99 3.8 with problem Idle
The car I have is a 1999 Mustang 3.8L. Okay I have had this problem since 30000 miles and the car now has about 115000 miles and nobody can fix it so far. I have noticed that when I drive my car sometimes at idle at a stop light it wants to jump 200-500rpms. This is annoying but not my major concern. The major concern comes from shwne I drive it mostly on the freeway then park it for 15-20 Minutes and come back out and start it up the engine almost wants to stall. This is especially bad when reversing. I also get the rpm surge when I am stuck in traffic for a long time say a wreck on the interstate. I am contemplating buying an ELM5 scanner to help me figure it out. Anyway the things I have done so far is replaced plugs, PCV Valve. Cleaned out throttle body and Idle Air Control. Cleaned MAF Wire very carefully.Checked Throttle Position Setting voltage which was 1.0 a little high. Any ideas on what could cause this and whether I should get the scanner. Thanks all
#3 | ||
yea it was me that made a post the other day .... except my rpms skyrocketed everytime i put the clutch in ..try reseting ur computer that helped mine ..
#5 | ||
i had a verry erratic idle putting fuel system treatment in and resetting my computer with a hand held scanner seems to have completely solved the issue for me. but it would bounce around like crazy at a stop but it was the worse when it first started it almost would stall some times and when i put the peddle down it would just cough and puke i had the exact same symptoms.
Threads Similar to: 99 3.8 with problem Idle
| umm have a weird problem? idle problem? | blue03mach1 | 99-04 | 16 | March 4th, 2008 12:03 PM |
| Idle problem /// Need some help ! | das50cal | 2005 - 2010 | 12 | July 4th, 2007 05:28 PM |
| HELP!!! idle problem ????????? HELP | das50cal | 2005 - 2010 | 1 | June 9th, 2007 08:25 PM |
| Idle Problem | jtlogruss08 | V6 Mustangs | 16 | May 22nd, 2007 04:21 PM |
| need help with idle problem | cooktheworld | 5.0 Mustangs | 2 | August 21st, 2006 09:54 PM |
