front caliper seized
Old November 21st, 2010, 04:09 PM   #1
99 mustang
clidefr0g is an unknown quantity at this point
my front right caliper is seized im gonna replace it, but i cant find any calipers besides cobra ones. can anyone link me? i just want a mid ranged one for now since its christmas and i just spent 2 grand on my car on friday.
*disclaimer* If i tell you something about your car i may be wrong so if your not sure take your car to a mechanic!
Originally Posted by ReverendDexter View Post
Make something idiot-proof, and they'll just make a better idiot.
Old November 21st, 2010, 05:05 PM   #2
99 BLUE V6's Avatar
99 V6 BASE
NEVER RACED THIS ONE
99 BLUE V6 has a spectacular aura about99 BLUE V6 has a spectacular aura about
what did you get for 2K. what is a mid range caliper
Old November 21st, 2010, 05:16 PM   #3
99 mustang
i got new tires and wheels and fixed a tie-rod, and im looking for a decent caliper but not too expensive.
Old November 21st, 2010, 06:37 PM   #4
MM's Official Lucifer
goren813's Avatar
'00 3.8L & '05 4.6L
Uh. Stock? Remanufactured ones are cheap and easy to find. Works fine.
Old November 21st, 2010, 06:48 PM   #5
99 mustang
they are ridiculously over priced here for stock replacement, which is why im trying to find some online.
Old November 21st, 2010, 07:15 PM   #6
'00 V6 Procharged Mustang
mp4 player has a spectacular aura aboutmp4 player has a spectacular aura about
If you go with anything other than stock aren't you going to need to buy two instead of one though?
You might also want to look into having a local brake shop work on it. I had a sized caliper and they were able to get it working for $20.
2000 Prochaged V6. T-lok, Mach 1 takeoff exhaust with H-pipe, 20% tint, OEM fogs and all HIDs.
SAE Corrected: 289HP/298TQ at 5100RPM(Pegged MAF).
Old November 21st, 2010, 08:01 PM   #7
Codeman's Avatar
Codeman will become famous soon enoughCodeman will become famous soon enough
Do it yourself. Go to your local oriely's or auto parts store get a caliper.
All you have to do is remove the old one two bolts, then the line, then install line and new copper washer on line. Then install pads, tighten two bracket bolts. And bleed the lines. It will cost you maybe 50 bucks total.
Check this out it may help Replacing Worn Out Brake Calipers | Tooldesk Automotive Tool Blog - Reviews, Advice, Question, Diagnose, Repairs, Technical Support, Information
UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors
Old November 21st, 2010, 08:40 PM   #8
Resident badass
Mr. Red Pony's Avatar
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
autozone one. New. Dont get reman.
271rwhp N/A V6
Suck it.
Old November 21st, 2010, 08:41 PM   #9
Resident badass
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
Or rockauto.
271rwhp N/A V6
Suck it.
Old November 21st, 2010, 08:45 PM   #10
1 Wheel Peel
GreenMustang00's Avatar
2000 Mustang 393w
2001 Mustang GT Vert
GreenMustang00 has a spectacular aura aboutGreenMustang00 has a spectacular aura aboutGreenMustang00 has a spectacular aura about
A lot of shops won't work on it because if the caliper fails and causes an accident they are held reliable... Best bet is buying set of two calipers for the front I think
2000 393w Swapped Vert
2001 GT Vert
2002 Six Banger
Old November 21st, 2010, 09:08 PM   #11
Codeman's Avatar
True on the above, most shops will replace them instead of reman them.
EDIT: Also there is nothing wrong with reman ones. They will work perfectly fine. There is almost no wear on a caliper. The only thing is dirt and stuff and then leaky seals. Other than that nothing, the pistons are plastic. A reman one replaces all of that.
Old November 21st, 2010, 10:29 PM   #12
ag11hockey's Avatar
1999 Mustang V6
ag11hockey is on a distinguished road
just goto advanceauto or autozone. all mine are from there.
Old November 21st, 2010, 10:30 PM   #13
ag11hockey's Avatar
1999 Mustang V6
and wth?... the pistons are not plastic lol
Old November 21st, 2010, 10:45 PM   #14
MM's Database Error
WLJohnson05's Avatar
2004 Mustang V6
322.8 rwhp
WLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud of
iTrader: 9 reviews
Just get new ones from one of the auto parts stores as listed...remanufactured parts are fine, but for me, I like the piece of mind that they are new. If you haven't replaced the other side recently, then go ahead and get two of them and do both sides at the same time. The other side is probably looking at seizing too...it's got the same wear on it. I know when I had issues with my it started on the driver side. That one started locking up...replaced it. About 8 months later I had the passenger one lock up on the road and burn it up. Not fun having a caliper catch fire and losing all brakes...
SCT Mass Air Flow Sensor $200
Old November 21st, 2010, 11:29 PM   #15
ag11hockey's Avatar
1999 Mustang V6
^^ he isnt kidding. that happened to mine. i replaced 3 out of the 4 calipers so far and a month after replacing the last one.... the only one i havent done yet is sticking.
Old November 22nd, 2010, 12:21 AM   #16
99 mustang
thanks for the help guys but i think we all got mis directed somewhere ill be more specific
I know how to replace it thanks though code
The only local auto parts store here is selling ONE caliper for 380$ INCLUDING core, which is why im trying to find a pair of them online be it after market or not that should be more of an accurate price. Ford wont order me the part and NOT install it because they are assholes and they want like 200$ for installation of a fucking caliper.
That said, i CANNOT find any V6 caliper's in any online stores, they all appear to be cobra brakes or cobra upgrade kits. If you all happen to know of any please let me know
Old November 22nd, 2010, 12:27 AM   #17
1 Wheel Peel
2000 Mustang 393w
first site I checked out
click
^^Fixed
2001 GT Vert
2002 Six Banger
Old November 22nd, 2010, 12:29 AM   #18
00MUSTANG89's Avatar
00MUSTANG89 is on a distinguished road
I just bought two Calipers from Car Quest they were like 48.00 bucks each and yea i had the same problem my front right one was seized.
I'd enjoy masturbating on her
Originally Posted by Nightmare69 View Post
When people tell me my car a slow POS I say...your right,I just got smoked by a homeless dude on a 10 speed this morning.
Old November 22nd, 2010, 12:31 AM   #19
99 mustang
Click
Those are rears, i need fronts. and they dont have fronts other than the 500$ special edition ones.
Edit: ahh you changed the link, THANKS A LOT!! those are cheap as hell too
Old November 22nd, 2010, 12:34 AM   #20
1 Wheel Peel
2000 Mustang 393w
Yea i changed like 3 times haha but no problem, yes car quest is cheap!!!!!!!!!! IF you have a local one those people are usually nice people to deal with
2001 GT Vert
2002 Six Banger
Threads Similar to: front caliper seized
is it seized? thehrtbrkkid 96-98 13 September 4th, 2010 06:03 PM
97 cobra front caliper cstorey29 96-98 2 June 7th, 2010 06:42 PM
seized engine stephen V6 Mustangs 20 January 28th, 2008 11:53 AM
seized motor 83five0 5.0 Mustangs 9 December 18th, 2006 04:23 PM
