lightspeed
Really? Good thing i didn't buy one, i should just lower the control arm then and remove them that way?
Old September 1st, 2010, 01:00 PM   #18
goren813's Avatar
'00 3.8L & '05 4.6L
Yes. Esp don't buy one, auto parts stores rent them out and you get your deposit back upon return. If you let the a-arm down all the way, then just use a pry bar to get the spring out, it won't be compressed anymore and thus won't be storing any potential energy to fling out at you, you'll just have to pry them free. Again, I have a write up if you don't want to use AM's.
Old September 1st, 2010, 03:01 PM   #19
BlueScreaM's Avatar
2012@lightspeed
yeah ill cheak it out
Old September 1st, 2010, 03:06 PM   #20
BlueScreaM's Avatar
2012@lightspeed
btw goren813 how are the nexen n3000 buying those this week just wondering if there good ive heard allot of great things about them.
Threads Similar to: Lowering springs
Drag springs or lowering springs??? AggieStang General Tech 10 February 18th, 2012 12:45 PM
Lowering Springs Fir3controlman 99-04 10 May 3rd, 2010 05:12 AM
stock springs vs lowering springs in drag TotoGT06 2005 - 2010 4 April 14th, 2010 10:25 PM
best lowering springs... ZoomZoomMFer 99-04 51 November 30th, 2008 10:19 PM
