97 mustang 3.8
Needing help
okay well I'm not sure if I'm posting this in the right area but hey,
so last night i was driving back from a buddies house,and was on the highway and my car started knocking and white smoking and lost all power then died. i cut it off and coasted off the service road,i towed the car home and went to looking around. whats up.. 1.oil all in the intake tube and tb. 2.will crank but wont start. 3. was white smoking and and knocking. let me know what you think it could be. Last edited by 97stangerx; October 9th, 2010 at 03:52 PM. |
99 mustang
sounds like your head gasket went and you started to leak coolant into your engine.
1999 Mustang V6
yea sounds like a head gasket. the knock on the other hand..... more than likely due to the blown head gasket (if in fact is).... not good
Resident badass
Sounds like you blew a heads gasket which caused the leak, then the liquid that got into you engine wont compress, so you bent a rod...
Don't ask how I know that so well... ![]() ![]() ^mine^
![]() 271rwhp N/A V6 ![]() The Name is Danny. I'm a GM Technician. Suck it. |
97 mustang 3.8
so its my head gaskets, and i'm guessing the only way to figure out if i bent a rod is to pull the engine apart right?
1999 Mustang V6
![]() iTrader: 3 reviews
Yep, get to it! It's really not that bad though. Probably around a 6 hour job. Unless of course you did bend a rod, then it's more work and just a better idea to swap a whole engine in since they're so cheap.
Resident badass
I swapped in an 02 engine with 42k.
97 mustang 3.8
If i was going to replace the head gaskets you know of a online manual that will show me how?
99 mustang
no, but you can buy one at any auto parts store for 25$
Threads Similar to: needing help
| Another Newbie Needing Help | Derek | 2005 - 2010 | 13 | July 2nd, 2010 11:09 PM |
| needing a tune up | roast&toastEM | 94-95 | 5 | June 18th, 2010 11:33 PM |
| Needing Some Help with the 3.9 | d3f4c3d | V6 Mustangs | 13 | March 6th, 2009 07:11 PM |
| needing some help on my 87 gt | 87gtmustang | 5.0 Mustangs | 9 | October 26th, 2008 07:11 PM |
| still needing help!!! | jerb43 | 96-98 | 4 | December 21st, 2006 07:03 PM |
