#21 |
Bringing Yellow Back
tell him to put them back on and be on your way
![]() SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT ![]() BAMA Performance Drag Team Member #4 |
#22 |
Moderator
2003 Grand Cherokee
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 0 reviews
That's not really all that uncommon. All the tire places use impact wrenches and if they start them cross threaded, they pound them on there that way. Or they put them on too tight which causes them to seize onto the studs and break.
#23 |
Dancing Naked In The Rain
Got the car back. They claim they're legally not allowed to install any parts I didn't buy from them but since one of my calipers was damaged and I'd brought 2 new calipers, they put one on and didn't charge me for it (although it was a matter of removing 2 bolts since they were replacing the brake lines). Looked over the wheels and they're fine, although my brakes are no better with new lines and a new caliper (plus new pads and rotors in the Spring). So this was an expensive waste of time
#24 | |
Not Banned
#25 |
14.37 @ 96
If its an acorn style lug, there is only one side w/ female threads ... so impossible
Stock style, like they said, has a tappered end. If put in backwards, It would have not secured the wheel correctly. Allowing play in the wheel, maybe a vibration. Probably not noticable to driving yet. That in itself could have damaged the hole where the lug stud goes through the wheel, by allowing friction against the nut. How that caused such a problem in such little time that you ruined your wheels ... I dont see that as true... Get them back on "correctly", observe each and every lug stud, lug nut, and the holes of your rims. Take pictures, and fill us in. |
#26 | |
#27 |
pop the hood and look at the vacuum line going into the brake booster..if the line even has a loose end or a cut that'll cause your issue
#28 |
I didn't even think about that. I'll have a look tomorrow
Threads Similar to: Damage Wheels From Backwards Lug Nuts?
| lug nuts for drag wheels.... | BakerFX4 | 99-04 | 48 | October 31st, 2010 02:19 AM |
| lug nuts | spetsnaz103 | 99-04 | 7 | June 22nd, 2009 01:29 PM |
| Lug nuts? | IHVOCD | 2005 - 2010 | 16 | April 1st, 2009 12:15 AM |
| who needs lug nuts? | Squints | The Clubhouse | 7 | June 11th, 2008 07:47 PM |
| LUG NUTS??? | whiteboycustom | 5.0 Mustangs | 6 | September 2nd, 2007 01:34 PM |
