T-lok and 4.10's
Old November 12th, 2010, 09:05 AM   #1
craigdavey's Avatar
craigdavey is on a distinguished road
T-lok and 4.10's
I have done some searching on here but couldnt find a real answer to my question. But approximately how much does it cost to get a t-lok and 4.10's in a 7.5 rear end if i have a shop do it? I know a shop is going to charge me more than if i would get my own parts from AM but can you guys give me some insight in to how much i need to save up to get my gears and t-lok put in.
2004 3.9L Vert (sold)
Old November 12th, 2010, 09:20 AM   #2
Formerly 01silversixer
SlowSix's Avatar
2001 V6
15.47@89.57
SlowSix has a spectacular aura aboutSlowSix has a spectacular aura aboutSlowSix has a spectacular aura about
like $300-400 probably
Old November 12th, 2010, 09:34 AM   #3
craigdavey's Avatar
Is that installation and parts or just the install?
Old November 12th, 2010, 11:07 AM   #4
04Sixxer's Avatar
2004 'Stang v6
04Sixxer is on a distinguished road
Thats just install. Plus another 400 or so for the LSD and the gears
Divorced Duals with Thrush Welded Mufflers
93 Octane BAMA Race Tune
Stack Racing Air Intake
Kicker Comp 12" Sub/JL Audio Amp
6000K 55W HID's
Originally Posted by Cathedral View Post
Then I'd get Zach Galifuckunucks to play me in a movie.
Old November 12th, 2010, 12:31 PM   #5
SlowSix's Avatar
2001 V6
15.47@89.57
+1
I've decided I'm just gonna find an 8.8 with some gears in it and do the swap myself.
Old November 12th, 2010, 02:22 PM   #6
mustangmike!'s Avatar
2004,1994,1967
14.37 @ 96
mustangmike! is a jewel in the roughmustangmike! is a jewel in the roughmustangmike! is a jewel in the rough
yeah usually is the better way to go.
8.8 will be stronger, and will have a tlok already in it. Maybe a little harder to find one with 4.10 gears though. So if you get one and buy gears for it, you need the Motive bearing kit, and it wouldnt hurt to get the disk pack to rebuild the tlok.
Only thing is the 8.8 is heavier ... but you have many more options for parts w/ 8.8.
Check craigslist.com I see them all the time on there
227whp N/A V6
Now w/ 8th Mile 8s !
How To Jmod Your Late Model 4R70W
Old November 12th, 2010, 03:35 PM   #7
craigdavey's Avatar
Heavier is actually what i am looking for in the rear end. I live in ohio and winter is coming so i know not having use of both back wheels is gonna hurt on the snow and ice. Hopefully i can get something done before the bulk of the snow hits.
Thanks for the input guys.
Old November 12th, 2010, 04:18 PM   #8
1 Wheel Peel
GreenMustang00's Avatar
2000 Mustang 393w
2001 Mustang GT Vert
GreenMustang00 has a spectacular aura aboutGreenMustang00 has a spectacular aura aboutGreenMustang00 has a spectacular aura about
How much more does a 8.8 weigh? Can't be too much?
And also IMO you should keep the 400 and built a compressor tank and an air impact gun.. Then you can install yourself with no problems
2000 393w Swapped Vert
2001 GT Vert
2002 Six Banger
Old November 12th, 2010, 05:51 PM   #9
9986paulk's Avatar
1999 Mustang V6
9986paulk will become famous soon enough
You can be out the door for ~$600. I have a 7.5 rear with new axle seals, t-lok, motive 3.73s, and bearing professionally installed. I'm considering selling it to get an 8.8 or swap out the t-lok for a tru-trac to handle more power.
Twin Turbo
Old November 12th, 2010, 06:43 PM   #10
Codeman's Avatar
Codeman will become famous soon enoughCodeman will become famous soon enough
the whole 8.8 being stronger is bogus. Well unless you do something to the 8.8. They have the same axles, and same tlok basically. Just a little bigger. The tlok is the weak point, the clutches burn up.
If you want a strong rearend then you are going to want a detroit unit or a spool those are your two options.
Sure it is easier to just swap in a 8.8 and it will have a tlok that will handle what most ppl throw at it, but you still have to install the 3.73s which will cost just as much as installing the tlok and stuff.
Just my 2 cents.
