1 Wheel Peel
2000 Mustang 393w
2001 Mustang GT Vert
4.10 gears
I tried using search bar but won't input 4.10s
Quick question. What is the top speed for a 2000 mustang v6 with 4.10s... I know it ca depend on mods but I want a rough estimate.. My car barely got to 100 and it seems really low ![]() edit: Automatic
![]() 2000 393w Swapped Vert 2001 GT Vert 2002 Six Banger |
[8MINUS2]
tire size.
1 Wheel Peel
2000 Mustang 393w
[8MINUS2]
stock redline in 4th takes you to 140
Dancing Naked In The Rain
With 4.10 gears? I hit redline (5250RPM) in 4th at just over 90mph or so (don't know the exact number, I rarely get the car going that fast).
#6 | |
1 Wheel Peel
2000 Mustang 393w
With 4.10's, 285/35/18 rear tires, 5250 rpm in THIRD gear (auto) will be 98.44 MPH. Don't got WOT in OD.
285mm/25.4 = 11.22" tire section width (11.22" x .35 x 2) + 18 = 25.85" tire diameter 25.85" x 3.14 = 81.18" tire circumference (81.18"/63360) x (5250/4.10) x 60 = 98.44 MPH
Rod @ AzzKicker Cars 2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's. ![]() 1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC. ![]() 1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch |
#8 | |
[8MINUS2]
Yep 1st)34 2nd)63 3rd)98 4th)139
It's not easy being green!
2001 mustang
3.76@306
barely 100??? wtf? why do people say up to 120 though?
2001 V6 vert....mostly stock but she's my beauty. ![]() TOPLESS MUSTANG CLUB |
What people? To reach 120 MPH with 4.10's and a 25.8" tall rear tire in your 1:1 gear (third gear in an auto), you'll need to spin the engine to 6400 rpm.
Rod @ AzzKicker Cars 2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's. ![]() 1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC. ![]() 1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch Last edited by Tang Stang; November 10th, 2010 at 01:32 PM. |
2001 mustang
3.76@306
yes i know my car is slow. what would my top be? not that i would go that fast but i have looked all over the internet and people say top is near like 118 before your speed limiter kicks in.
What gears and what rear tire size? Manual or automatic transmission?
'00 V6 Procharged Mustang
In a manual with stock tire size and gearing hitting the speed limiter was no problem stock.
2000 Prochaged V6. T-lok, Mach 1 takeoff exhaust with H-pipe, 20% tint, OEM fogs and all HIDs. SAE Corrected: 289HP/298TQ at 5100RPM(Pegged MAF). |
2002 Nitrous Injected V6
12's?
with 4.10's cold air, catback and tuner My car maxed out at 140 via gps spedo. I love my 4.10s but if you want to keep the mpg of a 6r I would go 3.73s. If Mpg dosnt matter go with 4.10s
![]() Project Red Magic -Full Intake, Full Exhuast,Geared, Tune, Sprayed, Dropped- -18 Inch Hypercoated Saleens wrapped in Nittos- |
#15 | |
2001 mustang
3.76@306
p.s. it's an automatic
I don't know the stock tire size or gear ratio for a V6 Mustang. I'd guess 225/55R16 and 3.27's. If that's right, then your top speed in third gear at 5250 rpm would be 123 MPH. That's if the factory speed limiter is either set higher than that (doubtful) or if it's been removed with a tune.
2001 mustang
3.76@306
i heard it was 118 when the speed limiter kicked in but with a tuner i heard i could hit 125. with gears t-lok and tuner higher...maybe
12's?
If you do get gears it would be unwise of you not to get a tuner while your at it, and this would take off the speed limiter. If you planning on being more concerned about top speed then acceleration then ditch the gears.
2001 mustang
3.76@306
no i was just curious. with the money i have spent on my 2 guitars and lessons i could've gone turbo. but its whatever......
I would not be that concerned about top speed. Unless you are able to go 98 mph or faster in the 1/4 mile then you don't have to worry. That is a way to build a car. By hp and how fast you will go at the end of the 1/4 mile. Then you can get the correct gear and tire size to get your car to top out by the end of the 1/4 mile in 3rd gear.
![]() UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors |
Threads Similar to: 4.10 gears
| Speedo after gears. Where to buy gears and speedo fix... | justinsstang | V6 Mustangs | 9 | September 15th, 2010 02:57 PM |
| speedo gears for 4.30 gears | bcinthearmy | 94-95 | 2 | April 23rd, 2009 12:02 AM |
| 3.73 gears or 4.10 gears? I need to get away from the 3.31's | 07torchgt | 2005 - 2010 | 91 | November 11th, 2007 12:25 AM |
