I'm doing it wrong
04 Grand Cherokee
Well my suspisions ended up being right.
So I guess I beat on the stang a little too hard this weekend. Have an obvious "clap" coming from drivers side valve cover. Speeds up while I lightly press the accelerator too. Im not one to pull an engine apart so what do you guys suggest. I AM trying to keep this as cheap as possible. So any other tests I can do besides the obvious I can hear it clear as day? And for once it isn't my paranoia
Formerly known as Demon_54 "I feel the same way about disco as I do about herpes." - Hunter S. Thompson
1 Wheel Peel
2000 Mustang 393w
2001 Mustang GT Vert
Uh oh. sticky lifter????????
![]() 2000 393w Swapped Vert 2001 GT Vert 2002 Six Banger |
1999 Mustang v6
Dooo ittt.
I went to school to be a mechanic, so I know what I'm talking about most of the time. mods in the garage, slowly getting peppier. 6ershootout.com summer of 2012... Be There |
I'm doing it wrong
04 Grand Cherokee
Do what? Get a v8 and drop it in? I want to actually, but funds are NOT there atm. Idk if its a sticky lifter or a rod knocking. FML is all I can say.
[8MINUS2]
video?
It is hard to tell.
Try canceling spark plugs on that side and see if it goes away? That would be the easiest. Otherwise we need a video. Or some more info?
![]() UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors |
2003 Mustang GT
14.16 @99.03
Could be a lifter or it could be loose and the rocker arm could be hitting.
Military Crew - United States Navy - Second Class Petty Officer My 2v build - MMR 1000 rotating assembly, Stage 3 heads/cams, 76mm turbo. Shooting for 700+rwhp. Last edited by silver03gt; November 14th, 2010 at 05:38 PM. |
2000 Mustang V6
dang that sucks but a video would help us to help with your problem
2000 full duel flowmaster 40 series with H pipe, roush stage 2 kit, 18'' ruff racing rims, k and n intake, sequential tails, and more
1 Wheel Peel
2000 Mustang 393w
Well if it is a lifter or rocker arm... minus well do a cam !!
#10 | |
I'm doing it wrong
04 Grand Cherokee
Will try to get a vid tomorrow for you guys, I am suppose to work a double tomorrow. I was messing with it earlier, just sitting in my driveway idleing, very slightly hit the gas and it got faster but at 1.5k rpm my exhaust drowned the sound out idk if it helps but coolant color is fine, oil color is fine, no exhaust leak. Pulled out my stethoscope and its coming from the drivers side valve cover from the middle of the cover towards the front of the car, so its very noticeable with the steth on half of the valve cover.
Threads Similar to: Well my suspisions ended up being right.
| Rear ended AGAIN | Punisher1982 | 2005 - 2010 | 21 | May 27th, 2010 05:02 PM |
| Rear ended... | acpeanut73 | 2005 - 2010 | 14 | December 28th, 2009 07:03 PM |
| Almost Ended bad! | Blown2000GT | The Clubhouse | 34 | July 19th, 2009 03:02 PM |
| This is the x pipe i ended up with | Jobra | 99-04 | 31 | March 22nd, 2009 07:38 PM |
| Rear Ended! | 6DXR | V6 Mustangs | 43 | June 21st, 2008 10:23 PM |
