Discussing Under drive pulleys in the V6 Mustangs Forum. Alright mine is on its way...is it a simple install...also I hear something ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2000 V6
Under drive pulleys
2000 V6 Mac LT headers, Mac O/R H-pipe, Mac CAI, ASP 25% underdrive crank pulley, SCT tune, and a buncha cosmetic mods |
#2 | |
Location: looking for free hand jobs in poland springs nebraska... silly gooses
nope its not the idle RPM its the amount of turns per minute... the only logical way is to get on over drive pulley for the alternator...
just ... a little lesson i bet you already know this but just reminding you... the under drive is smaller so it turn the whole belt system less times for every time the pulley spin around then the original one does... well since the other pulleys are built for stock when the belt slows down then they don't spin as many times per minute either... thats why you would need an overdrive pulley... i got one for my car and i havne't had a single issue and i am running a more powerful sound system then stock... soo yea
slow car club - crew member 8 of 9
2000 V6
thats the other thing...my sterio is still stock
#4 | ||
Resident MM Ricer
2006 Scion tC
13.9@103/8.9@81
I would go ahead and grab it if you haven't ordered them yet get a kit to be safe Imo
![]() Buy My Guitar and Amp Scion Tc-strup racing header, CAI, Ground Kit, NOS 100shot tuning and install in process, Custom suspension, Doc. I 50% STS "Horsepower sells cars, torque wins races." -Carroll Shelby Thanks To My Sponsors: Strup Performance |
Hmmm, I got a spiffy crank pully AND an alt pulley with my kit......
If your gonna do it, do it right... spend the bucks and get a good setup..... Also, if you EVER plan on doing a SC, you want to keep your factory pulley's... you can't use an underdrive on a SC. |
2000 V6
Thanks guys...as far as a power adder ill either go turbo or nitrous, but I keep all the stock parts anyway...I only got the pulley and the belt ordered though since it was cheaper...looks like adding in an alt pulley will cost what the kit did though...is it an easy install
Modded V6
![]() CAI, dual exhaust, spec stage 1 clutch, P&P heads and intakes, aluminum driveshaft, short shifter, 4.10 gears, auburn posi, SCT tuned |
#9 | |
Moderator
8.876@80.013 1/8th
the easiest way to get the alt pulley is with an impact wrench, and I think it's a size 23 socket. I had undercharging issues when I installed my pullies, and I didn't put the alt pulley on. That fixed it though.
Blue Mustang Society click it
#10 | |
I dont know about that...I hear you can use it...unless your implying that you shouldn't
just a V6 with a bad belt slip under the hood |
#11 | |
you can use it you just need a monster pulley on the super charger... which puts more rotating mass on it and makes it a lil harder to spin... but if the pulley is of high quality on the spuer charger and is big enough you can get back up to 8 psi with a 25% underdrive after a bit of tweaking
#12 | |
Moderator
8.876@80.013 1/8th
Your not suppossed to becuase the supercharger has to do that much more work, just so that it create boost. The pulley quality has nothing to do with how much boost it makes. Quality just makes sure it doesn't mess up on you. You need your accessories running where they are at stock so that your belt spins fast enough for you to create boost that gives you power right off the bat with a supercharger.
2000 V6
I think mods should blend together better...pulley no sc/ LT's no turbo...and if you do its a pain in the ass
Threads Similar to: Under drive pulleys
| Under Drive pulleys, which to buy? | 03_StangGuy | 99-04 | 14 | June 14th, 2007 10:20 AM |
| why to never let your son drive | barksdaleammo | Modular Mustangs | 6 | April 9th, 2007 09:59 AM |
| drive me mad | GENERAL | Pictures | 24 | February 12th, 2007 06:14 PM |
| 7 tooth drive gear or 8 tooth drive gear for my 98 GT manual | Blue98GT | Modular Mustangs | 1 | January 6th, 2007 07:27 PM |
| Is It Bad To Drive With... | 00SoSlow | General Tech | 2 | September 23rd, 2006 01:26 AM |
