2000 Mustang v6
Shop replaced my front brakes and now it stops worse than before...help
I got my front pads and rotors replaced..wagner thermo quiet pads and mid grade rotors, im not sure of the name, they are the smooth kind.
So after its done, I drive the car and it feels worse than before, I almost rear ended a couple of people. It feels like the pedal is spungy The shop says because there is a coating on the pads and rotors and in a few days it will wear off and ill be able to stop better. is this true? what should i do? i have no stopping power |
2000 Mustang v6
also originally, the left side pads were worn down to the medal and the rotors and marks on them and the right side still had meat on them...they didnt say why about that
Drive it a couple of days and just take it easy. Some pads feel different than others so your pedal may feel softer than before, you may have to give it a little more muscle than before to stop the same. If not bring it back and tell them you want better pads.
Poor college student club ![]() |
MM's Database Error
check to make sure you have enough brake fluid too.
Priest of the Car Gods
Could be a coating... did the shop bed the pads in or did they tell you to? If the answer is "neither", that could be the issue.
Spongy pedal can also be due to air in the lines. Do you know if they bled the brakes when they were done? It should've been part of the brake job, but maybe they figured they could get away with not doing it.
O o /¯/______________________ |BLAAAAAAAAAAAAAAAAAAAAAAAAARGH!!! \_\ Buy my Bronco, special deal for MM folks |
MM's Official Drunk
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 0 reviews
+1 to both. Brake fluid/air in the lines was the first thing I thought of when you mentioned the pedal feels spongy.
2002 v6 Mustang
Ya i agree with the others check your fluid and there could be a coating on the the new pads
![]() - Mac 2.5" with 3 " duals - AM Cold Air Intake - Clear Fog Lights - Mach I Chin Spoiler - Mach I Grille Delete - MSD Plug Wires - New Clutch - Window Tint (Future) - Tokico Blues (Cut Springs) |
MM's Official Lucifer
Why I do everything myself.
"Fast she goes...in the city of Overdose" ![]() |
1999 Mustang v6
I went to school to be a mechanic, so I know what I'm talking about most of the time. mods in the garage, slowly getting peppier. 6ershootout.com summer of 2012... Be There |
99 mustang
bleed yo brakes dawg, apparently the shop you took them to is full of idiots. They could have killed you with that shit.. id be pissssed
1997 Thunderbird
14.06 @89.53 needs tuned
Sounds like they didn't use brake cleaner to remove the oil on the rotors which got the oil into your pads and will probably take a month to wear the pads enough to get rid of it. My suggestion is to go out and heat the brakes up.
Alan |
2000 mustang v6
14.6@99.68
I have a thought bout tht, but id ask johnson or the other guys in the forum first....if ur one side is worn more than the othere id say a semi seized calipar (idk how to spell it) or a calipar. Tht the pin and boot is not floating not allowing the calipar to back off....but again id check with they guys who posted in this topic...
comp cams extreme energy cam, ported heads, flowmaster 40 divorced duals, ford tlok, 3.73 gears WANTS smoked head lights, smoked tail lights, fr500 wheels, fog lights. |
99 V6 BASE
NEVER RACED
if you are unhappy and dont feel safe return to shop and let them drive it. brakes are nothing to guess about. tell them it is so bad that you are scared to drive it. that should get the attention of any reputable shop.
1999 Mustang V6
if the brakes that came off were low and the right side were decent, id look into replacing that left caliper, chances are it is hanging up and will ruin your new brakes as well.
2000 Mustang v6
The mechanic said that they didnt have to bleed the brakes bc there would be no air getting into the lines when they changed the brakes...
Should I take it somewhere else today and get them bled? Now I dont know which side was bad, I dont want to wear the pads uneven, Will they know which one is bad and am I going to have to replace the pads again If I need calipers? |
14.37 @ 96
I say give it a few 60-0 stops somewhere safe lol. When I got my rotors turned and new pads on, the braking felt slick as hell. You could hear them just sliding. By the end of the day after playing with them and stopping nice and hard a few time it cleared up.
Shouldnt take much to get them worn in and working right.
FUCKING AWESOME: http://www.youtube.com/watch?feature...&v=Te0V71sGoxA Purple Haze
99 V6 BASE
NEVER RACED
Yes find another mechanic. at minimum he should be concerned. how does he know there wasent a little air in system before he even got the job. a good mechanic would at least test drive after brake job.
If only replacing pads and rotors, calipers wouldn't need to be removed, so no bleeding would be necessary.
Is this still an issue? Any coating would have worn off by now if you've been driving the car.
99 mustang
lolol, ALWAYS bleed your brakes after a brake job.. ALWAYS!
Better than ONLYaUNCfan's
2012@lightspeed
brake flush and cobra brakes
Formerly, AhobosCheese and Cheddars.
Threads Similar to: Shop replaced my front brakes and now it stops worse than before...help
| my brakes are squeeling worse than MSO after a night of getting ZIPPEE'D | v606er | 2005 - 2010 V6 | 12 | October 21st, 2008 08:43 PM |
| Cobra Front Brakes | Lefty | 4V / SVT | 6 | August 24th, 2008 01:35 PM |
| 4cyl>V8 front brakes | Racinjason81 | 5.0 Mustangs | 1 | December 1st, 2007 09:04 PM |
| Brakes (New Front Calipers) | 02stang02 | V6 Mustangs | 2 | September 1st, 2007 03:34 AM |
| Front Brakes HELP! | bbrewer03 | 96-98 | 4 | May 31st, 2007 11:01 PM |
