New Mustang Owner... What to get?
Old March 31st, 2007, 09:14 PM   #1
Chiefx56 is on a distinguished road
So I've only had my mustang for a month or so and I'm wondering what's good to get. I'm 18 and pretty much broke - but i'll post a pic or two soon.
Anyway i'm planning on getting a true Dual Exhaust and probably a CAI. I'm more interested in visual mods - so what are good ones? Any wheel suggestions? Paint?
You Can Run, But You'll Just Die Tired
Old March 31st, 2007, 09:20 PM   #2
97stanger is an unknown quantity at this point
welcome to MM
Here is a post i saved from awhile ago....... This really should be a sticky....but o well:
I have seen a lot of guys who are new to the performance game ask many of the same questions over and over again. Nothing wrong with that, we have all been there trust me.
You work hard like many of us,and you want your cash to pay off in HP upgrades. And you certainly dont want to waste that cash on mod's that look pretty and gain shitty (nice huh). So here are some important pointers when you are considering what to spend that hard earned cash on. This post describes a scenario in a modern modular motor (and pushrod in most cases)....
Debunking the CAI (cold air intake) hype....
First off,what is the purpose of a CAI ? A CAI is supposed to cool the inlet charge or allow cooler/more air into the combustion chamber. The cooler the air,the denser the oxygen, therefore you theoretically have more oxygen in the same amount of space compared to warmer air in the same space. Its simple,more air/fuel mixture equals more power right ? Cooler air makes more power right ? Yes and no..Says the manufactuers .
When they claim 10-15 hp gains with their CAI,where do you think they do the tests ? In the desert where cold air would really be a benefit to your motor? Nope. In a controlled enviroment with the right enviromental conditions so they can give you big numbers under the absolute best conditions. Guys when your car is sucking in 95 degree heat,its not gonna create 60 degree air. Its like the small print you read at the bottom of a weight loss commercial. When they say "you can lose 20 pounds in 4 weeks" , dont you notice the small print at the bottom of the screen ? It says,results may vary blah blah. You get the point.
Is a CAI useless ? Nope. But is it the RIGHT investment for your first mod ? Not in my opinion,and the opinions of people who have been chasing big HP numbers for years. Read on.
1) A nice cold air intake system certainly looks better that the factory intake,but are a waste of money as a FIRST or second mod. Its like a hot chick that wont give up that ass, SHE LOOKS GOOD BUT WHATS THE POINT ?. The factory air intake is actually capable of handling significant air flow . A K&N filter is a good choice because is will flow better than the factory paper cone. Thats its only purpose.
2) For an average name brand CAI you may spend around $150 new. Now ask yourself, how much air are you moving ? You have factory cams and heads (PI in a best case scenario ) and a restrictive factory exhaust. Are you making so much airflow that the factory engineered intake just cannot handle your massive HP ? No.
3)So you may be asking " Well if a CAI is better at creating cooler/denser air as said earlier,then how come its not a good investment ?" Its not a bad investment. Its just not a good FIRST investment .You need a plan of attack when looking for sizeable HP gains. And you cant build big HP from the Autozone shelves. Unfortunately,HP costs money.
"Ok OK I get it." Im not moving tons of air,therefore I dont really need to cool what air Im moving now. So whats the plan of attack ?
OK,it breaks down like this among guys in the know ..
GEARS -- The biggest vote getter in terms of first mod's is usually gears. A gear change is possibly the most difficult thing you can do on your car. Not because its so mind boggling confusing,but because the room for error is extremely minimal. Pay a pro if you cant find someone experienced to walk you through it. You can generally get a set of Ford Racing gears installed along with Royal Purple differential fluid for around $400 . Anything higher than that is maybe to high. $450 tops .
Your Stang probably came with 3.27 gear ratio in late model modular Stangs. Thats fine for factory performance and fuel economy and your factory tire size.. But they do not optimize the potential of the factory power. Picking the right gears for your car can result in a very nice gain in performance. Not more HP,but better utilization of the factory power.
What gears should you get ? First off lets explain what a gear ratio is . A gear ratio is the number of teeth on the ring divided by the number of teeth on the pinion. Its like this.... if there are 41 teeth on the ring and 11 on the piston the gear ratio is 3.73 (technically its 3.7272727272 repeatedly but its rounded up to 3.73). Just divide 41 by 11 on a calculator on you will see.Things like a larger tire size or automatic tranny dictate what gear ratio works best for your car....
