Motor Question
Old April 21st, 2006, 02:41 PM   #1
95CamaroZ28 is on a distinguished road
Motor Question
Hey i got a question for ay guy.....My brother needs a motor for a 1994 Mustang 3.8. My question is does he have to get a 1994 motor or can it another year? Thanks
Old April 21st, 2006, 02:44 PM   #2
99mustang232's Avatar
1999 Ford Mustang V6
99mustang232 is on a distinguished road
94-98 (these are the single port 3.8's) the motors changed to split port's in 99.
Old April 21st, 2006, 02:53 PM   #3
so the engines from all thos years are the same, like no problems pullin the busted one and dropping a new one?
Old April 21st, 2006, 04:11 PM   #4
AtlanticBlue99's Avatar
14.79 @ 92.15
94-98 is same motor just better cam in 98. he could do a split port swap and get 50 more hp by buying a 99-04 3.8L motor and swaping it in.
ModdedAutos
1999 Mustang V6
Old April 21st, 2006, 04:40 PM   #5
when you say new motor, do you mean the used longblock including upper and lower intakes... there are some differenances between 94-95 and 96-98 with the intake and head bolt lengths and gasket thicknesses... also the 94-95 have an ignition control module under the MAF housing.
Technically it will be a direct swap if you use a 94-95 if your use a 96-98 there will be little changes but not show stopping, if possible try and get the 96-98 w/the wiring harness. If you do swap the motor go ahead and do the head gaskets too, specifically for the 94-95's.
Threads Similar to: Motor Question
motor question Luvdmustang The Clubhouse 12 October 22nd, 2007 12:41 AM
motor question haywood11 5.0 Mustangs 5 August 2nd, 2007 07:43 PM
motor question IWantToGoFast 96-98 6 June 8th, 2007 02:46 PM
MOTOR QUESTION 83five0 5.0 Mustangs 17 April 12th, 2007 02:16 PM
Question About A 302 Motor mustangrebuilder Classic Mustangs 6 October 31st, 2006 08:20 AM
