Engine swaps
Old November 17th, 2010, 02:29 PM   #1
BlueScreaM's Avatar
Better than ONLYaUNCfan's
2012@lightspeed
BlueScreaM has a spectacular aura aboutBlueScreaM has a spectacular aura about
Engine swaps
In light of everyone asking about engine swaps im going to break it down as what needs to be replaced and what can swap over. Will need a tuner as well. I feel we need a thread explaining it to people.
The difference between the GT and v6
-Engine
-ECU
-Radiator
-Fog lights
-8.8 lsd
-Rims
-Rear sway bar
-Transmission
-Leather seats
-Speedometer (up to 160 mph)
-Exhaust
Transmission:
1. Auto:The 4R70W should handle enough tq for a swap just need to swap the torque converter.The transmission in the GT is a 4R75W is an upgraded 4R70w and was used in the 03-04 mach 1 and GT's. It has a greater torque capacity (generalized).
2. Manual: TREMEC T-5, is the manual transmission for v6 and GT till 2000, TR-3650: for 01-04 GT's, T-56 for 03-04 terminators all can be used for the swap. Since the engine is out swap the clutch while your at it.
Engine: The engine that have been swapped are the 4.6 SOHC, 4.6 DOHC, 5.4 SOHC, and 5.4 DOHC. Though other engines can be used its good to match the year model with year model.
Note: The 5.4 will need the 4.6 intake manifold to fit into the engine as the 5.4 sits higher. A radiator out of a GT should work for all the engines. The 4.6 and 5.4 SOHC are practically identical and can swap parts around mostly 4.6 to 5.4 parts.
ECU (engine control unit): It and the wiring harnesses will need to be swap for the conversion. Swap out of a mustang gt or whatever car you pulled the engine from match the engine to the ECU is the easiest. The gage cluster will need to be swapped.
Exhaust: The exhaust needs to be cut because a 5.4 sits closer two the firewall. The headers will need to be swapped because people have had problems making them fit. An H pipe will be needed for the swap with the exhaust for all of them will need to be cut to fit if it isn't the 4.6.
8.8 rear (v8) and 7.5 (v6): Look a "look here before asking about mods" sticky
Suspension: Is relatively the same except the GT has a rear sway bar.
Brakes: Are the same like suspension.
If theres anything i got wrong or left out like i feel i did please let me know and i will change is and give credit to you . I'm tired so im just going to post it but it might be a mistake lol.
Reference: Mustang Engine Swap - Installing a 5.4L Motor in a New Edge - 5.0 Mustang & Super Fords Magazine
Formerly, AhobosCheese and Cheddars.
Old November 17th, 2010, 02:37 PM   #2
The best 2003 Mustang
She's fast.
ONLYaUNCfan is infamous around these partsONLYaUNCfan is infamous around these parts
Thanks +1
When doing an engine swap, what should been done first? Like should the actual engine be the last things placed in? The way some people talk, the stock items on a v6 can handle it as long as you don't go "crazy", with crazy ranging in difference.
Should the 8.8 rear be intalled first?
Old November 17th, 2010, 02:45 PM   #3
BlueScreaM's Avatar
2012@lightspeed
Define crazy?
The 7.5 can be used since a stock engine wont be enough to brake it. Were talking 300hp tops to the wheels. Its up to you in the long run.
Threads Similar to: Engine swaps
question for those good with engine swaps. imagitterdun V6 Mustangs 8 October 15th, 2010 07:43 PM
Engine swaps justinsstang Modular Mustangs 1 February 19th, 2008 08:35 PM
Engine Swaps = Waste! Dansby The Clubhouse 21 January 2nd, 2008 05:09 PM
Engine Swaps RoushRacing99 99-04 6 July 19th, 2007 10:58 AM
engine swaps stang fanatic General Tech 15 June 1st, 2006 12:03 AM