Example ;If you upgrade your tire size,you need a higher gear ratio. Why ? Because the larger tire takes longer to rotate .So basically the more teeth you have,the faster you tranny will rotate the rear tires,resulting in faster speeds. On the other side of that ,if you keep the factory tires and upgrade your gears,you will see a big jump in performance as far a getty-up movement. Now you might say that "in that case Ill go with a real high ratio" . Logical thinking ,but incorrect in most cases .The higher the gear ratio,the more heat you create in the differential, which COUlD cause fluid breakdown. So there is a fine balance of what you desire and what you really need. Bigger isnt always better .
Same logic applies to a automatic tranny versus a manual. So to save you time, Ill just give away the answer to your question . Whats the best gears for an automatic ? MOST guys who know their stuff will say something like 4:10 gears because of the fact that you lose HP from the time its made in the motor to the time it actually reaches the rear tires a.k.a parasitic loss .Thats in a automatic. So its beneficial to have more teeth for a auto . .A manual ? 3:73 . You dont need as many teeth because a manual doesnt lose as much power along the drivetrain as a automatic does.You will really feel a big difference with gears.
OK, lets jump to what you really wanna know- Horsepower and the best way to get it ! This topic could be typed for days and still could not be explained in its entirety ,so lets go over the short version.
First of all, I dont care if you have a supercharged 460 big block making 600 HP under your hood. If you cant get that air out the back of tha car,your killing your performance,which brings us to ......
EXHAUST -- Now which exhaust is a LONG and opionated debate . Some x-pipes sound great while others sound like hell with certain mufflers blah blah blah . Thats just really a matter of taste. But what I can tell you is that when your ride left the factory ,it left with multiple cats (up to 6) fuggin up your flow. So yes,you should definately upgrade your exhaust . Headers are a big job,so you may wanna start with the mufflers and mid-pipe and go from there like most people do. If you choose a O/R-pipe ,your car will be louder and illegal in most states.But hey, the odds are slim that you will get caught by the fuzz anyways .So thats on you . You can also choose high flow cats which may or may not pass emissions tests . So basically ,a nice 2.5 system is the typical way to go,and you have to experiment with what set-up you want.
Now we get to the good stuff. Making real power....
You can buy a CAI, a 70mm TB ,plenum and every other bolt-on you can think of for under your hood,and you still are not gonna get the gains you could if you save that money for something like a more agressive cam profile and tune or a good port job.. Why ? Because those parts dont "make" HP . Not in the conventional sense .They are good investments eventually .They are mainly a support system for the more expensive parts to put it bluntly. As said before,HP aint cheap.
CAMS -- What does a cam do ? When the cam spins ,its lobes (egg shaped grooves on it ) open and close the intake and exhaust valves along with the motion of the piston ,rocker arms and the valve springs close them . .Soon after you have air/fuel mixing together ,the spark plugs are igniting the mixture and boom ,you have internal combustion . Thousands of controlled explosions per minute . I wont get into TDC ,pistons,stroke and all that other stuff here.Thats the short version.
So you may be wondering then,what does a aftermarket cam set-up do for me ? Its like this. There is NO PERFECT CAM PROFILE. Thats why you have SOHC,DOHC etc . But thats another story Some cams are good at low RPM's while some do better at higher RPM's or somewhere inbetween.So somewhere you have to make a compromise .
The reason a more aggressive (bigger) cam profile is better at making more HP is simple. The bigger the lobes,the longer (duration) the valves stay open and the wider (lift) they open,allowing more oppurtunity for air/fuel mixture. And that is what HP is all about . More air/fuel. The factory cams are designed for many different purposes in mind, and big HP is hardly one of them .Manufacturers have to meet lots of different federal guidlines when it comes to fuel mileage ,reliability and of course price,so they design parts to accomplish this,and leave the hot rodding up to you most of the time. But when they do build a beast of a sports cars with a forged bottom end and blower ,it usually outta the average guys price range.
When properly tuned and installed,and good cam profile- can net you anywhere from 35hp-50 in some cases. It all depends on the profile and what other mod's you have. So as you can see,cam's are the biggest bang for the buck when it comes to modular motors. Talk to any good cam company about your needs,or post it here .
