Engine light on!
Old October 20th, 2010, 06:58 PM   #1
papemilio's Avatar
1999 cobra
papemilio is on a distinguished road
Engine light on!
It's has a P1131 trouble code it says its running lean. My car doesn't run good when I press the gas pedal the car shakes and the exhuast makes a poping noise and also doesn't accelerate normal.
Old October 20th, 2010, 07:42 PM   #2
walt1120's Avatar
04 Stang 1.0Gallon V6
14.45 @95.8
walt1120 has a spectacular aura aboutwalt1120 has a spectacular aura about
did you mess with the maf sensor when maybe installing a cai? what did you do recently?
if thats not the problem unplug the negative on your battery for 5mins then put it back.
2004 Bolt on & Cammed 3.9L V6
Old October 20th, 2010, 07:48 PM   #3
papemilio's Avatar
1999 cobra
this started after i got my longtube headers and my pypes high flow cats. It was running worse when the cats were disconnected but when i got the o2 extensions it stopped a little then the light came back on.
Old October 20th, 2010, 08:06 PM   #4
papemilio's Avatar
1999 cobra
Will MIL eliminators help? Even though I got 2 cats?
Old October 20th, 2010, 08:09 PM   #5
walt1120's Avatar
14.45 @95.8
probably, it must be something with your o2 sensors, are they plugged in right?
Old October 20th, 2010, 08:11 PM   #6
2000 Mustang V6
crenfroe45 is on a distinguished road
I had a similar problem once. My catalytic converter had broken...it was pretty annoying. But yeh, I'd suggest unplugging the battery first to see if that fixes the light.
Old October 20th, 2010, 08:12 PM   #7
XXGREGXX's Avatar
2003 3.8L Mustang SIXXER
XXGREGXX has a spectacular aura aboutXXGREGXX has a spectacular aura aboutXXGREGXX has a spectacular aura about
Says you have a SCT tuner, write up Joe (Tricktuners) And tell him everything you have done to your car and he'll hook you up.
I think it's a tune problem. Your car needs the O2 sensors to determine to run a little more lean or rich.
Old October 20th, 2010, 08:14 PM   #8
papemilio's Avatar
1999 cobra
Meineke put them on when I scan the DTC it said at the end (b1, s1). Should I put the two MIL eliminators on the 2 front o2 sensors?
Old October 20th, 2010, 08:18 PM   #9
papemilio's Avatar
1999 cobra
I did call Bama tuning and told them what i did to the car when i put the new tune in the engine light turned off then later it turned back on and the engined feels like its back firing or something like them.
Old October 20th, 2010, 09:23 PM   #10
Resident badass
Mr. Red Pony's Avatar
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
All this is stupid. Ignore it. I got my info mixed. B1 S1 is bank 1 SENSOR 1. That just means the upstream is telling you.
271rwhp N/A V6
Suck it.
Old October 20th, 2010, 09:40 PM   #11
papemilio's Avatar
1999 cobra
I checked my engine light again and this is what it says.. Lack of ho2s-11 switches-sensor indicates lean (b1,s1)... this is exact what my tuner says. What do I have to do to fix this?
Old October 20th, 2010, 09:43 PM   #12
XXGREGXX's Avatar
From what Mr. Red Pony says, you got a gasket problem brochacho.
Check it, or take it to a shop.
Old October 20th, 2010, 09:48 PM   #13
papemilio's Avatar
1999 cobra
Mr red pony did your car run bad when you had a bent rod? When I am accelerating slow the car runs fine and when I press the gas pedal hard it doesnt accelerate fast and it makes a poping noise and the car goes back and forth..I don't know what to do
Old October 20th, 2010, 09:53 PM   #14
Resident badass
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
It ran... kinda fine. But I if THAT is the code, are the headers sealed up tight to the heads? I edited that last post. But I still did miss fire and get lean codes on bank 1. Sorry if I gave you a heart attack..
271rwhp N/A V6
Suck it.
Old October 20th, 2010, 09:58 PM   #15
papemilio's Avatar
1999 cobra
It got them installed like 1 week ago the guy told me to tighten the bolts on the headers after couple hundred miles because the headers shrink after they get hot/cold so many times. But if the headers are loose they should make a noise.
Old October 20th, 2010, 10:00 PM   #16
Resident badass
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
Not always true. I would tighten them just to be sure. I still suggest a compression test.
271rwhp N/A V6
Suck it.
Old October 20th, 2010, 10:03 PM   #17
papemilio's Avatar
1999 cobra
How does loose bolts on the headers make the engine run lean.
Old October 20th, 2010, 10:06 PM   #18
Authorized Vendor
AMChrisRose's Avatar
2007 Mustang GT
AMChrisRose will become famous soon enoughAMChrisRose will become famous soon enough
It sounds to me like a header leak. There really isn't a big tune difference between before and after long tubes. There isn't a big MAF transfer function (the MAF calibration that controls load which controls fueling) change, however a little bit changes top end and very little down low. We've taken that into consideration in your tune, though.
The majority of the tune changes are to let the oxygen sensors know they have been moved farther down stream so that they can expect a delay.
I am betting a gasket leak. This will skew the upstream oxygen sensor reading, the car's fueling will go crazy, and you'll get that lean code.
Chris Rose | AmericanMuscle.com
Toll Free: 866.727.1266 | M-F 9AM-9PM EST | Sat 10AM-4PM EST
Bama Hotline: 888.226.9764 | M-F 9AM-5:30PM EST | Sat 10AM-4PM EST
Need Help? PM AMShaneLesky for immediate assistance!
Old October 20th, 2010, 10:06 PM   #19
Resident badass
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
If is sucks air into the headers, the O2 will think it is lean. Same reason an exhaust leak will make it say it is lean.
271rwhp N/A V6
Suck it.
Old October 20th, 2010, 10:10 PM   #20
papemilio's Avatar
1999 cobra
Alright I will tighten the bolts tomorrow. Is there a specific torque on the bolts or just tighen them as much as I can?
Threads Similar to: Engine light on!
Engine light came on Teamsterjohn V6 Mustangs 3 November 23rd, 2009 06:56 PM
engine light! skuzzy 96-98 16 March 30th, 2009 10:09 PM
engine light 91cobra5.0 5.0 Mustangs 18 July 28th, 2008 08:09 AM
Engine Light?? cohnhead21 2005 - 2010 1 June 23rd, 2008 04:11 PM
Engine Light Need Help 90Stang 2005 - 2010 7 June 7th, 2008 12:26 AM
