Bad noise
Old November 12th, 2010, 08:29 PM   #1
04Sixxer's Avatar
2004 'Stang v6
04Sixxer is on a distinguished road
Bad noise
Whenever i turn, i hear a sort of clunking noise. Its hard to explain but i guess if anything it sounds like two pieces of metal clanging together? Any one know what this could be and if its a big problem or not?
Thanks
Divorced Duals with Thrush Welded Mufflers
93 Octane BAMA Race Tune
Stack Racing Air Intake
Kicker Comp 12" Sub/JL Audio Amp
6000K 55W HID's
Originally Posted by Cathedral View Post
Then I'd get Zach Galifuckunucks to play me in a movie.
Old November 12th, 2010, 08:44 PM   #2
BlueScreaM's Avatar
Better than ONLYaUNCfan's
2012@lightspeed
BlueScreaM has a spectacular aura aboutBlueScreaM has a spectacular aura about
sounds like ball joints to me.
Formerly, AhobosCheese and Cheddars.
Old November 12th, 2010, 08:50 PM   #3
04Sixxer's Avatar
2004 'Stang v6
Is it something i should worry about?
6000K 55W HID's
Old November 12th, 2010, 10:05 PM   #4
MM's Official Lucifer
goren813's Avatar
'00 3.8L & '05 4.6L
Yead, I'd replace them. Easy to DIY, not too pricey either. If you're lowered or plan on being so I'd recommend Steeda x2 balljoints. If not, OEM replacement will be fine. The press to remove your old ones can be rented at auto parts stores.
Old November 12th, 2010, 10:57 PM   #5
04Sixxer's Avatar
2004 'Stang v6
Thanks but honestly whats probably easy to DIY for you is probably kinda hard for me lol i looked at install instructions on americanmuscle for the x2 joints and it looks pretty rough
6000K 55W HID's
Old November 13th, 2010, 06:40 PM   #6
goren813's Avatar
'00 3.8L & '05 4.6L
If you feel that way go get estimates at shops. Basically it's getting your wheel off .. which I hope you can do... and removing the brake assembly and spindle to get to the ball joint..again just simple removal, then the press is self explanatory and do the reverse to install.
In my opinion, if you care to learn about the car and want to be able to do thigs yourself, this is a good repair to start with.
Old November 13th, 2010, 08:09 PM   #7
04Sixxer's Avatar
2004 'Stang v6
Youre right, cant hurt to try. I just need to get some jack stands
6000K 55W HID's
Old November 13th, 2010, 09:21 PM   #8
BlueScreaM's Avatar
2012@lightspeed
Also get a hydraulic jack because it will be easier and a torque wrench for the calipers 23 lbs for the caliper 85lbs for the bracket.
Old November 13th, 2010, 09:39 PM   #9
bigjohnstud4200's Avatar
2000 GT 'vert
bigjohnstud4200 has a spectacular aura aboutbigjohnstud4200 has a spectacular aura aboutbigjohnstud4200 has a spectacular aura about
definitely get them fixed as soon as possbile. If that ball joint comes out when you are driving, you're likely going to fuck up your fender and possibly the rim to start.
"...but don't say my car's topless, say the titties is out"
Nas
Originally Posted by thrashersonmomma09 View Post
( member as in person not as in cock although i do love cock)
Old November 15th, 2010, 12:39 PM   #10
craigdavey's Avatar
craigdavey is on a distinguished road
My wife's car sounded exactly like that and it was the ball joints.
2004 3.9L Vert (sold)
Threads Similar to: Bad noise
Bad noise when stoping mantis3567 99-04 8 October 26th, 2010 08:09 PM
Bad starter noise 87notch&98vert 5.0 Mustangs 0 October 8th, 2010 12:52 PM
bad ticking noise 01 RED GT 99-04 11 January 10th, 2009 09:18 AM
Bad Bearing Noise MustangMatt96GT Videos 5 June 6th, 2008 12:44 PM
bad noise... 01GT 99-04 8 July 9th, 2007 08:26 PM