CYLINDER HEADS -- When it comes to cylinder heads,us modular guys kinda got the shaft ( no pun intended) compared to the push rod crowd. The PI heads and their different variations are basically the best available. FRPP has high performace versions however,and they are expensive. The most common method of improving the heads is porting . Thats when you modify the intake/exhaust ports on the heads using a air flow bench ( you dont have one unless your awesome) .This increases gas flow. Incase you havent noticed "flow" is a very common word all in this post. The science of porting is a long one,so Im gonna skip all that . Basically,you take your heads to a shop and ask for a port job. There are different stages of port jobs,so you need to pick what you can afford and what you want to accomplish.
SUPERCHARGER -- If you have maxed out the modular motor as far as N/A mod's go,you are probably making some nice power ,and you may be done . But as soon as some F-Body does a number on you at the track or stoplight,you gonna want more .
Unfortunately for modular motors,even with all the upgrades discussed here,you will still fall way short of SERIOUS HP. If you make 350hp N/A,you da man. But your only choice for major power is forced induction a.k.a. a blower/supercharger.
I think forced induction is self explanatory ,but here is the easy version. The supercharger intake sucks in air and the supercharger crams massive amounts of air into the motor and creates whiplash power. Thats why you need bigger fuel injectors to introduce more fuel to the equation when you go the blower route. If you are going to get a roots style blower,thats another reason not to buy a TB,CAI plenum and anything else that sits on top of you motor.A roots style blower like a Kenne Bell eliminates all that.
Soooooooooo heres the summation of this little rant. As well as the popular order of modifications that make power ! Not look pretty but make power !
1. GEARS -- If you dont plan on touching the motor,get gears .They are a nice value for the punch factor ,and a good beginning to future mods. Just remember the laws of teeth talked about earlier.
2. EXHAUST -- Making gob's of HP is useless unless in can get out the back. A well set-up exhaust will help make some power by not restricting air-flow .And its just a matter of preference when it come to sound .
3. CAMS -- These are without a doubt the best investment you can make when it comes to making signifcant HP N/A . Remember ,you can spend $500-$600 on bolt-on and still not make as much as a good cam profile .Just remember ,if you go with a Stage 2 or higher,you will need to upgrade you valve springs and get a good tune. Stage 1 is generally safe on your factory springs and tune. Check with the cam maker for details on that.
4. CYLINDER HEADS -- If you have a 96-98GT and dont want to go through all the hassle of buying PI parts and everything,you can get your NPI heads ported .But I say go with the PI heads and intake plus whatever cam you want if you want to make real gains . A port job is a big bonus at around $700 or higher.
5. SUPERCHARGER -- This is the big one in everyway . Big power and big price tag. One note about these is that if you are gonna go boost crazy,you NEED to forge your bottom end or else your asking for trouble .Your factory components would do ok for a while,but the night your out on a date with a hot chick ,trust me...the only rod getting blown will be in your engine,lmao.
OK guys,I hope this has helped you in your dreams for moderate to big power. I obviously didnt cover every ounce of technical data out there ,but its broken down I think .As I said,I dont know everything but I know some things,so feel free to chime in. Just dont waste your money on Autozone stickers a neon CAI'S .
Remember 2 things ;
1 ) HP isnt cheap
2) If it looks pretty ,it gains shitty .
Originally Posted by BWAL09
aww, you fucking piece of shit, you are making me get all fucking emotional now
Old March 31st, 2007, 10:07 PM   #3
thanks that makes alot of sense and i'll definately take it into mind whe n purchasing
Old March 31st, 2007, 10:09 PM   #4
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
What kinda visual mods you want? More of a car show theme or a DD that can stand up to the elements.
NCMM #9
Old April 1st, 2007, 02:55 PM   #5
well im gonna be driving it so it needs to be able to last but look good too. i need a new front and rear bumber so maybe some suggestions on that?
Old April 1st, 2007, 03:09 PM   #6
MM's Resident Ricer
2006 Scion tC
13.001@113
A good body kit is always a good visual upgrade as well as rims, and tinting your windows. I have the saleen kit on my car. You can see some here
http://www.cruizinconcepts.com/
NCMM #9
Old April 1st, 2007, 03:13 PM   #7
Vision.Pro's Avatar
1999 Ford Mustang GT
Vision.Pro is on a distinguished road
Keep the styling simple, there's no need for cheesy oversized body kits. A simple chin spoiler should be enough, but it is also personal preference, so do what you please.
