2009 Mustang GT Premium
Will Mach 1 exhaust fit?
I wanted to know if a Mach 1 cat-back system would fit on my '99 3.8 Of course I'd need a dual exhaust conversion (H or X pipe). I've heard of people using GT take-offs...are they the same?
Ya they should be, the mach1 should have the same hangers and hpipe/xpipe connections
Yes.................
I have 2004 Mach1 catback exhaust on my 1995 stang
2003 Mustang Mach1 1995 Thunderbird LX 4.6L; 1995 Mustang 4.2L; Eaton MPX Supercharger, 11.61 @ 118mph |
yeah they do...only difference between it and the GT is it has better flowing mufflers...the same on the bullitts
just a V6 with a bad belt slip under the hood |
Pipe size difference?
Another thing I've heard is the difference between pipe sizes. I've heard not to go above 2.5" due to not enough backpressure being put on (I only know so much about engines and exhaust). Right now, I have '99 V6 stock exhaust but with a Flowmaster muffler instead. If I'm not mistaken, the pipes are 2.25".
If I buy the Mach 1 takeoff (which has about 30k miles on it) from my friend, it has 2.5" (3" tips). Will that affect anything? |
Also, what else would be necessary for conversion to dual? Would the system be enough?
the cat back with a hanger bracket for the passenger side muffler along with the tail pipe.... then get a Xpipe from RMPoutlet.com or Hpipe
Modded V6
![]() iTrader: 1 reviews
Take it to a shop and have them fab you up some pipes...it will be a lot cheaper having them make it.
![]() 1999 e46 328i BMW - Daily Driver 2001 SVT Cobra - Project 1995 v6 vert - SOLD 1996 v6 vert - SOLD 1995 v6 vert #2 - SOLD 1995 GT - SOLD 1997 v6 coupe - Parting |
For a conversion to dual you can get a kit that requires welding i believe or for like $50 more you can get an xpipe/hpipe. xpipes sound raspy on 6's (from what i hear)- both give roughly same performance for our 6's. for a upgrade from single to dual you need to get two tip hangers and a passenger side muffler hanger along with the catback system. ya you don't want to have too big of a pipe diameter, 2.5's will work great, any bigger and you will get that backflow unless your engine is pushing out alot more air than stock.
OK like I said b4.......and this is not from what I heard.........get the brackets for the passenger side....get the Xpipe or H....my exhaust is not Raspy like some fucking civic...and Xpipe arent made to sound like Hpipes they are for HP......and just make sure u have good mufflers....i had stock GT ones and sounded alright.....put flowmasters on and its a whole lot better overall.....2.5s will be the biggest you wanna run...the xpipe will be 2.5 but the stock cat back may be slightly smaller...then again its not from a GT so idk if its the same size or slightly bigger but it will not be bigger then 2.5................no welding is involed period.....all you need it a jack...4jack stands....9/16s socket and open wrench...and maybe a 15mm or 5/8 socket like i needed as well for the the midpipe to the manifolds along with an extension to make it easier.....some time and maybe a helping hand....just getting the pipes over the rear is a pain in the ass since the suspension will have to be dropped if its all in one piece(the catback) or u can say F tail pipes like me and put turn downs....sounds better then out the back and screams on the street
Are you saying Xpipes are for hp like they produce a better performance? for a 6 you won't notice it, and everywhere you see where they're discussed they're called raspy imo
Size
One final thing, I swear, lol.
The Flowmaster I bought is a 2.25", will that not work with the 2.5" piping of the Mach 1 system? |
Uhm if you take it to a exhaust shop or you can weld it will work, I'm sure you can get some pipe as a converter or something. I would suggest returning something for the same sizes
#14 | |
#15 | |
Re: Size
#16 | ||
Threads Similar to: Will Mach 1 exhaust fit?
| 04 mach 1 exhaust | armymike63b | 99-04 | 10 | November 7th, 2007 12:02 AM |
| mach 1 exhaust | Blk01ponyGT | 99-04 | 17 | October 12th, 2007 05:34 PM |
| 2004 mach 1 full exhaust system | noob | General Tech | 1 | June 13th, 2007 10:50 PM |
| 2004 mach 1 full exhaust system help?? | noob | 99-04 | 17 | June 2nd, 2007 11:15 PM |
| Recommended exhaust for Mach 1? | darkshadowshaker | General Tech | 4 | June 30th, 2006 08:58 PM |
