| LinkBack (18) | Thread Tools |
#41 |
Just get a harmonic balancer puller such as this LIS-45500 Lisle 45500 - Harmonic Balancer Puller - tooldesk.com
And on the tuning you can get a good email tune through trick tuners. A dyno tune would be easier, and no wideband is needed, it depends on the cost of your local dyno and how close it is?
![]() UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors |
#42 |
14.37 @ 96
Ok guys,
My Springs/Retainers should be here this week, also since it was 180 Shipped for both. I got an intake spacer just for the hell of it. It will have the whole kit for the spacer, gaskets n all. So Ive gotten the process down of how. Let me make sure I know everything I need to buy though. Engine Oil Engine Coolant Cam Lube ( or will motor oil work ? ) *And what gaskets do I need ? Or will the gaskets in the intake spacer kit cover that part ? Pulley Puller What else ? |
#43 | |
1 Wheel Peel
2000 Mustang 393w
2001 Mustang GT Vert
![]() 2000 393w Swapped Vert 2001 GT Vert 2002 Six Banger |
#44 |
14.37 @ 96
Ok, anything else ?
#45 |
14.37 @ 96
![]() ![]() ![]() ![]() Ok guys, this is all I have so far, and need to get to it so ! I need: Engine Oil, Engine Coolant, Timing Cover Gaskets Valve Cover gaskets cam break in lube Anything else im missing here that I HAVE TO HAVE ??? Im getting new spark plugs just because, im at 50k miles now, so might as well while im in there. Spark plugs Maybe some Carb' cleaner, ill probably wanna clean some shit out on them intakes. lol |
#46 |
01 True Blue v6
to slow to matter
A valve spring compressor
I used a u-joint socket and a few extensions to take off the power steering/ alternator bracket. Otherwise you'll need a power steering pulley puller. intake to head gaskets silicon gasket maker for where the bottom of the timing covers meets the oil pan. Torque wrenches lots of little baggies and a sharpie to label where your nuts and bolts go . A Haynes manual just encase you get stuck or have any question. This should help you out with the camshaft synchronizer removal Replacing Camshaft Synchronizer & Sensor - Ford Mustang Forums (post #8) You'll also need brake cleaner as well as a few wire brushes to clean off gasket surfaces. A gasket scraper may help as well (just be careful not to nick the surface). And PLENTY of rags. I would soak the bolts you will be taking off with WD 40. Pry bars or big screw drivers will also be needed to gently separate the timing cover from the engine block (be patient and slower work it off). Last edited by rfcsoulja; January 11th, 2011 at 05:30 PM. |
#47 |
14.37 @ 96
![]() ![]() ![]() Ok well over night my pile has grown. I now have, Motor Oil and filter Break in lube spark plugs Cam Springs/Retainers Intake spacer w/ bolts 2 upper intake gaskets Head gaskets Timing Cover gaskets I got got coolant stuff.... damn it Have access to a puller Have air compressor Pretty sure we have a spring compressor, they've done this before, last about a year ago Have bags and rags have TQ wrench I do have some black RTV silicon left over, should be way more then enough Im sure something isnt coming to mind ... But thats my latest update. |
#48 | |
2000 mustang v6
14.6@99.68
Mike If you could after the cam is installed and you went easy on it for a bit make a exhuast vid of start up idle rev take off wot drive by...lol just a request cuz I cnt find a cam vid of pppl driving by the only do start up and MABEY rev |
#49 |
01 True Blue v6
to slow to matter
nvm, see em in your pics.
#50 | |
[8MINUS2]
#51 |
1999 Mustang V6
![]() iTrader: 3 reviews
Yeah, without a power adder and the exhaust I had which was just GT take-offs, no cats, h pipe it didn't sound amazing. With the supercharger it did sound good though. I honestly hate the NA WOT sound of our V6s without cats whether they have a cam or not.
Twin Turbo |
#52 |
14.37 @ 96
Will do for vids.
Guys I need help !!!! I HAVE to do this project between fri-mon. Thats plenty of time, but I wont have much help on this. Some family problems arrised, medically that is. Any tips I can get PLEASE tell me. I will be reading my Chiltons, and ssms cam install guide tonight and tomorrow. Most of this will be done by me now, I have no xp in this at process at all. My xp'd dad wont be here for much of it. Whats the best way for this, should I take the heads off to get springs off ( we have a tool for this) or should I rent the tool to take them off with heads on ???? Ill get to reading those two things asap, im at work all night, with alot of shit to do between my work, school that starts next thurdsday and I got alot to finish before I go back, and my car ... So I need as much help on this as possible, thanks guys !!! |
#53 |
1999 Mustang V6
You don't wanna take the heads off, that's an extra hundred and sum dollars for head gaskets and bolts. You should be able to get a spark plug attachment for an air compressor for like $20 or so to hold the valves up whicle you remove the springs, if you have an air compressor that is. You should easily be able to get it done in the time frame you have. The only thing that might give you trouble is the timing chain tensioner, that's all that did fir me and you jus thave to fiddle with it to get it to open and put a pin in to hold it. And the clips on my fuel injector plugs broke and I just zip tie them now. But you can;t really control that, it was a common problem. I don't even remember if you have to unclip them though, I just had to change mine. And just be careful sliding the old cam out and new one in, it's not great to clunk it around in the journals. Not a lot more to mess up. But do find the timing mark on your crank ahead of time, I had to wire brush to find mine for cyl 1 TDC. And then when retorquing the rocker arms just make sure that each cyl is at TDC when you're doing it.
Oh and don't be afraid to use too much sealant on the engine front cover-oil pan. It's better than a leak, which I had the 1st time somehow.
Twin Turbo |
#54 |
14.37 @ 96
Hmm ok, any other input is thanked as well !!!
Just got my rounds done at work, bout to open up this Chilton's and get to reading!!! |
#55 |
14.37 @ 96
Ok, so is there anything I need to do before I actually start taking stuff apart. I mean, the first day I get going, can I just start draining oil, and coolant, and taking off alternator, intakes, all that kind of stuff ?
#56 |
2012gt
how much have you spent so far on all it have to kept tabs??
02 onxyv6duel exhaust cherrybombs mufflers-sold 2012 performance wht gt deluxe 401A
#57 |
14.37 @ 96
I cant remember the exacts, but, with everything you see in those pictures
It was 180 for springs, retainers, intake spacer, and 2 upper gaskets around 280 for cam shipped another 110 for the oil, spark plugs, timing and lower gaskets, break in oil So about 600 so far. Still need some tools n shit, some ill be renting only. And ill be going to HPP in lewisville to get my Tunning done. Idk the price. |
#58 |
14.37 @ 96
The more I read this damn manual the more confused I am ...
#59 |
2001 Saleen Mustang
12.4@108
just take your time man, go slow, 1 step at a time!
#60 |
14.37 @ 96
yeah ... I may start this process tomorrow. Im gonna go home and clear out my car port some, so that I can get my car atleast half way in it lol Make sure our other vehicles are running fine, and start getting my shit together. Then if I got any time left ill probably start draining my oil and coolant and getting some simple shit off and done.
Threads Similar to: Mikes N/A Build, HCI Swap Info
| Mikes Not Very Interesting Build | MikeJones | Projects | 65 | April 29th, 2012 07:29 PM |
| need info on do it yourself engine re-build | brimmer555 | 5.0 Mustangs | 4 | January 12th, 2011 04:07 PM |
| Want to do a turbo build need some info | xtremes10 | General Tech | 3 | December 8th, 2009 06:11 PM |
| pics and info about my build | Iownastang | The Clubhouse | 2 | February 10th, 2008 08:16 PM |
