1996 Mustang 3.8l
Spring Question
with the Eibach 3852.120 Pro-Kit Performance Spring Kit fit a 96 mustang 3.8l coupe?
![]() 96 v6 - needs v8 03 Roush - needs turbo 06 F250 6.0 - needs stepladder |
2004 Mustang V6
When I searched for it on Jeg's it came up with a Camaro/Firebird spring set, so probably, but you shouldn't do it. Just get a kit designed for Mustangs, particularly your six, such as the Eibach 3518.140 Pro-Kit. Here's a link to Jegs, but i think summit racing has them too.
Eibach 3518.140 Eibach Pro-Kit Lowering Springs |
04 Stang 1.0Gallon V6
14.45 @95.8
![]() ![]() iTrader: 2 reviews
OP, know if you have any relatives in NJ?
2004 Bolt on & Cammed 3.9L V6 |
2001 Mustang
Hey i have a quick question as well. I have a 2001 v6 mustang. I might be able to get some stock 03 GT springs for dirt cheap. I would cut these GT springs about a coil or so, and see how the drop is. By my only question is, these will fit fine right?
![]() All Bark, No Bite
Better than ONLYaUNCfan's
2012@lightspeed
They have the same springs. Fords suspension hasn't really change dramatically from 79-04. Cutting a coil is ok heating up the coil "too" much with the friction isnt.
Formerly, AhobosCheese and Cheddars.
![]() Last edited by BlueScreaM; November 4th, 2010 at 12:58 AM. |
#6 | |
2001 Mustang
Whats the best way to cut springs with? Grinder?
99 mustang
grinder with a cut off blade
1996 Mustang 3.8l
if i drop the car 1 and a half inches would i need new shocks? ive looked everywhere for "1.5 in. lowering kit shocks" with no luck
2012@lightspeed
Just get tokico blues I have them and allot of people here do too. They will be fine.
2004 Mustang V6
From what I've learned, you don't NEED new shocks and struts, it's just one of those things that you may as well do while you're putting in the springs. People have also found that the stock shocks and struts can wear out as early as 60,000 miles, though 80,000-100,000 is more reasonable, so you may just want to do it anyways.
Not Banned
you shouldnt use a grinder, it will heat up the spring too much and then it is not as strong.
im sure rev will come in here and explain exactly why. |
#12 | |
Dancing Naked In The Rain
MM's Official Lucifer
+1 on the blues.
and -1 on cutting springs.
#14 | |
01 True Blue v6
to slow to matter
Threads Similar to: Spring Question
| Spring Question | sctravis77 | 5.0 Mustangs | 2 | August 18th, 2009 12:22 PM |
| Spring Question | Mickey | 2005 - 2010 | 36 | August 5th, 2009 09:37 PM |
| Spring question? | JAY'SRED02 | 2005 - 2010 | 9 | September 1st, 2007 01:23 PM |
| spring question - need help | fallstar01 | General Tech | 2 | July 6th, 2006 01:05 PM |
| spring question | reeds98gt | 96-98 | 1 | July 4th, 2006 10:17 PM |
