Custom cai.
Old November 13th, 2010, 06:56 PM   #1
99 BLUE V6's Avatar
99 V6 BASE
NEVER RACED THIS ONE
99 BLUE V6 has a spectacular aura about99 BLUE V6 has a spectacular aura about
Custom cai.
I want to do somthing different with my CAI. I would like to know how far or close should the MAF be to TB? Does the air temp sender need to be behind MAF?
Old November 13th, 2010, 07:04 PM   #2
mustangmike!'s Avatar
2004,1994,1967
14.37 @ 96
mustangmike! is a jewel in the roughmustangmike! is a jewel in the roughmustangmike! is a jewel in the rough
windstar
lol
227whp N/A V6
Now w/ 8th Mile 8s !
How To Jmod Your Late Model 4R70W
Old November 13th, 2010, 07:15 PM   #3
99 BLUE V6's Avatar
99 V6 BASE
windstar
lol
does that mean you dont know. lol lol
Old November 13th, 2010, 07:24 PM   #4
2004,1994,1967
14.37 @ 96
yepp sure as hell does
lOl
227whp N/A V6
Old November 13th, 2010, 10:49 PM   #5
Codeman's Avatar
Codeman will become famous soon enoughCodeman will become famous soon enough
Hmm... What are you thinking for as far as how your going to make your new one? I mean how close are you thinking of having the MAF sensor? As far as distance, as long as it is not right next to the TB I am almost 99 percent sure that it does not matter.
UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors
Old November 14th, 2010, 02:26 AM   #6
99 BLUE V6's Avatar
99 V6 BASE
thinking of giong straight into front grill, with a custom radaitor of corse.
Old November 14th, 2010, 02:44 AM   #7
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to all
Make the entire front grill the opening for the intake
Hi, You can call me Kyle
Random ESG fact: Had a prochamber on his v6 before it was popular.
WTB: v6 BBK valve covers
Old November 14th, 2010, 03:07 AM   #8
rfcsoulja's Avatar
01 True Blue v6
to slow to matter
rfcsoulja will become famous soon enough
Kind of like the Camaro's (pre 2010)?
My supercharged v6
http://www.youtube.com/watch?v=1lNkgKBw0bw
Old November 14th, 2010, 05:47 AM   #9
99 BLUE V6's Avatar
99 V6 BASE
maybe not entire opening, but yea like the camaro. how close can you get to MAF to TB
Old November 14th, 2010, 05:59 AM   #10
I'm doing it wrong
Rich J's Avatar
04 Grand Cherokee
Rich J is just really niceRich J is just really niceRich J is just really niceRich J is just really nice
I like the idea actually, would look better if it was one or two turbos sticking out there though
But question, why are you asking how close the MAF can be to the TB? If your custom making it just keep the MAF in the same place and just add the piping w/ filter to the grille area. So you don't have to extend the MAF plug wires or anything, keep it simple. Just my opinion though.
Formerly known as Demon_54
"I feel the same way about disco as I do about herpes." - Hunter S. Thompson
Old November 14th, 2010, 06:48 AM   #11
99 BLUE V6's Avatar
99 V6 BASE
Well its going to be a little closer going straight off windstar.wires will be redone regardless.want to box it in something like this.only in grill pic1
Old November 14th, 2010, 11:13 AM   #12
Trick Tuners's Avatar
KB'd GT
You will need custom tuning if you do anything crazy. The maf is super sensitive to very small changes in the intake path. You do not want to expose the maf to direct air off the front of the car because the car will run way rich, unless you can get the maf far enough back so that it doesn't see turbulence. You don't really want to change the location of the maf without tuning because the ecu knows how far the maf is and how long the air takes to get into the cylinders. You also dont want to have maf too close to the throttle body.
Old November 14th, 2010, 08:18 PM   #13
99 BLUE V6's Avatar
99 V6 BASE
I understand what your saying about direct air off front, i can do some sort of defuser or something around filter. not trying to do a ram effect. i want to do this strickly for show but still be functional for D Driving.my car has a air temp sender does it need to be behind MAF? just trying to gather some info for now.
Old November 14th, 2010, 09:15 PM   #14
KB'd GT
The air temp sensor just needs to measure the incoming air temp. t doesn't really matter where it is in relation to the maf. Just be sure to check the tune before you blow the engine due to a lean mixture and a funky intake.
Old November 14th, 2010, 09:17 PM   #15
Codeman's Avatar
I like the 572 BB that looks nasty
Old November 15th, 2010, 03:06 AM   #16
99 BLUE V6's Avatar
99 V6 BASE
Thanks for your help. I'm surrounded by plenty of good tuners in my aera i'll go speak to a few of them.
Old November 15th, 2010, 10:44 AM   #17
BlueScreaM's Avatar
Better than ONLYaUNCfan's
2012@lightspeed
BlueScreaM has a spectacular aura aboutBlueScreaM has a spectacular aura about
my old homebrew intake i had the MAF upside down about 5 inches i want to say from the throttle, and it was held inplace by silicone lol. So i think it would work for that setup.
Formerly, AhobosCheese and Cheddars.
Old November 15th, 2010, 11:13 AM   #18
walt1120's Avatar
04 Stang 1.0Gallon V6
14.45 @95.8
walt1120 has a spectacular aura aboutwalt1120 has a spectacular aura about
why not just run the maf in between the filter and the TB maybe like 8 inches away from each. i dont think it matter as long as its right next to the tb, you just want it to get an accurate measure of incoming air.
and i actually thought about doing this if i ever got a windstar upper because i think it looks good as hell when you have a straight intake pipe like that and also no curves or bend to hinder airflow.
2004 Bolt on & Cammed 3.9L V6
Old November 15th, 2010, 11:55 AM   #19
99 BLUE V6's Avatar
99 V6 BASE
Yea been kicking this around for a while too. Plus, still got a little bit of a hood issue so its not going to be a straight shot.
Old November 15th, 2010, 01:49 PM   #20
walt1120's Avatar
14.45 @95.8
yeah maybe if you got a pipe that kind of went from a round shape and flattened out be like maybe 6 inches wide but maybe only 1 inch high, then put on a flat looking filter
something looking like this but closer to the grille and without the little plate underneath
Threads Similar to: Custom cai.
worth taking off BBK CAI and buying steeda CAI? slater 2005 - 2010 12 September 21st, 2010 05:25 PM
Extra noise? Headers, CAI, Custom Tune MyGG 2005 - 2010 7 August 26th, 2010 03:44 PM
K&N CAI vs. Trick Flow CAI jake1191 99-04 26 May 24th, 2010 01:12 PM
Ford Racing CAI vs. JLT CAI luvmyGT 2005 - 2010 18 November 17th, 2009 01:37 PM
Custom CAI 232stang V6 Mustangs 20 November 13th, 2006 10:36 AM
