My Twin Turbo Build - Page 8
LinkBack (1) Thread Tools
Old July 11th, 2011, 04:46 PM   #141
9986paulk's Avatar
1999 Mustang V6
9986paulk will become famous soon enough
Yeah they are a little big. They only have 5 psi at 3k. One of these would be really good on a stock engine I think. And btw, it is a Mustang Dyno that seemsto read lower. I've ridden in 300 hp cars and they pull nowhere near this hard. A track time is really what I need sometime.
And yeah, there is no way it's the kit. It should actually perform very well with a built engine just the way it's built.
And it's only 7 psi. I wouldn't expect even 300 on this dyno with 7 psi from anything I'd put on this car witht the stock engine. I planned on 10.4 psi but I didn/t have the extra vac hose to run boost from the manifold. Right now it's run from right after the turbos.
And what do you mean by good fuel JT? What turbos that come in t3/t4 would be better?
Twin Turbo
Old July 11th, 2011, 05:32 PM   #142
BWAL Is My Hero
JakeM's Avatar
2003 F150 S-Crew 5.4 FX4
JakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant future
Originally Posted by JTs03v6 View Post
It's not the engine or the kit. The problemb is turbo selection. I have said from the begining of mikes build they are to much turbo for his setup. Although they would work very well on a 4.3l stroker pushing 600+rwhp.
At 320 bhp these turbos arent even starting to breath. Here is a graph of a super 50T(to give an idea), the pte billett 5557 out flow this turbo by quite a bit considerig a single 5557 flow enough power to hit 500rwhp on a 4 banger.
320bhp on the super 50t...
500bhp on the super 50t (still not at peak effiency)...
and btw...both the above graphs were plotted using 3.8l engine
14psi on some good fuel and those turbo's will scream.
This! By good fuel, he means something that will resist detonation a bit better. I say up the boost and get a really good tune laid down and you should exceed your goals. If you are that far out the the turbo's efficiency range you may think about swapping them out for something a bit smaller if that doesn't work. Why throw more money in parts at it if what you got will do you?
*My YouTube channel*
Member# 1 of the Zip Nutswinger Bandwagon of Love.
Originally Posted by dr.gonzo? View Post
That drunk guy ran like I do after I fart in the store
Old July 11th, 2011, 07:05 PM   #143
JTs03v6's Avatar
2003 mustang
7.48x1.56=11.67
JTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura about
A single 5557 t3 .82 a/r on a stock 38 would work. I built a kit early this year using a 5857 .68 t4 and was remotr tuned by justin...made 358/382 sae on 12.4psi. Stock 3.8l and pulled all the way to 5800rpm abd full boost around 3k.
As far as a good turbo for twin setup...that depends on how much power your looking for. I like the mitsu 16's for a stock 3.8l.
I'm going to run a 6262sp on my car(built 3.8l). For a 4.2 stroker I'd recomend a 6265 or even a 6765 depending on how much power your shooting for. Check my youtube page for my 6262 build progress.
New combo: Forged SC short Block,280cfm heads, Precision 6262 turbo, cx 31x12x3 fmic
http://photobucket.com/JTsTurboBuild
http://youtube.com/user/JTsStang
Old July 11th, 2011, 07:16 PM   #144
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to all
I've got a 6765, its an awesome turbo for sure. Does precision release the compressor maps? I want to see the 5557 vs the 3076
Finally ditching the procharger?
Hi, You can call me Kyle
Random ESG fact: Had a prochamber on his v6 before it was popular.
WTB: v6 BBK valve covers
Old July 11th, 2011, 07:20 PM   #145
JTs03v6's Avatar
2003 mustang
7.48x1.56=11.67
Nah, pte dont do compressor maps. I wish they did though. I picked this turbo after speaking with patrick at pte who is a big buick gn guy. From searching the 6262 is close to the gt35 but is rated for more power.
Old July 11th, 2011, 07:22 PM   #146
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
Nah, pte dont do compressor maps. I wish they did though. I picked this turbo after speaking with patrick at pte who is a big buick gn guy. From searching the 6262 is close to the gt35 but out flows it.
Yes that's pretty much where I figure everything out about Precision turbos based on the GN
Old July 11th, 2011, 07:28 PM   #147
JTs03v6's Avatar
2003 mustang
7.48x1.56=11.67
Oh believe me, I did a ton of research on gn receipes as well. Thats where I choose the 5857 turbo. Most go with the cast wheel version, we went billett sp housing all the way.
Old July 11th, 2011, 08:44 PM   #148
9986paulk's Avatar
1999 Mustang V6
By asking what he meant by good fuel, I meant like 93 oct pump gas is sufficient? For like 13-15 psi with the stock cam. It depends where that puts me. I'm shooting for like 370-380 bhp. Or probably 315-320 rwhp on this dyno (with a better power band than the last time, of course)
Twin Turbo
Old July 11th, 2011, 09:43 PM   #149
JTs03v6's Avatar
2003 mustang
7.48x1.56=11.67
93oct, 14psi with completelly stock engine, 14-15* of timing, and 11.5 afr should be pretty safe tune and "should" make around 400rwhp on a dyno jet.
Also keep in mind...400rwhp with a turbo is like 370 with a blower. Your no longer using power to spin the blower.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/v6-mustangs/193745-my-twin-turbo-build.html
Thread Turbo Build couple of questions (on3 performance) | Forums at Modded Mustangs | BoardReader This thread Refback August 19th, 2011 02:48 PM
Threads Similar to: My Twin Turbo Build
2v Twin Turbo Bullitt Build 2001bullitt 99-04 178 April 9th, 2012 08:20 AM
Twin Turbo build thread menace07 2005 - 2010 58 March 6th, 2012 12:11 PM
5.4 4v Twin Turbo build steweod 99-04 143 April 26th, 2011 11:47 AM
My Motor/Twin Turbo build CobraStang161 4V / SVT 205 January 26th, 2011 09:08 AM
DIY foxbody twin turbo build 87vert General Tech 57 April 14th, 2006 07:39 PM
