First test drive... kinda wimpy...
Old April 10th, 2007, 01:30 AM   #1
RichM is on a distinguished road
the wife was laughing at me but... ok so I got my 96 v6 engine back together. It runs. It sounds a bit like the exhaust manifold isn't quite bolted up on one side but I wanted to see what was throwing a check engine light. The hood is off, the top is down, the other seats and the carpet are out... So I put a seat back in, bolted in the seat belt, hung a plate on the back, and drove it about 2 miles through the neighborhood to my local Autozone. I didn't really get on it, but it was not very impressive. It's an automatic, and not very responsive. The shifting is very smooth, it rides good, but... I've never driven one of these before. My wife's 106 hp 2007 Toyota Yaris (auto) has more punch. The engine is running a little rough, I don't know why yet... but still... are the stock v6's just really wimpy, especially with an auto?
It showed a P0305, "#5 cylinder misfired." I'll probably take this into a shop after I do the interior and paint.
The only other sports car I have owned was a 92 300zx twin turbo. This car (even though it's got .8 liters on the 300) isn't going to hold a candle to that, is it. ??
Old April 10th, 2007, 01:33 AM   #2
MustanG_guy17's Avatar
2007 Mustang GT/CS
MustanG_guy17 will become famous soon enough
Well with cylinders miss firing of course it is going to be alot slower. BUt yer the stock v6 is a slower motor
2007 Mustang GT/CS 5spd: Flowmaster hushpower axle back,O/R X pipe,JLT CAI,93 Bama tune..laser interceptor dual jammers, Escort Redline RD.
MAVERICKS!!!!!!!!!! BABYYYY.. DALLAS COWBOYS
Old April 10th, 2007, 01:35 AM   #3
¡ʇsnq ɹo uʍop ǝpısdn
Onemanzu's Avatar
that sucks... hope nothing goes to wrong
Old April 10th, 2007, 01:43 AM   #4
Slower is relative though. I had a 91 honda accord, with 245k on it, finally died because apparently I had "no compression in one cylinder, and almost none in two others". Yet, on 3 cylinders, it had more power than this.
It doesn't really sound like it's mis-firing, sounds more like the timing is off (but how can that be on this engine?) and like the exhaust has a hole (it doesn't, but not absolutely certain the header and pipe are bolted together all the way since I didn't do it myself).
I hope it's something easy though. The distributer pack and wires look fairly new, but the injectors did not. I did not grease (electr. grease) the injector plug connectors, and this car does have 160 k on it... maybe I need to do something with them? it'll be a PITA to pull that stuff back off but...
1996 Mustang v6 convertible - under reconstruction...
Old April 10th, 2007, 01:45 AM   #5
2007 Mustang GT/CS
Do yourself a favor and put that car in N and roll it into the atlantic ocean. and buy a 07
Old April 10th, 2007, 01:45 AM   #6
Texan_Stud is on a distinguished road
it will be slow but not that slow.. unless the 91 accord had a H22 in it..
I don't drive fast. I fly slow.
Old April 10th, 2007, 01:47 AM   #7
Onemanzu's Avatar
it is a chain driven unit with a cam shaft positioning sensor and if these components werent installed correctly then the engine could be confussing its self and could cause some damage...
their is a slight chance that timing can get off...
i don't know ... you did all the work yourself right in your garage im guessing...?
Old April 10th, 2007, 02:10 AM   #8
well not exactly. when I got it, there were parts in the trunk, in the back seat, in the door pockets, in boxes, and in plastic bags. The block was in, timing cover still on, but heads and everything above them were off. The wiring harness was off to the side. So I used a haynes, and alldatadiy.com manual (fair diagrams) and common sense to put it back together. I did not have the valves [or heads etc] checked. There was a bit of smoke for the first 20 minutes of running or so, but now there is no smoke, so I think the rings and pistons are ok.
can the plug wires short against each other or various engine parts, if too close? things are kinda tight on the passenger side, they're kinda crammed in there.
Old April 10th, 2007, 01:37 PM   #9
could worn cams be a likely cause of this poor performance, with 160k miles? I haven't looked into upgrading them... I was reading another post about upgrades and that was high on the list of things to do for +hp.
btw the key word was -likely- as I do realize that putting race cams on even a good running v6 would improve performance.
