Help with clutch cable adjuster
Old October 24th, 2010, 03:01 AM   #1
98SN-95's Avatar
98SN-95 is on a distinguished road
So i just installed a new clutch and flywheel and the steeda adjustable clutch cable, Now am having a problem with the cable i believe, I adjusted the cable at the fork and tighten the two bolts but for some reason have come lose again so my pedal feels all mushy and vibrates. First time it happen i re-tighten the blots and it stopped the mushy/vibrating clutch pedal. Now today it did it again. Can someone please tell me if i did it wrong, the big bolt goes before the fork hole and the small bolt after or both bolts go threw the fork? Put some lock tight on the threads so it does nt come loose again??? I just dnt want to be dealing with this crap again since its starting to rain.
Thanks guys!!!!!!!!!!!!
BBK Intake, BBK Pullys, 8.5MM MSD Wires, Accel Coilpack, Flowmaster 80s Side exit exhaust, Steeda Short Shift Kit, 04 SVT Cobra Wheels 12K H.I.D.s headlights, 10K H.I.D. fog lights
Old October 24th, 2010, 03:07 AM   #2
v6kid's Avatar
1999 Mustang v6
v6kid will become famous soon enough
Did you tighten the front and back bolts against the fork, so that it was tightly wedged in there?
EDIT: I was a little confused
I went to school to be a mechanic, so I know what I'm talking about most of the time.
mods in the garage, slowly getting peppier.
6ershootout.com summer of 2012... Be There
Old October 24th, 2010, 03:27 AM   #3
98SN-95's Avatar
This is how it did it.
Old October 24th, 2010, 02:53 PM   #4
MM's Official Lucifer
goren813's Avatar
'00 3.8L & '05 4.6L
Looks right to me, It's kind of tough to fit a tool in there but you gotta hold the larger one solid and tighten the other one down at the same time... shouldn't be coming loose at all if you've tightened it good.
Are you running the other adjustable components? i.e. firewall, quadrant and pedal adjuster?
Old October 24th, 2010, 03:10 PM   #5
98SN-95's Avatar
I figure it was right but wasn't sure. No I have the firewall adjuste and clutch pedal adjuster but didn't install them just installed the steeda clutch cable. Should i install the firewall and pedal adjuster?
Old October 24th, 2010, 03:11 PM   #6
v6kid's Avatar
1999 Mustang v6
You just make to make sure that the nuts are TIGHT against each other.
Old October 24th, 2010, 03:30 PM   #7
98SN-95's Avatar
Just hard to believe that it would have come lose again cuz I tighten the crap out of them to make sure it wouldn't come lose. Should I used loc tight to prevent it from coming lose in the future? Would the vibrations make the bolts come loose?
Old October 24th, 2010, 03:52 PM   #8
v6kid's Avatar
1999 Mustang v6
As long as they were tight against each other the vibrations should have made it loose. I would say to use loctite if you have to... the problem is that you shouldn't have to.
The way that me and my friend installed his was, I used a pry bar to get the fork arm out of the way while he used 2 wrenches on both nuts. You loosen the big one and tighten the little one, This makes the 2 push towards each other. Ya see what I'm saying?
Old October 24th, 2010, 06:07 PM   #9
98SN-95's Avatar
Yea I do. And that's Exacly wat I did but am nt sure what happen until tomarrow when I get under the car to c wats the deal. Would it b possible that the cable is streaching or something?
Old October 24th, 2010, 08:07 PM   #10
v6kid's Avatar
1999 Mustang v6
I wouldn't think so.
Old October 26th, 2010, 07:51 PM   #11
98SN-95's Avatar
So what i feared was true damn it. the nut started to back up making the clutch loose.
This is how it was when i took the cover off. compare with the first pic i posted and you can see the first one has long treads and this one is shorter.
Old October 26th, 2010, 07:58 PM   #12
98SN-95's Avatar
Also i took this video idk is this normal for the fork to vibrate this much? I think it might have been the reason to have made the nut to come loose nt sure. I put in a billet aluminum flywheel.
Old October 28th, 2010, 09:37 AM   #13
98SN-95's Avatar
Any suggestions? I can't believe it after putting loc tight on the damn treads it has come loose again. I was on my way to work this morning getting off the freeway when the pedal started feeling all mushy again WTF is going on with this freaken cable? Do I need to install the quadrant or what??
Threads Similar to: Help with clutch cable adjuster
Clutch Quadrant, Firewall Adjuster, Height Adjuster Install w/pics Serlin General Tech 10 February 25th, 2012 04:00 PM
Steeda Clutch Adjustment Quadrant, Cable, Firewall Adjuster. fallstar01 Parts 4 August 26th, 2010 01:51 PM
UPR Quad, Clutch Cable, Firewall Adjuster I8ACMRO 99-04 4 January 23rd, 2010 01:20 PM
Quadrant,firewall adjuster, adjustable clutch cable silver99gt 99-04 2 March 10th, 2008 11:21 PM
Clutch Cable And Adjuster Mechanism Help 99stangman V6 Mustangs 6 December 10th, 2007 07:12 PM
