Sticky Lifter - Page 2
Old November 8th, 2010, 05:18 AM   #21
99 mustang
clidefr0g is an unknown quantity at this point
from 99-04 ford recommended 5w20 and 5w30 for different months of the same year manufactured vehicles and they all have the same engine. you would never have a problem running either of them, but as stated 30 gives more protection and 20 gives more mileage.
And you are correct the manufacturer does recommend things for a reason, that reason; however, is what makes them the most money while still providing a decent product. And if they can advertise a higher MPG than something else, that will make them more money.
*disclaimer* If i tell you something about your car i may be wrong so if your not sure take your car to a mechanic!
Originally Posted by ReverendDexter View Post
Make something idiot-proof, and they'll just make a better idiot.
Old November 8th, 2010, 05:49 PM   #22
Codeman's Avatar
Codeman will become famous soon enoughCodeman will become famous soon enough
OK well I asked my teacher today on the tranny fluid. He said all they did was add 1 quart of automatic transmission fluid to the oil. They then took the car out and got on it as he said. And a lot of times that would clean the varnish off the lifters. HE said you will want to change your oil after you do this.
UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors
Old November 8th, 2010, 10:23 PM   #23
I'm doing it wrong
Rich J's Avatar
04 Grand Cherokee
Rich J is just really niceRich J is just really niceRich J is just really niceRich J is just really nice
So I take it you did it after you spoke with him right? I want to see your results before I do this
Formerly known as Demon_54
"I feel the same way about disco as I do about herpes." - Hunter S. Thompson
Old November 9th, 2010, 04:29 PM   #24
Codeman's Avatar
I did not do it after I spoke with him. Sorry man, I have around 1k left till my next oil change so it will probably be a couple weeks. Sorry man. I will let you know once I do it though.
Old November 9th, 2010, 06:15 PM   #25
9986paulk's Avatar
1999 Mustang V6
9986paulk will become famous soon enough
New cars alspo recommend waiting at least 5k to change oil too. I do it 3k regardless. Sometimes I think they recommend stuff so your engine actually wears out a little faster. But as far as the weight goes, I'd run 5-30 in all of the 3.8s. There's no reason to change it with no real mechanical differences.
And btw, has anyone ever tried to test for a difference in gas mileage with te 5-20 to 5-30? I doubt you'd be abe to tell any legitimate difference
Twin Turbo
Old November 9th, 2010, 10:16 PM   #26
Codeman's Avatar
I doubt there is any difference. I am not at all concerened about running 5 20 in my car. Have been for three years.
Old November 10th, 2010, 08:47 PM   #27
1996 Mustang V6
CRA 8 is on a distinguished road
run 5w-30 royal purple
Old November 10th, 2010, 08:59 PM   #28
Codeman's Avatar
I will never run synthetic, too expensive and a waste of money.
Old November 10th, 2010, 09:05 PM   #29
stephen has a spectacular aura aboutstephen has a spectacular aura about
If it's actually a lifter problem 1qt of ATF with the oil may help.
It could also be a worn rocker arm and the ATF won't help that.
Old November 10th, 2010, 09:29 PM   #30
Codeman's Avatar
That is another possibility. I almost thought it could even be a broken valve spring. My car feels like it is missing. I am not sure if it is because I can't get my final tune yet? Or what?
I guess I will try the ATF first and hopefully that fixes the problem. If not then I will have to pull both valve covers off and take a look. Well if a valve spring is broke, then it gives me an excuse to get a new cam quicker . Because if I have to put a new valve spring in might as well replace them all and throw in a cam
Old July 17th, 2011, 12:35 PM   #31
adryan's Avatar
2003 Mustang V6 Pony Edit
adryan is on a distinguished road
Did you ever get the ATF to work on your sticky lifters? Please update... I think I got the same issue.
Thanks.
Adryan
2003 Mustang V6 Pony Edition | 1968 Mustang RS |1980 Datsun 280 ZX | 1977 Camaro with '85 Intercooler Engine | 1971 Cadillac 472 cu.in. (7.7L) Engine | 1973 Mustang 5.0 Ragtop
Old July 17th, 2011, 01:15 PM   #32
2000 v6 mustang
1slowv6 will become famous soon enough
its not a waste of money, it has a conventional base but much better detergents in it for cleaning your engine and keeping it lubricated longer. ive gone 10k on synthetic before without problems.
i also replace my plugs every oil change.
If Nissan motorsports is Nismo..Wouldn't Honda motorsports be Homo?
Old July 18th, 2011, 02:32 AM   #33
Jetflo's Avatar
2001 3.8L w/ 5spd
Jetflo will become famous soon enough
If you are going for snake oil, I'd do the marvel mystery oil over tranny fluid. It is probably just mineral oil, but it has in past experience done some good for noisy valve parts.
You can use Seafoam to flush the crankcase beforehand, but it really works best in the intake. While you are trying out various oil treatments, it is probably fine to run dinosaur oil.
You'll want to change it within a week or two after any snake oil actually works. There's a reason we don't use a cocktail of additives at every oil change.
Still using Royal Purple 10W30 at 130K miles. It is an early 2001 V6 Mustang. It runs just fine. I remember Ford introducing the 5W oil to get 0.25 MPG fleet average. It was never necessary to use 5W oil unless you live where it gets pretty cold.
It does not get cold here.
Are you absolutely certain you're not pregnant?
Threads Similar to: Sticky Lifter
Got a sticky lifter... ItaliStang V6 Mustangs 8 August 2nd, 2009 01:14 PM
Lifter Tick Chris951 5.0 Mustangs 10 March 11th, 2009 05:47 PM
solid roller lifter vs. hyd flat lifter ... pushrod length? ryans88gt 5.0 Mustangs 5 December 10th, 2008 12:19 AM
Lifter Question 95blackbeauty 5.0 Mustangs 1 June 12th, 2008 07:30 PM
Lifter Tapping... help? Stan27 99-04 11 February 21st, 2007 12:17 AM
