LinkBack (1) | Thread Tools |
#1
1999 Mustang V6
![]() iTrader: 3 reviews
My Twin Turbo Build
I just wanted to put a thread together since I'm putting the twin turbo kit on my car (whit00stangers kit with new turbos and some other fixes). The kit needs a little bit of work to function it's best and I'll document it here as I make progress.
For those of you who don't know I already had an intercooled Vortech V6 with a cam, ported intakes, etc, with bad results maybe resulting from the cam. We could never get it to run correctly. Pics of Previous Build... ![]() ![]() http://3.7mustang.com/forum/showthre...hlight=vortech I just ordered the turbos yesterday and they should be here by the middle of next week, or the end at latest. They are precision 5557s with the billet compressor wheel. .48 hotside A/R and the Ported S trim compressor housing. Things I need to do: 1. Weld in bungs for the 02 sensors to be before the turbos, where they are supposed to be. 2. Fuel System- Not sure what I'm doing yet...I may just go with SVT Focus pump and upgraded wiring because it's easy. But I'd need it to be able to support me running 10 psi, not sure if it will. All I'll have is a ported upper, lower, and the head ports matched to the lower for a couple inches. Questions as of now: Does anyone know if I should be running any kind of oil restrictors with these turbos? The kit's oil lines are set up so one 1/8" oil line is running from the pump, then splits into two 1/8" oil lines that go to each turbo. Does anybody have any input about Manual Boost Controllers? Would I need one for each turbo, or can I tee one of them? And any brands in particular, or do the $20 ebay ones do the job? I know sometimes they're fine... I'll start updating with pics of all the work I do as I go. I'm relocating the fuse box and battery right now.
Twin Turbo Last edited by 9986paulk; November 27th, 2010 at 05:54 PM. |
BWAL Is My Hero
2003 F150 S-Crew 5.4 FX4
IIRC, the billlets have oil restrictors built in. Lemme see if I can find that.
Edit: I can't find anything specific on any forums I trust about the restrictor being built in on the 5557 Billets, but on S197 forum a guy just upgraded to a 6765SE and his is built in for sure. I am fairly certain all the new billet's have a internal restrictor. But Precision's website is a nightmare and I can find much info on the 5557. Here is the link to the 6765SE build: http://www.s197forum.com/forum/showthread.php?t=43665 Last edited by JakeM; November 27th, 2010 at 05:33 PM. |
1999 Mustang V6
![]() ![]() ![]() ![]() ![]() ![]() I just threw in a pic of my exhaust at the end...and I just took the pic of the pass side of the engine bay for a before and after kinda thing. I didn't get make any more progress today because I slept in and it wwas freezing and I had a few other things to do. Tomorrow I'll get the battery relocate and fuse box thing all done.
Twin Turbo |
2002 Auto V6
Several Seconds
yeah it was freezing here too
Whaaat??
[U]Specs[/U] 351W EFI with 2 cylinder delete [U]Mods[/U] Catted dual exhaust with Flowmaster 40's H-piped $60 XM with no subscription Savings Account Mod $00000.00 [U]Future Mods[/U] None [COLOR="Red"]Put This Immature Crap Back In Your Sig, And You'll Be Taking A Vacation. Love, TheUNZippee!T[/COLOR] Last edited by i-bought-a-v6; November 27th, 2010 at 05:59 PM. Reason: v |
#5 | |
1999 Mustang V6
Twin Turbo |
Needs 2 cylinder bolt on
'03 Mustang V6
It's a six so what do you expect?
man i wish i had enough money to do a turbo lol. I'm jealous. Keep up the good work though, cant wait to see what the car pushes when your done.
2007 mustang
Simple eBay mbc will work, you can even take about 5 minutes and ten bucks to make your own. I'm not 100% sure, I've never ran twins but I believe if you have a single mbc set at 10 psi that's only 5 psi to each turbo. Good luck with the build.
1999 Mustang V6
I think that would actually run 10 psi to each turbo, which would still make a total of 10 psi...does this sound correct, since both turbo coldsides are routed together by the time they get to the manifold?
Twin Turbo |
BWAL Is My Hero
No, it would be 10psi combined. The MBC would regulate both turbo's. 10+10 is twenty...
2007 mustang
Like I said I'm no expert on twins, I just always believed if you had a total of 10 it would split to 5. Your boost gauge will still read 10 psi.
#11 | |
1999 Mustang V6
So lets just say I had 10 psi springs in each wastegate, I would have 10 psi total right? Cause both pipes go together. So that's how it works, 1 MBC tee'd off?
Twin Turbo |
[8MINUS2]
Single or twins or quads...
10psi spring = 10psi on the gauge
1999 Mustang V6
Look in a repair manual...or your oil pressure gauge...the lowest mies been at idle was 35 and gighest I've actually watched was around 60..but I dont think I ever watched it at high rpms...lol
That's what I though...but as for MBCs one tee'd is good? I'll get one off ebay tomorrow then.
Twin Turbo |
2007 mustang
10 psi in two separate wg would equal 20 correct? That's not combining the ten into both then. Sorry if I'm misinforming you but thats how I would see it after my experience with single turbo builds. Yes a single a mbc tee'd off into both turbo would be fine. What wastegates are you going with? Why not just change springs in those to your desired boost.
#15 | |
1999 Mustang V6
But as for the boost, if you have 10 psi on each wastegate, you have a total of 10 psi. Just think of it like this...both of the turbos end up being run together at the intercooler. As soon as you reach a total of 10 psi, both wastegates open. Because the only way for 1 turbo to have 10 psi pressure on its compressor side is for the other side of the system to have the same pressure.
Twin Turbo |
2007 mustang
Makes a little more sense now, like I said I've never had 1st hand experience with twins. But good luck with the build. Hope to see more of it in the near future
[8MINUS2]
I wouldn't buy an eBay boost controller... Thats an easy way to buying a new engine.
And no again... Two wastegates two 10 psi springs, your boost gauge will read 10psi.
2003 mustang
7.48x1.56=11.67
2 wastegates with 10psi springs = 10psi at the manifold. The wastegates are set to manifold psi, not exhaust pressure.
New combo: Forged SC short Block,280cfm heads, Precision 6262 turbo, cx 31x12x3 fmic ![]() ![]() http://photobucket.com/JTsTurboBuild http://youtube.com/user/JTsStang |
#19 | |
1999 Mustang V6
And which boost controllers would you recommend? Yes, that's how I thought it was all along, but others have tried to say otherwise.
Twin Turbo |
[8MINUS2]
LinkBack to this Thread: http://www.moddedmustangs.com/forums/v6-mustangs/193745-my-twin-turbo-build.html
| Thread Turbo Build couple of questions (on3 performance) | Forums at Modded Mustangs | BoardReader | This thread | Refback | August 19th, 2011 02:48 PM | |
Threads Similar to: My Twin Turbo Build
| 2v Twin Turbo Bullitt Build | 2001bullitt | 99-04 | 178 | April 9th, 2012 08:20 AM |
| Twin Turbo build thread | menace07 | 2005 - 2010 | 58 | March 6th, 2012 12:11 PM |
| 5.4 4v Twin Turbo build | steweod | 99-04 | 143 | April 26th, 2011 11:47 AM |
| My Motor/Twin Turbo build | CobraStang161 | 4V / SVT | 205 | January 26th, 2011 09:08 AM |
| DIY foxbody twin turbo build | 87vert | General Tech | 57 | April 14th, 2006 07:39 PM |
