home made turbo?
well i've come to the realization that i want to throw a little boost on this sixer, but i dont want to spring for the cheapest kit TMA has. I figure i can make my own kit with about 1,000 dollars.
the only things i can think of at the moment to run low levels of boost (less than 10 definately) on a stock engine safely are... Turbo (ebay/junkyard) Intercooler (ebay) Wastegate (if turbo doesnt have internal one) piping BOV vacuum lines oil/steel braid lines bigger injectors new fuel pump? colder spark plugs a diablosport/sct tuner 1) what else do i need? 2) Whats the safest psi i can run? 3) anything else i forgot/comments? |
#2 | ||
Re: home made turbo?
yeah i would say not to go over 7 psi specially if your gonna be running it stock
how much hp/tq can i expect from 4-5 psi?
MM's Resident Ricer
2006 Scion tC
13.001@113
255-280ish
#6 | |
I don't drive fast. I fly slow.
how much hp/tp can a stock block take?
#9 | ||
ok, because i figure this is cheap power quickly...and then build the bottom end later, after that i'll get a bigger turbo.
#11 | ||
no such thing as cheap power quickly. Especially if your going to be doing it 100% correct and not cutting corners. It will cost more than you think, that what I mean.
#12 | ||
MM's Resident Ricer
2006 Scion tC
13.001@113
yeah you won't put to much power to our blocks don't even worry about that. The 3.8 can take all you throw at it.
#14 | ||
how would i run the stock exhaust manifolds into the turbo? switch driver and passenger side ones? would that work? then weld the ends into a section to meet into the inlet in the turbo?
shit good luck on this one...if u get it done and it works real good i would let people know that u can ddo it and make some money off of it!! start a little business goin..know what im sayin? but good luck w/ it man!
Engine Mods: slp loudmouth catback exhaust, pacesetter h-pipe, k & n cold air intake, jet chip Body and Interior Mods: Saleen front bumber, 18" chrome saleen rims, GT rear bumper and drop zone 2" lowering springs |
http://cheapturbo.stores.yahoo.net/index.html
You can find some nice sized turbos for a under 700 their. You don't need anything like a blowzilla. |
I hope u know your welding and fabbing...also tuning on a turbo isnt like getting a tuner for a stock car....you have to worry about the air/fuel...possible boost spikes which you will go from 6 to 14 for example....also fuel managment system would be best....if u run 5 psi you'll get bored of it and want more.....a quality intercooler will be needed so you dont lose to much boost also the sizing...unless ur making a intercooler yourself...also external wastegate, boost controller, and turbo timer especially to keep the oil flowing before the car is completely shut down....do it rite the 1st time...or learn the hard way....it can be done with 1000...but remember theres always a want for more...
just a V6 with a bad belt slip under the hood |
#19 | |||||
Zoolander
04 Cobra #2260/3768 1/820
I don't recommend junkyard turbos since a lot of times they are in absolutely horrible condition Ebay screwed me over, by not sending the turbo I bought at all Why would you even buy a turbo thats too small for your car? Your not helping yourself out. |
running a T4 is enough I would think....if not go with a turbo off a diesel truck...thats fairly used....either way you buy cheap stuff u get cheap stuff....a good BOV alone is gona cost about 200 or so...cheap ebay shit breaks from to much pressure...spearco intercooler
....TiaL wastegate...Greddy turbo timer and boost controller....you'll be doing good then...walbro 255 fuel pump...some good injectors size'd right a turbo cam....along with a muffler that will help with the turbo maybe a Dynomax Turbo muffler....or sun w/e just need something less restrictive other then open down pipe or a glass pack
Threads Similar to: home made turbo?
| Home made Subs | Blackblurr_00GT | 99-04 | 1 | July 8th, 2007 02:30 AM |
| HOME MADE CAI | BLACJAC | 2005 - 2010 | 4 | April 2nd, 2007 07:27 PM |
| parts for home made RAM AIR(What do i need) | SlvrStang | V6 Mustangs | 17 | January 13th, 2007 01:25 PM |
| So My Bro Is Home And I Took His Car Out (03 GT) | 00SoSlow | The Clubhouse | 4 | September 23rd, 2006 01:06 AM |
| anybody home? | artisan00 | V6 Mustangs | 48 | February 12th, 2006 10:51 AM |
