Help!!! E Brake Problem
Old December 8th, 2010, 11:49 PM   #1
2004 V6 Coupe
04stang123456789 is on a distinguished road
Alright, so I have had a problem recently with my e-brake/e-brake light. A few weeks ago I smelt the smell of burning brake pads. I pulled off to the side and realized it came from the rear pads. There were no lights on the dash at all, and the e-brake was completely off. I pulled the brake up and down a couple times and the problem stopped.
Now I have a new problem which I don't know if it is related or not. When I take off from either a stop or a slow roll my e-brake light will come on. It is off when I am stopped or rolling from a stop. The light only comes on when I have a steady, slightly hard acceleration. If I take off very slowly the light does not come on. When it does come on, it only stays on for a few seconds. If I am very hard on the gas it stays on until it shifts.
I should also add that there has been a decent amount of brake dust on the rear rims, compared to the front. I do not know if this is from it originally sticking the first time, or this new problem.
What could this problem be? Could the e-brake be stuck? A bad sensor? Please help!
Old December 9th, 2010, 12:01 AM   #2
1 Wheel Peel
GreenMustang00's Avatar
2000 Mustang 393w
2001 Mustang GT Vert
GreenMustang00 has a spectacular aura aboutGreenMustang00 has a spectacular aura aboutGreenMustang00 has a spectacular aura about
One of the brake cables may of stretched or is not connected??
Brake dust on both sides or just one????
Mine did this when I forgot to hook the brake cable back on
2000 393w Swapped Vert
2001 GT Vert
2002 Six Banger
Old December 9th, 2010, 01:11 AM   #3
'00 V6 Procharged Mustang
mp4 player has a spectacular aura aboutmp4 player has a spectacular aura about
Check your brake fluid. The light also serves as an indicator of low fluid and during acceleration there's some slosh in the reservoir.
2000 Prochaged V6. T-lok, Mach 1 takeoff exhaust with H-pipe, 20% tint, OEM fogs and all HIDs.
SAE Corrected: 289HP/298TQ at 5100RPM(Pegged MAF).
Old December 9th, 2010, 01:31 AM   #4
Resident badass
Mr. Red Pony's Avatar
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
This happened to me with the light coming on when I took off. The reservoir was low. But don't just top it off. Check if it is leaking. If it is just low, then you more than likely need new brakes. As the breaks wear, the fluid level goes down to compensate to the calipers being filled more.
271rwhp N/A V6
Suck it.
Threads Similar to: Help!!! E Brake Problem
Brake Problem GP-SE 99-04 10 November 1st, 2010 06:06 PM
e brake problem 05mustangman V6 Mustangs 0 April 10th, 2010 11:50 AM
new brake rotors installed, equals new brake problem StutteringStang06 2005 - 2010 23 December 16th, 2009 06:58 PM
brake problem!!! 95BlackStang 94-95 8 January 30th, 2009 08:43 AM
Brake light switch problem after upgrading brake booster black88 5.0 Mustangs 2 January 20th, 2008 11:41 PM
