Cracked oil pan please help
Old April 5th, 2007, 09:40 PM   #1
99v6stang's Avatar
99v6stang is on a distinguished road
Alright, so i was imstalling headers and my jack tipped over and put a hole in my oil pan.
Where do i buy a new one?
How much does it costs?
Can i install it myself?
Old April 5th, 2007, 09:42 PM   #2
Clayhistorian is on a distinguished road
Owch, I can only offer my condolances
Old April 5th, 2007, 09:45 PM   #3
Tree Fiddy Z
Breakout's Avatar
2006 Nissan 350Z
Breakout is a jewel in the roughBreakout is a jewel in the roughBreakout is a jewel in the rough
Send a message via AIM to Breakout
You most likely can do it yourself...but you'll need a torque wrench along with all the other wrenches/ socket wrenches to finish the job. Definately don't want to strip the threads. I've seen idiots overtighten their drain plug and then they had to replace their oil pan like you. If you have little/no knowlege about cars or repairs...take it to the professionals. It will cost some $$$, but at least if they screw it up...you have some sort of labor warranty to get it taken care of.
Old April 5th, 2007, 09:52 PM   #4
99v6stang's Avatar
How long do you think it would take to install the oil pan? Also the hole is pretty small, could it be welded?? If not, whre would you reccomend to buy a new oil pan?
My car ---- (m112 in progress)
Old April 6th, 2007, 03:05 AM   #5
99v6stang's Avatar
Are there any step by step guides to replacing an oil pan or is it pretty simple?
Old April 6th, 2007, 03:28 PM   #6
stephen has a spectacular aura aboutstephen has a spectacular aura about
The procedure looks complicated.
To get clearance the engine has to be unhooked from the mounts and lifted up as well as one of the cross members needs to be lowered. After there is clearance it's just a matter of removing a lot of small bolts. There is a seal at one end and the rest of the oil pan is sealed with RTV.
As mentioned above torque the oil pan bolts to specs, probably a bit under 10 ft lbs but check to be sure.
I would try to get a good used one.
Old April 6th, 2007, 04:57 PM   #7
99v6stang's Avatar
Yea i actually spoke with a mechanic today, and he gave me some adhesive compound that he said he has used to fix this problem in the past, so i applied it today, and in 24 hours when it is done drying, i will see how it works.
Old April 6th, 2007, 10:11 PM   #8
97TunedMustang's Avatar
97TunedMustang is on a distinguished road
Send a message via AIM to 97TunedMustang
JB Weld ftw
New block with forged internals running 16psi, tuned by Lasota Racing
Too many mods to list...
3.73's and Truetrac Finally Done!
Old April 6th, 2007, 10:32 PM   #9
SPF0percent is on a distinguished road
Send a message via AIM to SPF0percent
if i were you i wouldnt mess with it cuz if u mess ti up ull have to start over all agian...u can take it to any drive in auto place and have it fixed for under $250 most likley and thats running a little high for just a oil pan...my advice take it to a firestone repair center...they will take care of u
-StevO!
Old April 7th, 2007, 03:25 AM   #10
1995 BMW 325i
232stang is on a distinguished road
Send a message via AIM to 232stang
DIY man.
Originally Posted by Cesar2cool
lol i use my car for speed
Old April 7th, 2007, 04:56 AM   #11
¡ʇsnq ɹo uʍop ǝpısdn
Onemanzu's Avatar
diy its not to bad just removing a cross member... ha uhh i personally wouldn't replace one but thats just me
Old April 7th, 2007, 05:35 AM   #12
1995 BMW 325i
get a tubular k member
Old April 7th, 2007, 01:08 PM   #13
Juggalo_X's Avatar
2001 Mustang 232/CBR600
14+@Slow
the pump will be a prick too if i remember correctly when u pull the pan u have to unbolt the pump too i use an elastic to hold the pumps driving shaft in place so u dont have to fumble with it.
Threads Similar to: Cracked oil pan please help
Intake Cracked!!!!!!!!!!!!! 98GreenGT 96-98 193 November 3rd, 2007 03:26 PM
Cracked my block 97stanger V6 Mustangs 61 March 15th, 2007 03:21 PM
Cracked manifold UnthoniJones Modular Mustangs 9 February 3rd, 2007 10:31 AM
cracked intake bdp55 99-04 2 October 21st, 2006 03:11 AM
Cracked Body Kit Ninjawafers! V6 Mustangs 6 September 24th, 2006 02:42 PM
