Brakes aren't fully disengaging after front pad install
Old November 16th, 2010, 01:00 PM   #1
mooses is on a distinguished road
Hey guys, I put on a pair of Hawk ceramic pads in the front this past weekend, and I've noticed that the brakes aren't fully disengaging now. I can tell because I'm not rolling back on slight inclines that I know I normally roll on and the rotors are hot as fire after driving. There has also been some smell coming from the brakes after driving on them even if I don't use the brakes that much.
I had the rotors turned and I did the proper break-in procedure... Apparently I must've messed something up because it is definitely both sides that are sticking.
What are the odds that both calipers are sticking? Any ideas?
Old November 16th, 2010, 01:41 PM   #2
craigdavey's Avatar
craigdavey is on a distinguished road
This may sound minute, but check to make sure that your brake fluid resavoir is completely tight. Also make sure that you didnt accidentally nick one of the brake lines.
The odds that both calipers are sticking is very small. But that is a possibility too.
2004 3.9L Vert (sold)
Old November 16th, 2010, 02:06 PM   #3
Moderator
03SonicBoom's Avatar
2003 Grand Cherokee
03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of
First I would check to make sure the brake reservoir isn't completely full. There should be some air. If you changed your pads, when you pushed the piston back it pushes fluid back into the reservoir.
The other option is that you cracked the caliper pistons when pushing them back to make room for the new pads. If you did it on one, you could easily do it on both.
Old November 16th, 2010, 02:08 PM   #4
Do you mean the cap to fluid reservoir or the actual container itself being loose? I'll check on it.
I'll check on the brake lines, but wouldn't it be easy to spot brake fluid if they were nicked?
Thanks for the suggestions
Old November 16th, 2010, 02:14 PM   #5
craigdavey's Avatar
Yes i mean the cap to the reservoir. You might see brake fluid depending on how big of a crack is in the lines.
Definately check for what 03SonicBoom says above too. If you cracked the pistons, then you will need all new calipers on the front.
Old November 16th, 2010, 02:35 PM   #6
Ah, I sure hope not. What would be a common reason for a cracked piston? I used one of those caliper piston tools that pushes the pistons back in. I did it really slowly since I read it could cause the fluid to overflow from the reservoir if it was done too quickly. Is it common to crack a piston when using that tool?
Old November 16th, 2010, 02:52 PM   #7
craigdavey's Avatar
It's not common unless you drive it back further than it is supposed to go. But it is possible.
Old November 16th, 2010, 03:00 PM   #8
Moderator
2003 Grand Cherokee
Not real common but still possible. Just pull the wheel and caliper off and it should be evident if that's the case.
Old November 16th, 2010, 07:14 PM   #9
00MUSTANG89's Avatar
00MUSTANG89 is on a distinguished road
also check your slides to make sure the move freely most common problem with breaks
I'd enjoy masturbating on her
Originally Posted by Nightmare69 View Post
When people tell me my car a slow POS I say...your right,I just got smoked by a homeless dude on a 10 speed this morning.
Old November 16th, 2010, 10:04 PM   #10
v6kid's Avatar
1999 Mustang v6
v6kid will become famous soon enough
Yes yes yes... The first thing to be checked. Did you lube everything when you did the brake job??
I went to school to be a mechanic, so I know what I'm talking about most of the time.
mods in the garage, slowly getting peppier.
6ershootout.com summer of 2012... Be There
Threads Similar to: Brakes aren't fully disengaging after front pad install
Clutch not Disengaging koessl 96-98 9 May 8th, 2010 08:51 PM
Brake Pad Install - Brake Grease? mcqueen V6 Mustangs 7 April 6th, 2010 05:45 PM
Clutch not fully disengaging? Fox2102 2005 - 2010 V6 12 October 28th, 2009 02:22 PM
Front pads install : the 'spring' left the pad :( registo 2005 - 2010 2 June 30th, 2009 06:19 PM
Rear brake pad install problem 2006greyGT 2005 - 2010 6 January 13th, 2008 04:17 AM
