pats-
Old December 6th, 2010, 12:34 AM   #1
00 Mustang Convertible
double0mustang is on a distinguished road
pats-
I'm still working on my car the fuel pump doesn't even prime..
I changed the fuel pump and nothing, changed the ccrm and still nothing changed the FPDM and nope nothing.. (inertia switch is working properly also)
my theft light is blinking and my odometer reads ------- instead of numbers - this happened after i had a short by the fuel pump connector located under the license plate by the fuel tank. obdII reads no link so tomorrow i'm picking up a ECU at a local wrecking yard to see if it even connects to the obdII .
I thought about the PATS system being engaged but after seeing a few videos on youtube I realized that the fuel pump will prime and let the car start and after a second or two the engine will shut off correct?
so my next thing to do is retrace all the wiring and my only guess would be a bad ground connection somewhere .. my cd player was stolen and they did yank the wires out (bastards) so can that be a problem ?
Old December 6th, 2010, 05:57 AM   #2
99 mustang
clidefr0g is an unknown quantity at this point
afaik if pats is enabled it will never start not even for a few seconds, it just turns over and over til the bat is dead.
*disclaimer* If i tell you something about your car i may be wrong so if your not sure take your car to a mechanic!
Originally Posted by ReverendDexter View Post
Make something idiot-proof, and they'll just make a better idiot.
Old December 6th, 2010, 10:43 AM   #3
xn1919's Avatar
2000 mustang
xn1919 is an unknown quantity at this point
Send a message via AIM to xn1919 Send a message via Yahoo to xn1919
pats is gay tho like 200 bonez.. im not sure if its it or no but its gonna be a little risk.. i say have it done it could cost u less money and time.
visco
Old December 6th, 2010, 11:26 AM   #4
1999cobra92's Avatar
1999 mustang cobra
1999cobra92 will become famous soon enough
I'm thinking you have a bad fuse. You should check them
Black and White Crew
Crew Member # 5
Check garage for mods and pics
if you Los Angeles and want to ride send me a text (323) 270-6827
0% Wheel hop, 0% broken parts, 100% wheel spin
Old December 6th, 2010, 11:36 AM   #5
Trick Tuners's Avatar
KB'd GT
I would suspect pats if the theft light flashes during cranking and the car doesn't start.
Old December 6th, 2010, 06:43 PM   #6
checked all the fuses one by one and nothing wrong with it.
does anyone know if the fuel pump is supposed to prime when PATS is activated?
because even before I had any of this problems the fuel pump wouldn't prime.
Old December 6th, 2010, 10:55 PM   #7
Resident badass
Mr. Red Pony's Avatar
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
Keep it simple stupid. Easy stuff first. (these are just saying btw) People blame what they know least. So don't just assume it is the most complicated thing. If you have a tuner, get a tune that disables PATS.
271rwhp N/A V6
Suck it.
Old December 7th, 2010, 06:56 PM   #8
so if the I can't get communication to my odbII what makes you think I will be able to work my way around it with a tuner smart one.
Old December 7th, 2010, 10:56 PM   #9
Resident badass
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
MAKE it get communication.
271rwhp N/A V6
Suck it.
Old December 7th, 2010, 11:12 PM   #10
94 v6 mustang
Puffy93 is on a distinguished road
When PATS has a problem doesn't the dealer have to reprogram it and to do this it requires them to use the OBD II port to reprogram it so it does have communication it just won't give out information to any old scanner you might need a ford scanner or a tunner might work. I'm just saying don't rule that out. I could be whong on that to so don't hold me to that.
94 mustang 3.8
Steeda Tri-ax, FRPP aluminum driveshaft. Soon to get built 351W
Old December 8th, 2010, 08:00 PM   #11
I just thought about doing the odometer diagnostic you know hold the reset button while turning the key to the on position and I got a code dtcd 9681 and dtcd9232 -after a quick google search I found out that those 2 codes are for the PATS transceiver so in other words the transceiver needs to be replaced so I'm going to be changing that during the weekend and hopefully that'll fix the problem.
I did read in a few posts that the transceiver doesn't need to be programmed. so we'll see how it goes.
Old December 8th, 2010, 08:01 PM   #12
Threads Similar to: pats-
PATS help anyone? Cjstratton 99-04 4 September 12th, 2010 12:50 PM
Pats ? 3sportbob 99-04 8 April 27th, 2010 05:58 PM
? about pats 1kwikcobra 4V / SVT 13 March 30th, 2009 09:59 PM
Ot Pats By 17 03firebolt 2005 - 2010 5 February 4th, 2008 04:05 PM
Pats Drick 96-98 13 November 19th, 2007 06:07 PM
