2001 Mustang
wet sand before i clear my rims?
so ive painted my bullitt rims gloss black and im just about to add the last coat of paint.... after that dries, should i wetsand the paint with 1500 or 2000 grit sandpaper before i add the clearcoat?
I can see some orange peel effect with the paint, so should i remove it with the light sanding? i wetsanded before the clear coat when i tinted my tails, but that was a different type of paint so idk. ill try to get up a pic soon
![]() All Bark, No Bite
00 Mustang Convertible
what kind of paint are you using? you should be able to apply the clear right over the paint.. and then wetsand with 1500 followed by 2000 to remove the orange peel.
another thing.. has it been more then 24hrs since you applied the paint? |
wetsand then see if you need to recoat it...or just try not to sand too deep...then clear
#4 | ||
2001 Mustang
i just finished applying the paint 30 minutes ago im kinda in a situation right now, because for my last coat, i didnt really give it a medium wet coat, so the finishing coat looks kinda dry, and since i was trying to use all of the paint i had, i kinda left a couple splotches of paint that are more gloss than the last coat i left... so should i wetsand and then clear? or just clear, and hope that turns the "dry" paint into a glossy finish
it will get a glossy finish after you clear over it ..
I would personally wetsand everything with 1500 then 2000 this will even out your glossy spots. then just clear over it ..one tack coat followed by 2 wet coats of clear.. and you should be good to go. you can always try one wheel to see how it looks.. let us know how it turns out. |
#6 | |
2001 Mustang
Jailbait till 2013
2001 V6 / 94 Z28-gone
0-60 in -10.3
2001 Mustang
ok,here are some pictures.
first off, i know they look like shit right now, but they arent as bad looking and noticeable in person. so like i said before, on the last coat of paint i put on, i didnt give it a nice medium wet coating, i was just trying to use all the remaining paint i had, and i was spraying more of a dry coat. therefore, in some spots it has the glossy finish i was looking for, but in others, it has the dry and sometimes splotchy finish i need to get rid of. on the coat i had before this, they were looking damn good, and my perfectionism fucked me up... ![]() heres some pics of what im talking bout ![]() ![]() here are some examples of what i was talking about when i said the paint was dry and splotchy ![]() you can see here, the glossy finish that the rims should look like, mixed with the shitty dry splotches ![]() more dryness... oh and btw these rims got a little dirty from sitting in my garage for about 2 days... all those hairs, and sparkles and what not arent part of the finish ![]() ![]() ![]() i started wetsanding with 1500 grit on 1 rim. it still needs to be sanded more with the 1500, followed by a complete sanding of the 2000 ![]() ![]() so my options here are to either, wetsand all of the rims with 1500 and then 2000, and then shoot the professional grade clear coat over them..... or wetsand then repaint the last coat with a medium wet finish, then clear... or just screw the wetsanding on the rims i havent touched so far, (only started wetsanding one) and just lay the final wet coat over what i have so far, then clear... oh and one last thing. these bad boys are getting a laser red pinstripe, so mind you, sometime before the clear, the pinstripe will be going on
Better than ONLYaUNCfan's
2012@lightspeed
So you finally got some bullet rims
Formerly, AhobosCheese and Cheddars.
2001 Mustang
yeah...
haha finally picked them up from a guy off craigslist for $110 as of right now, im just working on this project, and hopefully by the time christmas rolls around, ill be getting new tires, and finally putting these guys on
2012@lightspeed
Good deal!
2001 Mustang
first pic. of the rim looks good man. I still think you should pick up some more black paint and do it right the first time.
just noticed you're n the east bay lol i'm in stockton pretty close..
#15 | |
2001 Mustang
<concord
just take your time with it ..
spray from left to right in an even coat don't stop while you're spraying.. once you're done then turn the rim upside down and spray again from left to right (in this case it will be across since you turned the rim) this will ensure that you cover the entire rim and will give you a nice smooth even coat instead of spot spraying. but again let us know how it turns out
2001 Mustang
Heres a little teaser for anyone who cares. hah
i took a break from this project for a couple weeks, and i still need to wetsand all the rims down, add another wet coat of paint, add the red pinstripe, and then clear. but here they are as they stand now ![]() ![]() ![]() ![]() ![]()
2012@lightspeed
That look really good, props lol at first i was like damn he has no tire on those rims then i saw the second one.
#19 | |
2001 Mustang
hopefully theyll be said and done with tires mounted by new years. hahah and yea out here in the bay we be scrapin! who needs tires? all rim motha fucka!!!! ![]() haha
#20 | |
2012@lightspeed
I think you should leave them just black i like it make it stand out. Thats what i was going to do but i got a deal on these and there in mint condition so i couldn't bring myself to do it.
Threads Similar to: wet sand before i clear my rims?
| How to sand/paint cobra rims? | cc250r | 99-04 | 2 | May 11th, 2010 09:52 AM |
| Is this pealing clear on my rims? Need some insight.. | Zatrekaz | Visual | 32 | December 31st, 2009 01:54 PM |
| What order sand paper grit do I sand in? | 93hatch | The Clubhouse | 20 | June 10th, 2009 02:45 PM |
| Buff/Sand Your Clear Coat by Hand | Lefty | General Car Care & Detailing | 4 | March 11th, 2009 10:41 AM |
| im wet,my cars wet an the weatherman aint always right | 00redgt | The Clubhouse | 22 | July 27th, 2008 03:09 PM |
