oil change question
Old April 3rd, 2007, 03:14 AM   #1
juan310's Avatar
juan310 is on a distinguished road
Send a message via AIM to juan310
oil change question
what oil (brand/type/weight) should i go with?
2000 v6 stock 84k miles(live in socal)
Old April 5th, 2007, 02:28 PM   #2
NottyBoy93's Avatar
1993 Notch, 1988 Notch
NottyBoy93 is on a distinguished road
Castrol 10W 30 is good stuff. I have always ran Amsoil full synthetic in my off-road cars but the needs are a little different. Bsically mfg's will usually recommend a 10W 30.
Old April 5th, 2007, 05:48 PM   #3
ujslost's Avatar
5w20 castrol
Old April 5th, 2007, 09:19 PM   #4
96DropTop's Avatar
96DropTop is on a distinguished road
car requires either 5w20 or 5w30... not 10w30. i've always stuck with mobil1 synthetic, i was a tech at on oil change for over 4 years.. all the oil i've been around i'd recommend mobil1! don't forget the mobil1 oil filter...
Old April 6th, 2007, 07:44 AM   #5
NottyBoy93's Avatar
Oil change people must be less informed in Texas. They all use 10W30 almost exclusivley. I use Amsoil full synthetics anyways, not because I am a technician just because.
Old April 8th, 2007, 01:50 PM   #6
2001 Camaro z28
GTblackprodigy is on a distinguished road
Send a message via AIM to GTblackprodigy
my gt is close to 89 k miles..should i stick to 5 20 or move up to 5 30?....oh and i use mobil 1 synthetic
Old April 10th, 2007, 07:52 PM   #7
WAR-PARTY's Avatar
2001 YUGO GT
WAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of light
Just stay with what has been run in it. They’re several different blends of oil. But if you haven't been using a sync don't start now. Pennzoil and Castro, generally Penn. crude are paraffin based oils and you should not change to those either if you haven't been running them. The high mileage stuff is good. 5/30 is good all round.
Old April 19th, 2007, 03:23 PM   #8
juan310's Avatar
well the manual says to use 5w30....but then the haynes repair manual i bought says i can use 10w30 based on my climate since it doesnt get below 32 degrees down here
i just went with mobil1 5w30 full syn and a k&n oil filter....
but does the mileage affect what oil weight to use?
Pioneer Sound System (Comp Speakers-Amp-Deck) - Viper Alarm/Remote Starter
Eibach Pro Kit - Smoked CC Headlights - 18" Bullitt Wheels - SVT Focus Fuel Pump
True Dual Exhaust - Flowmaster Original 40s - 3.5 Rolled/Slanted Tips
Old April 21st, 2007, 11:33 PM   #9
fordzilla21 is on a distinguished road
anybody that runs pennzoil is an r-tard. that is the worst stuff ever. i have taken many valve covers off of pennzoil motors to be covered in sludge on the valves. please dont use. id rather use used trop-artic oil than that. i like motorcraft pure synthetic 10W30. it works.
Old April 24th, 2007, 11:48 PM   #10
Stangzilla's Avatar
Stangzilla is on a distinguished road
Royal Purple..... If your motor is worthy to flow Royal blood...lol..
I have a Mustang mag where they replaced all the oils, motor, trans and rear end with Royal Purple and they gained a constant 8hp gain...
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Old April 25th, 2007, 08:27 AM   #11
ujslost's Avatar
I seen them do that on Horsepower tv also, and gained 8-10 hp.
Old April 25th, 2007, 08:51 PM   #12
Stangzilla's Avatar
Yep cheapest 10 hp you can get
Old April 25th, 2007, 09:06 PM   #13
ujslost's Avatar
I want to put it in the trans and rear, but I cant afford to keep it in the engine
Old April 25th, 2007, 10:06 PM   #14
Stangzilla's Avatar
Yeah but you can go 5-6000 miles between changes if you like.. As long as you use a good filter..
Old April 25th, 2007, 11:27 PM   #15
ujslost's Avatar
Thats just it. I was reading a magazine that we get at our shop. they did a filter test. They were talking about people going over 3,000 miles on oil changes. They were saying that its not that some of the oils cant handle it. Its the oil filter, they cut open hundreds of filters all with differant variables. And I dont believe there was 1 filter in the bunch that worked efficiently past the 3,000 mile mark. I think this is one thing ppl over look is how efficient is the oil filters. People always ask me, how does that oil look. And I give them this how fuckin stupid are you look. Its burnt motor oil how the hell do you think it looks. ITS BLACK! They are always worried their oil cant hold up. When most oils will.
Old April 25th, 2007, 11:34 PM   #16
Stangzilla's Avatar
Well change the filter at 3k then top off the oil.. Simple as that..
Old May 13th, 2007, 07:30 PM   #17
zrez is on a distinguished road
I was told not to use synthetic. Thoughts on this?
Old May 13th, 2007, 07:39 PM   #18
Big timin' in a small town
Drick's Avatar
2004 FX4 F150, 86 GT
why wouldnt you be able to use synthetics
Old May 13th, 2007, 08:53 PM   #19
Stangzilla's Avatar
Did they give you a reason? The only thing I can think of is if you start to use them in older higher mileage motors they have been known to start an oil leak or two but other than that the lubrication properties far surpass regular oil and it does not break down as fast as regular oil.
Old May 13th, 2007, 10:18 PM   #20
ujslost's Avatar
i just started using synthetic in my 97 explorer about a year ago it has 207K on it no problems. Except its a pig for gas!
Threads Similar to: oil change question
SN change please lx302 Feedback Forum 2 October 5th, 2007 03:20 PM
Gear oil Change question?? Cantbeatblack 99-04 3 September 20th, 2007 01:00 PM
oil change pfman Classic Mustangs 11 August 17th, 2007 09:59 AM
Headlight Change Question MustangMo V6 Mustangs 5 October 11th, 2006 10:42 PM
oil change BlackIce V6 Mustangs 8 July 9th, 2006 09:51 PM
