Stubborn Head Bolt
so....i have all head bolts off except one.....and no matter WHAT i do to it.....it wont freaking break loose....how can i break it loose?
#2 | |
Re: Stubborn Head Bolt
#3 | |||
I used a 3/4" drive breaker bar and about a 4' length of pipe. Be very sure you have the right size socket. On the 99 it was a 15 mm socket as I recall, anyway it's metric. I would get a 6 point socket since if you use a 12 point socket on a very tight fastener and it damages the bolt head you will never get the engine apart! Anyway I think you just need a longer lever arm. Another problem on the 99 was limited access to some of the head bolts due to things like the brake booster in the way.
By the way the reason that one head bolt is so tight is most likely that the head is warped. |
yes derrrr lol breaker bar will work but be sure to watch the head because the head bolts are stretch bolts and you can easily snap the head off them.... and again i cant stress enough NO heat or you will most likely dammage the head
Threads Similar to: Stubborn Head Bolt
| Head Bolt Headache | Buttaz | V6 Mustangs | 14 | August 2nd, 2007 08:06 AM |
| i6 Head Bolt Torque | tnknepp | Classic Mustangs | 5 | July 30th, 2007 08:21 PM |
| 3.8L Head Bolt Torque | Cosworth | V6 Mustangs | 6 | April 23rd, 2007 03:05 PM |
| Head Bolt holes in block | lwhitetrash88l | V6 Mustangs | 10 | April 12th, 2007 02:22 PM |
| Debris in head bolt holes... | lwhitetrash88l | V6 Mustangs | 5 | April 12th, 2007 12:25 PM |
