LinkBack (1) | Thread Tools |
#1
2002 Nitrous Injected V6
12's?
Windstar Intake, Cleaning and Tips
Alright I just got my windstar from southfour and im putting it in today with all the extra shit ordered from vap. The intake is pretty dirty so how would you reccoment cleaning it( Carb cleaner?) Also any tips before I start the install
![]() Project Red Magic -Full Intake, Full Exhuast,Geared, Tune, Sprayed, Dropped- -18 Inch Hypercoated Saleens wrapped in Nittos- |
Not Banned
Glad to see that it arrived. The van that one was pulled from was filthy. I cleaned it up a bit on the outside
For the outside I used goo gone on some other ones and it worked pretty well. Just lay down some towels and soak it then either rinse with water or wipe it off. |
12's?
I think ill let it soak in a tub overnight with some dishsoap and simple green, I wanna get it really clean before I put it on. Btw thanks again man for the intake
99 V6 BASE
NEVER RACED
you need to get in there with some sort of porting tool. polishing flapper sanding roll stone or what ever you can come up with. i've cleaned 3 of them and they all had a lot of carbon build up. get that shit out before soaking .
1999 Mustang v6
I soaked mine in a big thing of grease oil cutter stuff. Then i used a tire scrubber it get into all of the ports. They had almost 1/4" of shit on the walls of the ports. It took a lot of work to get it clean. Then I painted it.
I went to school to be a mechanic, so I know what I'm talking about most of the time. mods in the garage, slowly getting peppier. 6ershootout.com summer of 2012... Be There |
Gallagher's Worst Nightmare
I hit it with engine cleaner then a sanding sponger and dremal. worked well. I went through all the ports and it smoothed it out.
![]() C/H/I 3.8 227rwhp 226rwtq @ 0psi, 0hp shot The Name is Danny. I'm a GM Technician. hi-comp 3.9 coming very soon. |
99 V6 BASE
NEVER RACED
they are definetly NASTY.
2000 Mustang v6
16.683@83.86
acetone will take anything off of anything, I think thats the primary chemical in goo gone actually, but a huge can of it is like 10$
![]() A turbo, exhaust gasses go into the turbocharger and spin it, with a supercharger, air goes in,witchcraft happens and you go faster~Jeremy Clarkson |
Not Banned
Yep those intakes get filthy most of the vans I pulled them off of ( I've pulled about 25) were at the auto wrecker because the owner didn't do any maitnence. The air intake and filter are usually soaked and covered in oil.
12's?
I got it all clean i soaked it in dishsoap and simple green for the night then hand cleaned it all out. For the bolts on the coilpack, they are 7mm right? 1/3 bolts came out easy and the other 2 are like stripping out the outside. So any tips here
Also The egr going into the header has a leak in it and I need to tighten the bolt, what size is the bolt how do you tighten it being I cant get to it really with a wrench
#11 | |
12's?
Its bigger than 15, I was thinking like 22mm. Its where the egr goes into the passengerside header
how much bigger than 15mm? when I put my cap on, it was 3/4 (19mm)
BTW. I like the new sig.
12's?
its bigger than an inch, I just matched it up with a wrench and its not big enough, im thinkg 1 1/16. I should of capped it when i was putting my headers in
. Anyway I need to get off these coilpack bolts without rounding themand thanks man, I like your new one 2
So is it a delete cap, or are you still using the EGR? As for the bolts on the WS, try buying one of those sockets that can get a stripped bolt off.
Formerly 01silversixer
2001 V6
15.84@87.43
Hey Matt, how much did it cost you in total for the windstar? I know southfor has the intake for $75 but how much did it cost after getting the extra stuff from VAP?
I just wondered how much cheaper it is then buying the whole setup from VAP. |
12's?
220 for the 65mm Tb. Side bracket, Iac Braket and intake pipe. And 75 from southfour.
So a little under 300 bucks. And I would definatly go for the bigger Tb its only 20 bucks more than the stock size, and a 65m tb would ushally cost you 200. I Got all the bolts and manifold off, I got a socket instead of using a wrench. And Redpony the nut is stock size, whatever size that is. ![]() It kinda looks like the nut all the way to the left. But I have longtubes so the header is a little differnt
I just got confused..
12's?
Do I use ford's gaskets for the stang? The windstar has these awkward rubber gaskets that make the oem gaskets not very flat
LinkBack to this Thread: http://www.moddedmustangs.com/forums/v6-mustangs/182000-windstar-intake-cleaning-tips.html
| Windstar Intake Cleaning and Tips | This thread | Refback | September 8th, 2010 05:35 PM | |
Threads Similar to: Windstar Intake, Cleaning and Tips
| Windstar tips | Codeman | V6 Mustangs | 12 | May 20th, 2010 11:12 AM |
| Cleaning exhaust tips. | 03_StangGuy | Visual | 10 | April 30th, 2009 02:39 PM |
| rim cleaning tips? | cbrown54 | General Car Care & Detailing | 5 | October 24th, 2008 05:49 PM |
| Any Tips on cleaning up my motor?? | Traidmarx | 5.0 Mustangs | 15 | October 6th, 2008 03:29 PM |
| Tips on Cleaning Wheels | rsk0528 | 99-04 | 24 | March 7th, 2008 09:14 PM |
