Springs..
Old November 22nd, 2010, 09:17 PM   #1
jakeabraham's Avatar
2003 Mustang V6
jakeabraham is on a distinguished road
Springs..
So, I'm curious what your guys' opinions are on cutting the springs to lower your car, compared to just buying new springs that will lower it 1.5"-2" or so. From what I understand, if you do it yourself, cutting the springs is free. But I just dont understand why alot of people wouldnt go that route instead of buying new springs if there wasn't a disadvantage. So whats the pros and cons of cutting stock springs?
THANKS,
Jake.
Old November 22nd, 2010, 09:21 PM   #2
11.21@123 -150 shot
orangeRcode is on a distinguished road
I wouldn't do it. Many times your ride quality suffers. Pick up a set of used lowering springs.
Old November 22nd, 2010, 09:24 PM   #3
2003 Mustang V6
Thanks for your response, I'll probably wait till spring before I get new springs and I'll probably just buy new ones instead of cutting the stock ones.
Old November 22nd, 2010, 09:32 PM   #4
Six Banger's Avatar
2001 - 3.8
Six Banger has a spectacular aura aboutSix Banger has a spectacular aura aboutSix Banger has a spectacular aura about
Plenty of people cut springs and are fine with the ride quality. 6er_w/vengeance has done it a couple times. As long as you keep it to about a coil you'll be fine.
Look on the bright side: If you're reading this, you're alive. And that's fucking awesome.
Old November 22nd, 2010, 09:37 PM   #5
bigjohnstud4200's Avatar
2000 GT 'vert
bigjohnstud4200 has a spectacular aura aboutbigjohnstud4200 has a spectacular aura aboutbigjohnstud4200 has a spectacular aura about
If you're going to cut the springs, it's suggested you change the shock / struts also. You should change the stuts / shocks anyway if they are due, but if your low on money. I personally would cut the springs and install a set of autozone cheap replacement shocks and struts built for a Fox body (93 model). The fox body has shorter shocks by 1".
You can pick up front struts for $38 a piece and rears for $25 a piece.. are they high quality, HELL no. but they are probably in better shape than the shocks you have on their now if they are past 50k miles.
I am doing this tomorrow myself tomorrow. I'm being cheap b/c Christmas is coming and i would rather my kids get nice stuff than my car priorities.
On an experimental side, I have installed Steeda X2 ball joints (extended length helps with lowered vehicles). I will install the shorter shocks / struts and cut the springs. This will put the car sitting where it would with a good set of springs, shocks and struts and I will be able to get an alignment to see if caster / camber plates are needed. If they can't fully adjust my alignment due to the need for caster / camber plates, i'll know i need to add that to the list.
"...but don't say my car's topless, say the titties is out"
Nas
Originally Posted by thrashersonmomma09 View Post
( member as in person not as in cock although i do love cock)
Old November 22nd, 2010, 11:00 PM   #6
rfcsoulja's Avatar
01 True Blue v6
to slow to matter
rfcsoulja will become famous soon enough
IMO, a car is too big of an investment to half ass a mod on it. I'd just save the money and do it right with good quality parts. Just my opinion though.
My supercharged v6
http://www.youtube.com/watch?v=1lNkgKBw0bw
Old November 22nd, 2010, 11:02 PM   #7
Resident badass
Mr. Red Pony's Avatar
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
Cut 1.5 cools off each spring and it will drop it quite a bit.
Mine before,
After.
271rwhp N/A V6
Suck it.
Old November 22nd, 2010, 11:05 PM   #8
patrick's Avatar
2004 Mustang V6
patrick is on a distinguished road
Looks way better lowered IMO.
Old November 22nd, 2010, 11:05 PM   #9
Resident badass
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
Wow. Looking at it, I think I like original best. And that was .5 off the front only.
271rwhp N/A V6
Suck it.
Old November 22nd, 2010, 11:07 PM   #10
Resident badass
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
I agree 100% I'm eventually get some lowing springs that keep it about the same drop as the cuts.
271rwhp N/A V6
Suck it.
Old November 22nd, 2010, 11:09 PM   #11
MM's Official Lucifer
goren813's Avatar
'00 3.8L & '05 4.6L
These cars def. look correct lowered about 1.5" from stock. I'm one to suggest buying aftermarket progressive rate springs to lower them. Cutting them can be done, but to me its too easy to come out incorrect in some fashion, and for a DD you won't like poor ride quality much.
To a further extent, the ride quality will suffer with stiffer springs as well, it takes more than just springs to make a lowered application look and behave like it was a stock setting. x2 balljoints, bumpsteer kit, c/c plates, new shocks/struts...they all help make it behave naturally.
Either way you decide, get it lowered and take pics!
Old November 22nd, 2010, 11:17 PM   #12
Resident badass
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
I have 4 bolt CC plates, bumpsteer, solid rack bushings, and I am about to get X2s, and lower shocks and struts when it comes time to replace them. I might hold out on springs 'til then, and put it all into one mod and spend a little more to get coilovers all around since I and getting shocks, struts and springs. I have the equipment for it.
271rwhp N/A V6
Suck it.
Old November 22nd, 2010, 11:22 PM   #13
goren813's Avatar
'00 3.8L & '05 4.6L
Good way to do it, coilovers r pricey but the best bet.
Old November 22nd, 2010, 11:30 PM   #14
Resident badass
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
Fo, sho. I will most likey get these and these unless Kyle yells at me about it.
271rwhp N/A V6
Suck it.
Old November 23rd, 2010, 12:08 AM   #15
cut springs are amazing...that is all
Old November 23rd, 2010, 01:08 PM   #16
goren813's Avatar
'00 3.8L & '05 4.6L
Take your GT and get out of here!
Old November 23rd, 2010, 01:09 PM   #17
goren813's Avatar
'00 3.8L & '05 4.6L
Those look good to me, two great brands. Should be good pieces.
Old November 23rd, 2010, 10:03 PM   #18
1 Wheel Peel
GreenMustang00's Avatar
2000 Mustang 393w
2001 Mustang GT Vert
GreenMustang00 has a spectacular aura aboutGreenMustang00 has a spectacular aura aboutGreenMustang00 has a spectacular aura about
Cutting springs are fine if done correct. Won't suffer much ride quality and even if you did... It will look a lot nicer!
2000 393w Swapped Vert
2001 GT Vert
2002 Six Banger
Old November 23rd, 2010, 10:08 PM   #19
Old November 23rd, 2010, 10:20 PM   #20
goren813's Avatar
'00 3.8L & '05 4.6L
Tighten up! You know I love your tight as...ton martin poster....
Yeah.
Threads Similar to: Springs..
Drag springs or lowering springs??? AggieStang General Tech 10 February 18th, 2012 12:45 PM
H&R SuperSport Springs or Steeda Ultralite Springs CaptDeanSierra 2005 - 2010 V6 4 September 5th, 2010 12:07 PM
Summit springs Vs Ford C springs. Advice? SlowNorth 99-04 4 May 3rd, 2010 01:44 PM
stock springs vs lowering springs in drag TotoGT06 2005 - 2010 4 April 14th, 2010 10:25 PM
Are v8 front springs noticeably different vs. 4 cyl. springs 90hatch 5.0 Mustangs 3 August 8th, 2006 06:23 PM
