cooling system problem
Old November 14th, 2010, 04:44 PM   #1
1995 Mustang
clc11688 is on a distinguished road
About 2 weeks after buying my 95 mustang (not gt) everything on it was fine then suddenly i was driving it on the interstate and BOOM!!! I pulled off at the next exit and discovered that my top radiator hose blew out. I replaced it and put new coolant in it. the car still acted up and i ended up replacing the thermostat. car was running fine then yesterday it started acting up and when i popped the hood the hose i replaced was sucked flat and after prying the radiator cap off it went back to normal and there was almost no water in it. there is no water in the oil and no smoke out the exhaust so i ruled out cracked heads but im not sure what it could be. before the hose blew i had no problems out of the car at all.
Old November 14th, 2010, 05:03 PM   #2
1999cobra92's Avatar
1999 mustang cobra
1999cobra92 will become famous soon enough
Did you make sure you filled up the entire coolant system with antifreeze because it sounds like you filled up the resovoir and took off. Your suposed to let the engine bleed out all the air before actually driving the car
Black and White Crew
Crew Member # 5
Check garage for mods and pics
if you Los Angeles and want to ride send me a text (323) 270-6827
0% Wheel hop, 0% broken parts, 100% wheel spin
Old November 14th, 2010, 07:20 PM   #3
2000 Mustang V6
Bigg_Nate is on a distinguished road
fill the radiator with water put the top on run the car for about 20 minutes or untill it gets to operating temperature and then with the car still running pop the radiator cap off (be careful it will be hot) and then top the water off in the radiator than fill your resovoir. Then you will be ready to drive
2000 full duel flowmaster 40 series with H pipe, roush stage 2 kit, 18'' ruff racing rims, k and n intake, sequential tails, and more
Old November 15th, 2010, 08:24 PM   #4
1995 Mustang
Im not an idiot i filled up the entire coolant system and made sure all the air was out. and when i first discovered that the hose was sucked flat there was no water in the radiator but the resovior was full
Old November 15th, 2010, 08:25 PM   #5
cale2006's Avatar
2006 Mustang GT
cale2006 has a spectacular aura aboutcale2006 has a spectacular aura aboutcale2006 has a spectacular aura about
water pump
Originally Posted by 07 Boss View Post
Why not? I think getting stroked and blown is the way to go. Those are my plans.
MM Military Crew
SSgt USAF / DIA, NGA
gamer tag carjax06
Threads Similar to: cooling system problem
cooling system problem(need help) rob madison 4V / SVT 8 October 11th, 2010 01:24 PM
Draining the cooling system 07 Boss 2005 - 2010 12 January 22nd, 2010 02:08 AM
cooling system? competition orange 99-04 8 March 26th, 2009 08:28 AM
Problem With Cooling System Baby96 All Other Vehicles 7 January 11th, 2008 10:44 AM
07 cooling system upgarde dumps 2005 - 2010 2 May 29th, 2007 10:03 PM