Old April 1st, 2007, 04:25 PM   #8
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of light
But a simple chin spoiler doesn't win car shows
Hi, You can call me Kyle
Old April 1st, 2007, 05:10 PM   #9
Vision.Pro's Avatar
neither should a V6
Old April 1st, 2007, 05:34 PM   #10
muneris pro ego
Ninjawafers!'s Avatar
97 5.0 Exploder AWD
snow has nuthin on me
Ninjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to behold
Send a message via AIM to Ninjawafers! Send a message via Yahoo to Ninjawafers!
Originally Posted by Vision.Pro
neither should a V6
why shouldnt it? if you are saying a v6 shouldnt win car shows then you are saying a 4 cylinder should either... or an v8 for that matter since there are cars out there with more cylinders than that. as long as the v6 is updraded from stock it would be the same as an upgraded v8 in a car show
Buy my M90 Kit and my Gears and T-Loc!
MM ZDC - Alaska Base Commander
MM+ Cleavage Club #24
MM Cares Crew / Military Crew
M2C2 President / USCG - OS2
Old April 1st, 2007, 05:50 PM   #11
g money is on a distinguished road
Only Bugatti Veyrons can win car shows, duh.
Old April 1st, 2007, 06:01 PM   #12
wannabeimportkiller's Avatar
2012 Race Red GT/CS
wannabeimportkiller will become famous soon enough
Send a message via AIM to wannabeimportkiller
didnt turp when at show, or was just a race or something. i seen a picture of him holding some kind of certificate. and why wouldnt a v6 when a car show?? Vision.Pro
2012 Race Red GT/CS
98 GT-Gone
NCMM ORIGINAL
Old April 1st, 2007, 06:25 PM   #13
i want one.
Old April 1st, 2007, 06:41 PM   #14
MM's Resident Ricer
2006 Scion tC
13.001@113
I've won first and second best ford in plenty of shows. A show is about looks rarely about numbers.
NCMM #9
Old April 1st, 2007, 07:31 PM   #15
Vision.Pro's Avatar
I'm not trying to degrade the V6 as i just recently purchased one, but i just feel that car show's aren't what they used to be and a late-base model car shouldn't be eligible for a car show, especially if the only engine work done is for show.
All that is really besides the point. What i originally said was to keep the exterior simple.
Also note that this kid said it's a daily driver not a show car, so putting a body kit on it is impractical and a waste of money. It's also a kick in the ass to the Mustang heritage to put a body kit on a stock 6 cylinder. It brings back memories of ricers putting F1 wings on a car that can't even break 90mph. Also this kid is young with no money, so a body kit will destroy his resale value on the car, especially if it isn't done right.
Old April 1st, 2007, 07:36 PM   #16
MM's Resident Ricer
2006 Scion tC
13.001@113
I have a saleen kit on my car cause I hate the stock stance of the mustang. A classy bodykit made for the car doesn't defile and mustang heritage. The point of a mustang is cheap power and the v6 gives that. And my body kit improved my resale Mine is a DD and does fine you just have to make sure it is done right. Like with everything. And a car show is meant to show your car new or old. I can beat old stock 302 bosses and 289's which are what you say should only be shown so you first statement is just stupid 9no offense of course)
NCMM #9
Old April 1st, 2007, 08:22 PM   #17
Originally Posted by GreenFaleen
I have a saleen kit on my cause hate the stock stance of the mustang. A classy bodykit made for the car doesn't defile and mustang heritage. The point of a mustang is cheap power and the v6 gives that. And my body kit improved my resale Mine is a DD and does fine you just have to make sure it is done right. Like with everything. And a car show is meant to show your car new or old. I can beat old stock 302 bosses and 289's which are what you say should only be shown so you first statement is just stupid 9no offense of course)
+1332 Here here (passes a beer to you)
Old April 1st, 2007, 09:03 PM   #18
Yeah, i got a 97 cloned out to a Saleen in every aspect expect the engine, and its my DD and i have won many mustang/ford shows.
Threads Similar to: New Mustang Owner... What to get?
New 97 Mustang GT Owner! Lgalaz Modular Mustangs 7 September 3rd, 2010 04:41 AM
I am now a Mustang owner 1bad04gt The Clubhouse 20 September 30th, 2007 02:41 AM
New Mustang Owner barksdaleammo 99-04 11 March 20th, 2007 06:48 PM
I am a new Mustang owner yojoe600 99-04 25 February 27th, 2007 10:24 AM
New Mustang Owner soon! myroush6 2005 - 2010 4 February 17th, 2007 11:22 PM
