Car won't start: Flashing Theft Light - Forums at Modded Mustangs
post #1 of 11 Old October 26th, 2010, 03:47 AM Thread Starter
Fhernando's Avatar
Question Car won't start: Flashing Theft Light
Today I was just changing the battery terminals for a new ones, and when I put the key to the Ignition ON position the car starts to make a sound in the front-right-fender and when I put the key to the START position it won't start.
Also the 'THEFT' light on the dash just keeps blinking (when the key is in the Ignition position) and it won't stop!
The car was running fine today, and now this happens.
I just Got this 2003-3.8-Silver-Stang and trying to get some Mods.
Fhernando is offline
post #2 of 11 Old October 26th, 2010, 06:08 AM
unplug the neg bat term for 20 minutes, replug it in, see if it works.
If not, this is the pats system (passive anti theft system), your car thinks your trying to steal it. if thats the case i think you have to take it to ford and hope you have 2 keys
clidefr0g is offline
post #3 of 11 Old October 26th, 2010, 11:34 AM
xn1919's Avatar
Send a message via AIM to xn1919 Send a message via Yahoo to xn1919
yup =) i thought mine did that when i tried to access the computer but the battery was just bad does it click??? i dont see how messing with the battery cables would of set it off because once one is disconnected the PATS has no life?? try to jump it
visco
xn1919 is offline
post #4 of 11 Old October 26th, 2010, 12:12 PM
ReedsFX4's Avatar
what do you mean "sound" in the right side fender? Is it a clicking?
2001 Mustang V6- Sold
2014 Focus ST
ReedsFX4 is offline
post #5 of 11 Old October 26th, 2010, 01:17 PM
01 Slate Stang's Avatar
Hey as far as the theft light flashing when u attempt to start just let the car set for around 2 hours. usually if its just a battery change out the pats system will go into theft mode for that reason. If u let it set for a few hours then try to start it should work ( the anti-theft should reset ). Like said above if once u let it set for a few hours and no luck then yes u need to take it to a ford dealership and have 2 keys and it will have to be re-programmed ( thats if ur transiever for the pats didnt bite the big one ). GL
01 Slate Stang is offline
post #6 of 11 Old October 26th, 2010, 04:41 PM Thread Starter
Fhernando's Avatar
Thanks guys, but I solve the problem it was a Ground-Wire that I forget to plug in with the rest of the wires... Thanks anyways.
post #7 of 11 Old October 26th, 2010, 04:46 PM
u know i was gonna say ground, but.. well.. you know
post #8 of 11 Old October 26th, 2010, 04:47 PM
mustang003's Avatar
My theft light started flashing and i couldnt start it at a gas station once. Took out the key, hit the lock button on the clicker, hit unlock, put the key in and started it up. I know you figured your problem out but i figure if anyone else has an issue and they search, this could be helpful to know.
White Mustang Crew Member #10
Originally Posted by 2011GT1979 View Post
Newtons third law states that gay cars can not beat my manly car.
mustang003 is offline
post #9 of 11 Old October 26th, 2010, 04:52 PM Thread Starter
Fhernando's Avatar
Yeah that's right I was online yesterday trying to get anyhelp cuz' I don't wanna pay any mechanic... And somebody mentioned an unplugged wire, that's why I went back to the car and check all the wires around.
post #10 of 11 Old October 26th, 2010, 05:15 PM
wraitherx's Avatar
iTrader: 13 reviews
So your saying that after every battery change or terminal removal that the PATS system is triggered and not allow you to take the car for a couple of hours? Thats also assuming that everything was installed and hooked back up correctly? non pun intended OP.
1999 Ford Mustang SVT Cobra Built
2011 Ford Taurus SHO TT AWD
Originally Posted by Towelie View Post
he spent all the time
thinking about if it could be done, and not thinking about if it should be done
wraitherx is offline
post #11 of 11 Old October 27th, 2010, 12:07 AM
v6kid's Avatar
I doubt that it's PATS. Even if you use a bad key it will at least turnover..
I went to school to be a mechanic, so I know what I'm talking about most of the time.
mods in the garage, slowly getting peppier.
v6kid is offline
Human Verification