I guess I just don't have any idea how this car is supposed to perform if it's running well. Maybe I should find one for sale and testdrive it...
Old April 10th, 2007, 01:48 PM   #10
HMUSN's Avatar
iTrader: 9 reviews
it's a 96 v6... what did ya expect?
they only make like 130 Rwhp in stock form...
(no offence v6ers)
but they are dogs to begin with let alone when they are missing a cylinder.
that would bring you down to like 104 rwhp
Old April 10th, 2007, 02:08 PM   #11
tomzac is on a distinguished road
(no offence v6ers)
HMUSN, you're an ass.
Did you check cylinder compression yet?
2002 Summer Beater
Old April 10th, 2007, 02:09 PM   #12
Juggalo_X's Avatar
2001 Mustang 232/CBR600
14+@Slow
yah u cant judge a car that isn't even running properly, but yes the 94-98 v6's were obnoxiously slow.
Old April 10th, 2007, 02:15 PM   #13
mustang1072's Avatar
mustang1072 is on a distinguished road
Send a message via AIM to mustang1072 Send a message via MSN to mustang1072
the 96 v6 mustang is not very fast... neither are any mustang v6's for that matter... thats y were here
Originally Posted by Onemanzu
your moms a quicky... ha just playin ... but seriously
Originally Posted by mustanginky View Post
.... felt great in the seat of the pants dept.
2002 Ford Mustang GT
And so it begins... (mods)
Old April 10th, 2007, 02:16 PM   #14
HMUSN's Avatar
iTrader: 9 reviews
like i have never been called an ass before
i'm not being an ass..i am merely just stating the obvious man.
check all your fittings.. you have an exhaust leak somewhere.
did you scrape the old gasket material off the block before you installed the manifolds?
Old April 10th, 2007, 02:19 PM   #15
dont call him an ass tomzac he is right unfortunately... ford came out with a v6 so u can afford it, look good, and get better gas mileage... in my opinion
Old April 10th, 2007, 02:42 PM   #16
It's not what was said, it's how it was said. The little LMO figure at the slow v6; is neither objective, nor constructive to resolve a problem.
2002 Summer Beater
Old April 10th, 2007, 02:46 PM   #17
HMUSN's Avatar
iTrader: 9 reviews
"but still... are the stock v6's just really wimpy, especially with an auto? "
i answered his question AND i followed up in a second post to offer some assistance
"did you scrape the old gasket material off the block before you installed the manifolds?"
and i wasn't laughing at the fact that it was v6 I was laughing at the fact that if it were missing a cylinder it would only have 104 RWPH.
Old April 10th, 2007, 03:12 PM   #18
Back on topic:
Did you do any head work? If so, are you sure the rockers are set and operating the valves correctly? And with 160K miles, a professional injector inspect, clean, and flow check might be a good idea. Also check your coil pack. And double check for vac leaks.
2002 Summer Beater
Old April 10th, 2007, 03:34 PM   #19
2000 V6
ByPopularDemand is on a distinguished road
Send a message via AIM to ByPopularDemand Send a message via MSN to ByPopularDemand
I don't think they make 130 to the wheels...
2000 V6 vert
Mac LT headers, Mac O/R H-pipe, Mac CAI, ASP 25% underdrive pulley(r.i.p), SCT tune, 8.8 rear and 4.10 gears.
Old April 10th, 2007, 03:34 PM   #20
Juggalo_X's Avatar
14+@Slow
Originally Posted by tomzac
Back on topic:
also check your wires make sure htey are not grounding out from cracks or wear. plugs are they good? are you sure u dont have a warped head? an exhaust leak off the block will cripple performance so get that header checked.
Threads Similar to: First test drive... kinda wimpy...
Test Drive Unlimited 232stang The Clubhouse 19 December 17th, 2007 10:51 PM
Part 2 of '03 Cobra Test Drive... LeadFoot_GT The Clubhouse 9 July 23rd, 2007 03:50 AM
'03 Cobra Test Drive... LeadFoot_GT The Clubhouse 19 July 21st, 2007 08:55 PM
Take A Test Drive - Get A Shirt & Hat orangeRcode The Clubhouse 3 October 25th, 2006 01:09 PM
2003 Cobra test drive AtlanticBlue99 Multimedia 10 June 13th, 2006 12:11 PM
