97 Mustang V6
O/D Race.
So earlier in the day. i raced a 98 v6 mustang with my v6 3.8 97 mustang only mod i had is flowmasters straight pipes 40 series. he also only had flowmasters x pipes though 40 series. After we raced i walk up to his driver window and i see he had his O/D off. he screeched his tires and i didnt so i won. just wondering isnt the O/D supposed to be for heavy duty pulling? or does it help that its off when racing? i also know it just gives the car more gas. and a better sound to the flows when cruisin in the street. Any details? Thanx alot.
01' Mustang 3.8L
Overdrive off will suck the gas out of your tank so fast your head will spin.
Needs 2 cylinder bolt on
'03 Mustang V6
It's a six so what do you expect?
TBH, I have no idea what the purpose is for O/D lol!
97 Mustang V6
Lol me either. i just press the button alot when i got a chick in the car. well when im stopped at a light and then put it on when its green lol.
01' Mustang 3.8L
Overdrive is nothing but a higher gear ratio.
BYAHHHH!
2001 Mustang GT
13.874
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
it locks out 4th(overdrive). You use it in a race. You dont want to go WOT in 4th.
![]() Precision Turbo|TurboSmart|TeamZ|Strange|Hellion|BBK|SCT|Edge Converters|Fairbanks|CG Fabrications|Treadstone |
01' Mustang 3.8L
you lose torque, with o/d. Its used to maintain speed with less power.
BYAHHHH!
2001 Mustang GT
13.874
but you also dont want to WOT in 4th. you are movin enough and it builds heat like 5th pulls in a stick
I'm doing it wrong
04 Grand Cherokee
Yea you can get away with turning it off for a 1/4 mile pass at the track, just don't keep it off and go like 70ish? You will build up a bunch of unnecessary heat which leads to part failure, sometimes pretty quick.
To simply put it: 1st-3rd gear race, o/d off late 3rd-4th, keep it on and spare your car lol.
Formerly known as Demon_54 "I feel the same way about disco as I do about herpes." - Hunter S. Thompson
BYAHHHH!
2001 Mustang GT
13.874
4th in the tranny is like 5th in the stick car. strictly for cruising and gas milage
1999 Mustang v6
Taadaa.
and it will keep the toque converter from locking up.
I went to school to be a mechanic, so I know what I'm talking about most of the time. mods in the garage, slowly getting peppier. 6ershootout.com summer of 2012... Be There |
97 Mustang V6
So say like Demone said 1-3 gear o/d off would it be bad to turn it on at that high speed to get into 4th and 5th?
01' Mustang 3.8L
You're going to be better off using it or not. 85mph-95mph for 3 or 4 mins isn't going to burn anything up. Just don't get into a habit of not using it. Capiche?
1999 Mustang v6
Whether or not you use it is solely up to you. It will not make you slower/faster or make you overheat/not overheat.
97 Mustang V6
14.37 @ 96
ohhhhh dear .....
OD is your 4th gear. You turn it off and your car goes into 3rd gear. @70mph turning off O/D will bump you up 500-1000rpm (I think its closer to 500 but i cant remember). If you turn it off, it keeps you from going into 4th gear. If your cruising in a stick, you wouldnt do it in 4th, you would go 5th. So dont turn it off to cruise. If your racing, it may or may not help. Just depends on how fast your going. 1/4 mmm might not hurt to turn off, but chances are you wont hit a high enough speed/rpm for it to shift into O/D. Anything further yeah you should leave it off just a lil to gain a very very small advantage. But like any tranny, you have to shift at some point, so keep an eye on your rpm and turn the O/D back on.... Simple. |
yeah i always wonder that it seems like my car gets off the line quicker... is that all in my head when o/d is off? tloc 4:10
visco |
14.37 @ 96
Unless turning it off controls something else that I dont know, Then yes its in your head.
To my knowledge O/D is only a 4th gear, used for high speeds. |
1999 Mustang v6
Correctomundo
14.37 @ 96
Didnt think it did anything else lol
I learned all this by driving w and w/o it lol who needs a forum :p Like I said, turning it off will keep you in 3rd a lil longer for those higher rpms, but you wouldnt leave it in 1st and race, so remember to turn it back on before you blow your engine, or just leave it alone
Threads Similar to: O/D Race.
| H&R super race springs vs. H&R race springs | gray8188 | 99-04 | 10 | July 17th, 2009 05:36 PM |
| The Race | MustangMo | The Clubhouse | 17 | March 31st, 2008 12:35 AM |
| and the race is on | scubasteve041186 | The Clubhouse | 8 | June 28th, 2007 06:13 PM |
