2001 Mustang V6
Just did rear end w 3.73 gears
Geez I wish I would have done this first. Just got my car back from blue oval performance in vancouver, wa. did a great job.
Mods: BBK CAI, BBK 65mm TB, BBK UDP, Diablo Tune, True Dual (2) CATS removed, FM 40's, 8.8 rear end, 3.73 gears, Lower Just Purchased: Windstar Upper Intake |
14.37 @ 96
stick or auto ??
3.73s in my auto sure made a difference I love em
2001 Mustang V6
Stick.
I'm doing the wheels and rims next month. then save up for the SC install in June. I'm doing the 18x9, 18x10 as well..
2001 Mustang V6
Long day didnt see the rest of the post... Ya, I am really impressed with the 3.73's.
14.37 @ 96
I just not sure you shoulda went w/ them if your going SC, but thats a common argument i think either 3.55 or 3.73 im sure they'll be fine though.
what kind of SC ? |
2001 Mustang V6
Ya the performance place that does our work is very knowledgeable felt 3.73's were the best since its a daily driver. Thinking about a procharger? not sure yet.
3.73s will work well for a DD procharged car. Actually for a procharger you want like 4.10s even. But if it is a DD i would stick with 3.73s. The procharger your not making your horsepower till higher RPMs so you want to get there as fast as possible.
![]() UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors |
14.37 @ 96
just seems it would suck up your final gear to fast w/ FI
2001 Mustang V6
Thanks guys, I will keep ya posted for sure. I am hearing that we can get as much a 340hp with stock internals. what you think? I have 89,000 miles on the car..
1999 Mustang V6
![]() iTrader: 3 reviews
I don't think people realize how gear ratios work...they always worry about top end with gears. If you can get these cars to do 5500 rpm in final gear (I believe they are a .68 OD? Very close to the same final ratio for autos...) you will be going about 160+ with 3.73s and 150+ with 4.10s. Just an FYI.
And to answer your question...approaching 100k I would keep it around 350 and that should be safe with good tuning.
Twin Turbo |
2001 Mustang V6
And to answer your question...approaching 100k I would keep it around 350 and that should be safe with good tuning.[/QUOTE]
Hey thanks, I am going run the sc on this motor till we start the build on the new one in in Sept. I have heard hp numbers from 325-340 or 350.
2010 GT Sterling Grey
12.97 @ 107.34
pleaseeee me easy on them! lol gears take time to break in...
there is a full list of things NOT to do after install!!! lol i didn't follow the rules after a bad install and i blew out my rear end......
[SIGPIC][/SIGPIC] |Some fun new stuff...| |
2001 Mustang V6
thanks for the heads up! I was getting on it a little and a buddy said " bro, knock it off"..haha
14.37 @ 96
I didnt run them as hard as possible, but when I got my 3.73s in, I didnt wait that 500 miles. I think I drove 1 mile before I got on it a lil. Not WOT (keep in mind its an auto, no reving and dropping the clutch:p)
Anyways, mines all good. That was a good 3k miles ago or more. probably 6k |
12.97 @ 107.34
some people are lucky and get away with it...but having that break in period is a MUST! it will keep your gears from breaking down the road! I think around 500miles you can finally open it up
#16 | |
Dancing Naked In The Rain
4.10s rule
01 True Blue v6
to slow to matter
You want to go with a low gear if you have a turbo since you would want to stay in boost longer. With a supercharger you want a little steeper gear since you build boost as your rpms increase and you usually don't make peak boost until high in your rpms.
Mind me asking how much BlueOval charged for the install?
2001 Mustang V6
I will have to look for ya. They did a bunch of stuff for me at the same time they did the swap.
2001 Mustang V6
the charge 100 per hour and it took 4hrs to tear apart and rebuild the 8.8 and install the gears.
Threads Similar to: Just did rear end w 3.73 gears
| rear end gears | depressoiscool | 96-98 | 2 | August 13th, 2010 12:34 PM |
| Rear end gears | HOLLYWD69 | 2005 - 2010 | 31 | June 6th, 2009 01:32 AM |
| rear end gears | theyanks904 | V6 Mustangs | 11 | February 19th, 2008 08:53 AM |
| gears and rear end | Killer_Bee | V6 Mustangs | 3 | October 5th, 2007 01:03 PM |
| rear end Gears ? | theyanks904 | V6 Mustangs | 17 | June 21st, 2007 01:00 AM |
