miss w/ fuel running out tailpipe
LinkBack (1) Thread Tools
Old November 10th, 2010, 10:24 PM   1 links from elsewhere to this Post. Click to view. #1
89stang302gt's Avatar
1989 Mustang gt
89stang302gt is on a distinguished road
I'm working on my wires 94 3.8. It has horrible miss (code P0302) and has fuel running out tailpipe and leaves a large white cloud of smoke behind. I've changed plugs, wires, and coil pack. Ive pulled the fuel rails and checked for leaking injectors , done compression test (between 155 and 165), checked for fuel in vacuum line to regulator. Checked fuel pressure its 32 when ruining but when you just turn the key it goes to 40 and then to 0 within a second. I'm not sure what to try next.
Old November 10th, 2010, 10:32 PM   #2
'00 V6 Procharged Mustang
mp4 player has a spectacular aura aboutmp4 player has a spectacular aura about
Start pulling then replacing plug wires one by one while running and see if you can isolate it down to a specific cylinder.
2000 Prochaged V6. T-lok, Mach 1 takeoff exhaust with H-pipe, 20% tint, OEM fogs and all HIDs.
SAE Corrected: 289HP/298TQ at 5100RPM(Pegged MAF).
Old November 11th, 2010, 03:26 AM   #3
v6kid's Avatar
1999 Mustang v6
v6kid will become famous soon enough
Pull the plugs one by one and see how much the the rpm drops with each cyl. The one that doesn't really make a diff is your bad cyl. White coming out of your exhaust would be coolant, are you sure it's gas coming out of the exhaust?
I went to school to be a mechanic, so I know what I'm talking about most of the time.
mods in the garage, slowly getting peppier.
6ershootout.com summer of 2012... Be There
Old November 11th, 2010, 04:57 AM   #4
99 mustang
clidefr0g is an unknown quantity at this point
if theres no spark the gas would just drain out into his exhaust. but im not sure how it would get past the muffler unless u filled it up
*disclaimer* If i tell you something about your car i may be wrong so if your not sure take your car to a mechanic!
Originally Posted by ReverendDexter View Post
Make something idiot-proof, and they'll just make a better idiot.
Old November 11th, 2010, 08:36 AM   #5
1989 Mustang gt
I pulled plug wires one at a time and I couldn't really notice a difference. The car smells really strong of fuel when running and the fluid running out the tail pipe is very flammable (I tested it) And smells of fuel.
Old November 11th, 2010, 01:40 PM   #6
rfcsoulja's Avatar
01 True Blue v6
to slow to matter
rfcsoulja will become famous soon enough
You may wanna check and make sure you didn't get any fuel in your oil. It definitely sounds spark related.
My supercharged v6
http://www.youtube.com/watch?v=1lNkgKBw0bw
Old November 11th, 2010, 01:56 PM   #7
v6kid's Avatar
1999 Mustang v6
Ok I got less lazy. p0302 is cyl 2 misfire. I guess it sounds like you have a spark problem, make sure you are getting spark to the plug, and pull the plug to see how it looks/ measure the gap.
Old November 11th, 2010, 02:08 PM   #8
stephen has a spectacular aura aboutstephen has a spectacular aura about
The fuel pressure dropping rapidly to zero is not right. That plus code P0302 and gas coming out the exhaust is consistent with a major leak in the #2 injector. I would replace that injector.
Old November 11th, 2010, 02:29 PM   #9
v6kid's Avatar
1999 Mustang v6
Nice one, I didn't even think about that.
Old November 13th, 2010, 08:22 PM   #10
1989 Mustang gt
I borrowed an injector pulsing tool from a buddy and he said that the fuel pressure should drop between 5 and 8 psi for 1 pulse. So I removed the upper intake and clamped the return line and unplugged all the injectors and turned the key on to build the pressure. It got to 36lbs and when I pulsed each injector individually and they all had a drop of between 10 and 12. Cylinders one thru three were all at 12 and four thru six were 10-11. Are they all bad??
Old November 13th, 2010, 09:16 PM   #11
BlueScreaM's Avatar
Better than ONLYaUNCfan's
2012@lightspeed
BlueScreaM has a spectacular aura aboutBlueScreaM has a spectacular aura about
Rig it with some spark plugs or something similar and have flames coming out
Formerly, AhobosCheese and Cheddars.
Old November 14th, 2010, 05:55 PM   #12
1989 Mustang gt
I clamped the return and with the gauge hooked up the pressure dropped 12lbs in an hour and half just sitting. The mechanic I borrowed the pulsing tool from said none of that would concern him. He said he would be looking at the computer. Any other ideas out there??
Old November 17th, 2010, 10:00 AM   #13
1989 Mustang gt
Well I've given up on it for now. Put the car in storage for the winter. Maybe It'll magically fix itself over winter! LOL
LinkBack to this Thread: http://www.moddedmustangs.com/forums/v6-mustangs/191610-miss-w-fuel-running-out-tailpipe.html
Thread miss w/ fuel running out tailpipe | Forums at Modded Mustangs | BoardReader This thread Refback July 10th, 2011 09:27 AM
Threads Similar to: miss w/ fuel running out tailpipe
fuel injection miss keiken 96-98 3 January 14th, 2010 06:01 PM
running bad...small miss GT87Stang 5.0 Mustangs 4 September 13th, 2008 09:09 AM
Tailpipe ? 01VBmustang V6 Mustangs 3 July 14th, 2008 11:41 PM
How much fuel pressure should I be running? demononwheels 5.0 Mustangs 1 August 7th, 2006 01:56 PM
