Couple questions
Old November 13th, 2010, 10:09 PM   #1
Codeman's Avatar
Codeman will become famous soon enoughCodeman will become famous soon enough
Couple questions
Ok I have a couple questions on Wideband air fuel gauges.
I am looking to ask for one for christmas. I looked at the LC-1 on Ebay which is a pretty good looking guage. Are there any guages that you would recommend? I want one that works easily to datalog with the XCal 3.
Next question is how does it work if you have dual exhaust. I mean I have tru duals so won't I only weld in the sendor for the gauge in one side of the exhaust? Is this ok?
Finally, I want to get a gauge pod for the gague. I have seen some that look like they hold one gauge on the steering column. I can't seem to find them online, anyone know where I could get one? I already have a dual gauge pod that mounts to my a pillar.
UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors
Old November 13th, 2010, 10:46 PM   #2
Codeman's Avatar
I found the gauge pod that I was looking for at LMR. But I am still curious on the other two things.
Old November 13th, 2010, 11:00 PM   #3
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
Hit up Joe at trick tuners.
He sells wind bands and gauges.
It is just fine if you have dual exhaust. The wide band is only hooked up to one side.
Old November 13th, 2010, 11:07 PM   #4
Codeman's Avatar
Ok, I was not sure on the dual exhaust. I didn't know if I need some special one since I have two pipes. But I gues that makes sense.
Old November 13th, 2010, 11:09 PM   #5
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
Yea, you don't even mess with your up and down stream sensors when installing a wideband. I weld a new bung hole.
Old November 13th, 2010, 11:15 PM   #6
Codeman's Avatar
Ok where should I weld in the new bung? Like location wise in the pipe? Is it before cats, between cats, after cats?
Old November 14th, 2010, 12:07 AM   #7
Resident badass
Mr. Red Pony's Avatar
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
On the exhaust
271rwhp N/A V6
Suck it.
Old November 14th, 2010, 05:29 PM   #8
Codeman's Avatar
I figured in the exhaust. I just didn't know if it mattered location. Well hopefully when I get one it comes with instructions telling where to weld in the bung.
Old November 14th, 2010, 06:08 PM   #9
Codeman's Avatar
Ok well I was looking at Wideband guages.
I am a little confused. What do I need to be able to hook it up for tuning as a PID? Like I found this Innovate Wideband DB BLUE Gauge Kit with LC-1 3795 NEW: eBay Motors (item 380287949427 end time Nov-17-10 13:18:57 PST)
Will this work if I get a cord to have it hooked in as a PID? I have found this same gauge for around 160 on ebay new with free shipping, that is why I am curious.
Old November 14th, 2010, 06:31 PM   #10
JTs03v6's Avatar
2003 mustang
7.48x1.56=11.67
JTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura about
I'm running the innovative lc-1 summit brand wb. I have it mounted inside the rear o2 spot since they have beened turned off via tune.
And for only reading one bank at a time thats fine. If the side is off much you will throw a code like bank1 rick or lean etc.
New combo: Forged SC short Block,280cfm heads, Precision 6262 turbo, cx 31x12x3 fmic
http://photobucket.com/JTsTurboBuild
http://youtube.com/user/JTsStang
Old November 14th, 2010, 07:39 PM   #11
Codeman's Avatar
Ok thanks man. And that willl make the installation much easier since my rear 02s are shut off. Thank you JT reps.
Old November 14th, 2010, 09:27 PM   #12
9986paulk's Avatar
1999 Mustang V6
9986paulk will become famous soon enough
You have to get firewire from any computer store and splice a wideband wire into it. In case you didn't know. It's pretty easy.
Twin Turbo
Old November 14th, 2010, 09:35 PM   #13
Codeman's Avatar
Ok. I think I saw that on TT about how to add a input.
Old November 22nd, 2010, 06:42 PM   #14
Codeman's Avatar
Is this a good wideband to get? AEM 6-in-1 Gauge-Type Wideband UEGO Controller - JEGS
I am just curious because I like the looks of it more. Will it work easily to datalog with my Xcal3?
Threads Similar to: Couple questions
a couple questions 707Stang Classic Mustangs 3 September 25th, 2009 07:34 PM
just a couple questions Mustang RacR94 4V / SVT 6 August 2nd, 2008 07:17 PM
couple questions hanscomb88 5.0 Mustangs 5 June 26th, 2008 09:42 PM
couple questions hanscomb88 5.0 Mustangs 1 June 26th, 2008 09:26 PM
Just A Couple Questions Youngin The Clubhouse 44 November 13th, 2007 02:11 AM
