1998 Mustang V6
232 to 351
so ive seriously been doing an engine swap. at first i was thinking about doing a modular DOHC 330, but i want to be different and try to drop a pushrod 351w in my 98 stang. right now everything is just an idea and i want to make sure i get any unclear questions out of the way before i put one buck down on the project
-im not concerned about hood clearance, but i am concerned about bay clearance between p/s, a/c, alt, and other components and the coolant resevoir and fan. would i have to get a smaller fan and resevoir or should the one i have fit right now -i know for the 302 to 351 swap the motor mounts are compatable but have the clearance issue, which right now is not a big issue cause ill make clearance. do i need to get 302/351 motor mounts or are the 232 mounts compatable as well? -what are the AOD transmissions rated, because im guessin ill be making 350/400 hp with like 450ft/lbs at the most and i dont know if that transmission will take it. -im probably going to have to buy a carb engine and then put an efi kit on it. as long as i find the right manuals it should be a breeze hooking up all the senors right? also, i know there have to be books out there about doing a 96-98 engine swap so if anyone has links please post them. |
[8MINUS2]
You would be more /different/ doing a doch 330 than a 351.. Just look at the 94/95 302 for advice
Threads Similar to: 232 to 351
| 232... | 96Snaker | The Clubhouse | 1 | February 1st, 2008 11:36 PM |
| 232-351 ? need help is it any good? | Jeffery9508 | Modular Mustangs | 0 | December 3rd, 2007 10:38 PM |
| 232 Is Still Alive | 232stang | The Clubhouse | 22 | November 24th, 2007 02:28 PM |
| the 232 tribute | HMUSN | The Clubhouse | 24 | July 7th, 2007 04:40 AM |
| 1972 Mustang Conv. BOSS 351 or 351 HO? | 72BOSS351 | Classic Mustangs | 1 | October 8th, 2006 05:12 PM |