And yes you can do the tlok and gears at home. The biggest pain is getting all the measurements otherwise they will make noise. You will need time and a good dial indicator and magnetic base to get it done correctly.
UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors
Old November 12th, 2010, 06:55 PM   #11
SlowSix's Avatar
2001 V6
15.47@89.57
^ agreed. You can install gears and a tlok yourself, but good luck getting it to not whine.
Old November 12th, 2010, 07:15 PM   #12
BlueScreaM's Avatar
Better than ONLYaUNCfan's
2012@lightspeed
BlueScreaM has a spectacular aura aboutBlueScreaM has a spectacular aura about
gears: 169.99
Tlok: FFRP 219.99/ detriot trutrac 500
Rebuild kit: 74.99
labor: 250-300
total: 714.97 (with FFRP and 250 labor)
Just use the 7.5
Formerly, AhobosCheese and Cheddars.
Old November 12th, 2010, 07:22 PM   #13
1 Wheel Peel
2000 Mustang 393w
Or go buy a new 8.8 for 300 bucks... Cheaper some places!
Theres one for sale (with 3.73s) around my area for 200 so just look around.
2001 GT Vert
2002 Six Banger
Old November 12th, 2010, 08:51 PM   #14
BlueScreaM's Avatar
2012@lightspeed
True, you could skip the tlok but its still like 600+ with labor added. I would do it to but i have the gears and no one here sells 8.8 in my area.
Old November 12th, 2010, 08:59 PM   #15
1 Wheel Peel
2000 Mustang 393w
True^^ can be hard to find a great deal but if he buys one he wont have to pay labor either. Saving a good 300-400 bucks
2001 GT Vert
2002 Six Banger
Old November 12th, 2010, 09:06 PM   #16
sc55509's Avatar
2011 V6
13ish@105 mph
sc55509 is on a distinguished road
Mine cost 142 for the gears, 70 for the install kit and 200 I just called around till I got a good install quote, my first quote was 500, it just depends what you can find.
C&L cold air intake
SCT X3 tuner
Ford Racing 3.73's
Flowmasters
BBK Lontubes
BBK O/R x pipe
UMI LCA's
Old November 12th, 2010, 09:18 PM   #17
Codeman's Avatar
You are lucky though you already have an 8.8 in the 11' mustang with a tlok.
And I guess if you can find an 8.8 with gears it is a great deal. I just had searched for a year or so and no luck so decided to go with the 7.5. And you can find tru tracs for like 340 i believe.
Oh and BTW I did my gears myself. The first time I did it I had gear whine due to having my dial indicator setup poorly. I drove it for a week and took it apart and redid the whole thing and now I have no gear whine. I also have access to all the tools I would ever need AKA my 15,000 worth of snap on tools sitting at my college.
Old November 12th, 2010, 09:22 PM   #18
sc55509's Avatar
2011 V6
13ish@105 mph
Thats badass I wish I could have done mine, but I do not have near the amount of tools I need lol
C&L cold air intake
SCT X3 tuner
Ford Racing 3.73's
Flowmasters
BBK Lontubes
BBK O/R x pipe
UMI LCA's
Old November 12th, 2010, 09:25 PM   #19
Codeman's Avatar
It is actually kind of difficult and scary the first time. But honestly if you have a dial indicator and a hoist along with a good 1/2 inch impact then it is simple. But doing it at home is pretty difficult. If I were to do it over again I would have waited till I could do it in school and use a hoist.
Old November 12th, 2010, 09:33 PM   #20
1 Wheel Peel
2000 Mustang 393w
lol i did it with two 18 inch jack stands and no dial indicator... Whines a little but Im not too worried about it since im planning on a 8.8 soon
2001 GT Vert
2002 Six Banger
Threads Similar to: T-lok and 4.10's
T lok 4;10's and a tuner mk1993 V6 Mustangs 9 October 29th, 2010 10:39 AM
T-lok OHHitsKB 2005 - 2010 V6 16 August 15th, 2010 02:43 PM
4.10's and T-Lok Installed... FINALLY RFM 40th V6 V6 Mustangs 29 December 17th, 2009 12:38 PM
anyone need a t-lok? tigerfan2771 V6 Mustangs 24 April 15th, 2008 08:39 PM
T-Lok gkizzle3622 V6 Mustangs 14 September 4th, 2007 10:19 AM
